BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 2016 LED Headlights retrofit.
      08-13-2017, 04:24 AM   #133
mrtx
Drives: BMW M4
Hello
Ive put new LED headlights to my 2016 F80 VIN:5E68234
They fit plug and play but when I turn ignition off and turn back on they don't light back on which seams I need some coding.
Is there anyone who can help with the coding?? What option needs change or adding??
      11-24-2017, 03:17 PM   #134
emmy_aquarius
Drives: Bmw F30 2013
Originally Posted by marius76 View Post
Yes, common man can retrofit adaptive LED headlights, however is it not as simple as retrofit of the tailights. If you need custom front wiring harness I can make one for you.
I need wiring for bmw f30 2013 xenon to led headlights, do i need light control unit and what else i need please let me know
      11-27-2017, 04:31 PM   #135
Kofiankra
Drives: Red f30 2014
need this doing. just following
FF
      11-28-2017, 10:30 AM   #136
Jhnblckwood
Drives: F30 2014 320i xdrive
Yes u need two main control modules and 8 other modules as well. Look at bmw oem parts list for led's.
      12-08-2017, 06:33 PM   #137
Jhnblckwood
Can someone That has the lci full led headlights help me out. I'm trying to get all the parts necessary since my headlights only came with turn signal modules. I kno I need the 3 led modules for each light plus the main control module for each but I don't know about the "led display for fan" 63117419612. Is that inside the headlight or am I missing something? When I twist the cap off the light I can see something that I think is it but I'm not sure and jus trying to figure this out. Sorry for such a dumb question. Thank you.
      12-20-2017, 03:52 PM   #138
Jhnblckwood
No one?
      12-23-2017, 08:35 PM   #139
Jhnblckwood
Originally Posted by mrtx View Post
Hello
U figure it out dude?
      12-24-2017, 10:41 AM   #140
M3nity
Drives: E90 LCI
Subscribed
      04-13-2018, 05:44 PM   #141
Jhnblckwood
Originally Posted by larry_bml View Post
1 ground, 2,3 are power, one permanent and the other from FEM, 8 is LIN, 9 and 10 are CAN2 wires.
With original retrofit harness is very easy to be done .
U sure about that? For the lci led I thought 1 is activation flash indicator light, 2 is ground, 3 is constant power n then the rest like u said.
      04-14-2018, 03:11 AM   #142
YusufLUK
Drives: 2014 M Sport F30
Originally Posted by maximed3 View Post
Hi guys good news. I just ordered a official bmw F30 led retrofit harness at my local bmw dealer. To code the car you can also go to the bmw dealer at most imported thing it cost only 58 euro with the introduction manual.The coding would be around the 200 euro. So much cheaper than everybody. I let you now next week when i get it of it works.
How did you manage to get them to sell you that? What exactly did you ask for?
I asked my dealership and they said no Lol
How much did the harness set you back?
      04-14-2018, 11:57 AM   #143
rflagg
Drives: F31
Think I found the retrofit harness, it’s this one: 61122410223. Looking at the instructions it also seems like leveling sensors are need as well, I guess you will get errors if they are not installed?
Update: It looks like the non-adaptive LEDs don't need leveling sensors, at least none are listed for S5A2A (LED headlight) so we should be good to go without.
What about coding, anyone know any specifics?
      04-15-2018, 02:21 AM   #144
Jhnblckwood
U still need sensors but the error can b coded out. I’m also interested in the VO coding for non adaptive. VO code 5A2 to fem?
      04-21-2018, 02:54 PM   #145
Jhnblckwood
Before coding the fem they would level separate n at a nice slow speed. After coding fem they would level at same time but real fast. I want them to level slow like they did before. Anyone have any suggestions. Maybe I can fdl code something for the leveling speed? I kno it’s soenthing dumb but I like it when it would level slow lol
      04-27-2018, 02:27 PM   #146
Jhnblckwood
No one who did this retrofit withit the levels noticed this?
      05-17-2018, 01:20 PM   #147
MagnusAG99
Norway
80
Drives: 2017 BMW 330e
Just so u guys know, there is a page called “eurowagens” that sells OEM looking headlights for a lot of the F-gen BMW’s, LCI And pre-facelift, also the reflector versions. Pretty much all the headlight versions, they seem to specialize themselves for F20 and F30. They’re also certified SAE, DOT and ECE so they’re road legal worldwide.
The LCI taillights r also easy to install on a non-LCI. Just switch up some wiring in the rear, just search for “LCI taillights Retrofit” and it should come up a utube video of a blue F30 with the LCI taillights, the dude that made it explained all pretty good aswell.
      07-26-2018, 02:55 AM   #148
6ixf30
Drives: f30
DONE!
without sidemarker
Attachment 1268876
with sidemarker on
Attachment 1268877
LED lights on
Attachment 1268878
indicator light on
Attachment 1268879
Hey where did u get this headlight??? Can u send a link please tha ks.
      08-20-2018, 02:30 PM   #149
ade1990
Drives: bmw f30 2013 front headlight
Post Right front headlight not working after replacement
Hello all,
I know I might not post in the right place but I couldn't find a better thread.
I replaced my right front headlight of my F31 the other day with a TYC 20-12973-05-2. After putting everything together I just realised that none of the lights work on that side.
Is there some coding required in order to make it work? I have no experience with cars, but I thought that it will be as simple as taking out the broken (original) headlight and mounting the new one.
Thank you in advance!
Cheers
      08-20-2018, 02:36 PM   #150
Jhnblckwood
Originally Posted by ade1990 View Post
Hello all,
Cheers
Assuming everything connected properly n nothing else wrong u may have to initialize with ista+.
      08-22-2018, 04:50 AM   #151
Nunaat
Drives: E34 525tds F33 420d I01 bmw i3
Hello Marius, I am retrofitting LCI Adaptive LEd in my F33 bimmer. I am having problems with coding. After vo coding on FEM the FLE units has dissapeared. Before this I detected CAF and they worked fine. Could you help me? Thanks.
      08-29-2018, 10:05 AM   #152
Nunaat
I am sorry Larry but I think pin1 is fem and pin 2 is ground.
      10-24-2018, 05:48 PM   #153
Markom051
Drives: F31
Can somebody help me, I have an f31 12/2012, and I am aware about k-Can 2 signal for the led headlights. Where they are connected in the fem on the model before 07/13? As teh models before 07/13 are using the K-Can instead of the K-Can 2. Thanx
      10-24-2018, 08:51 PM   #154
atzebmw
Drives: Tesla Model 3
https://www.newtis.info/tisv2/a/en/f...74-2v/GS6Y5b7J
