07-25-2018, 12:32 AM | #1 |
Rep 3,540
Intercooler Shootout: ATM vs Wagner EVO 2 Comp!
I've been playing with intercoolers over the past half year, and at my last track day at Laguna Seca I ran the
View post on imgur.com . This past weekend I ran ATM's intercooler along with Wagner's EVO 2 Comp at Thunderhill (east). Both days were pretty hot (~95F) and I was able to get some good sessions in that were very comparable. All of these intercoolers will work with both the N20/26, N55, and N47 engines, but you may need to be aware of slightly different inlet/outlet locations compared to the OE intercooler when using aftermarket turbo to intercooler and/or intercooler to intake pipes (in particular ATM and CSF).I used the Torque pro app in conjunction with an OBDLink LX bluetooth OBDII reader to log data at 4Hz. The car only reports temperature in 1C (1.8F) increments. From the data read, the "charge air cooler temp" is the temperature of the air after the intercooler (sometimes seen as IAT elsewhere). This was compared to the ambient air temp to see how well the intercoolers were cooling the pressurized air. The car is a '17 328dx wagon with JR Tuning's stage 2 flash. The turbo will boost up to 29-30PSI. The turbo to intercooler and intercooler to intake manifold pipes are stock, since both are of the flexible rubber hose type on the 328d, and it makes swapping intercoolers much quicker (I was able to do the swap in under 30min at the end of the first day). Here's a plot showing the difference in performance between the intercoolers. The ATM is consistently lower than the Wagner by 7-11F. I was surprised at this result given the EVO 2 Competition's description. One thing I noticed that ATM does on their core is that they have rounded header bars inside the end tanks to make the flow into the core smoother. Here's the raw temperature data showing the charge air temps and ambient air temps. These two sessions were really well matched ambient temperature wise. Over the next week I'll be logging commute data with the Wagner (got the ATM's data last week) so I can do a comparison on performance in "every day" driving. Daily Driving Performance Link Last edited by FaRKle!; 08-05-2018 at 12:34 PM.. |
s3ri3s1188.50 Jpup26.00 Solidjake945.00 horsepower_and_hounds1836.00 Taskmaster2465.00 VipinLJ1941.50 AmuroRay2282.50 triax37130.00 |
07-25-2018, 11:04 AM | #4 |
Rep 63
In your opinion, how does the CSF compare to the Evo 2 and ATM? Hard to compare via the temps since it was tested at a different time but would be curious to hear your opinion given you have driven with all 3.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
07-25-2018, 01:04 PM | #5 |
Rep 190,807
Nice comparison OP, thank you for taking the time and sharing it.
You forgot to compare pressure air drop and the weight between the 2. Both should easily be in favor of the Wagner since it is a tube and fin core.
07-25-2018, 02:46 PM | #6 | |
Rep 3,540
Temperatures-wise I can't really compare it with the other two since the conditions were so different. I suppose you could try and do some hand waving by seeing how far over ambient the CACT got with it vs the ATM and Wagner, but that was at a different track, with non-tuned car at the time. Someone from my other thread asked how much of a difference the IC can make. Looking at data from the same day (so same IC), in the morning when it was cooler (78F ambient, 118.4F CACT) my max speed on the front straight was 6.75mph higher than the max speed I reached later on in the day (95F ambient, 129.2F CACT). Across all laps between that morning session and this afternoon one, the morning speeds were 6.25mph higher on average. Last edited by FaRKle!; 07-25-2018 at 02:57 PM.. |
Jpup26.00 Hammer Werke101.50 |
07-27-2018, 03:59 PM | #7 | |
Rep 3,540
In daily driving though I clearly noticed a difference in how low my mpg meter would drop going from a stop before the system was pressurized. The Wagner drops to about mid to high 8mpg, the ATM low 8mpg, and the CSF would do mid to high 7mpg. This correlated with turbo lag, or how long it felt before the power came on. From the graphs above, the Wagner tube and fin design doesn't show any benefit with regards to heat recovery, and even if it did, it's baseline level is still as high/higher than the highest ATM reading. |
07-28-2018, 09:18 AM | #8 | |
Rep 5,392
Is it definitely the Wagner "Competition" model that you tested? Did you get some amazing price for it new, or did you find it used? Thanks. |
13blk335ix74.50 |
07-28-2018, 09:34 AM | #9 | |
Rep 5,392
What I think I hear you saying is that the Wagner Competition2 (tube & fin) is noticeably more responsive in daily driving because it flows better so the boost increases quicker from a standing start. I believe that the smaller stock IC may be the only other tube & fin design that you have tested. How does the stock IC compare in terms of flow and responsiveness? (I am thinking that maybe BMW uses a stock tube & fin IC to lessen perceived turbo lag in daily driving.) The Wagner Competition1 and Competition2 models are the only tube & fin upgrade IC's that I have come across on the aftermarket. Have you seen any others? I'm curious to read your comments on the IC's and their daily driving characteristics. Thanks again! |
07-28-2018, 09:24 PM | #11 | |
Rep 10,473
07-30-2018, 10:56 AM | #12 | ||
Rep 3,540
The steering isn't as great as others, however I found that adding a front strut bar definitely added more feeling into it. That mod was TOTALLY worth it (and cheap too!). Adding Superpro camber adjustable bushings didn't do anything really for the steering feel though. |
08-01-2018, 08:08 AM | #13 | |
Rep 5,392
08-01-2018, 10:29 AM | #14 | |
Rep 3,540
08-05-2018, 12:23 PM | #15 |
Rep 3,540
Part II: Daily Driving Performance
To evaluate "daily driving" performance I logged my temps/ect. during my weekly commute. I divided the commute data into morning and evening data sets. The intercoolers were run in back to back weeks, but on average, the ambient temps the week with the Wagner were a bit cooler (for the plots the two closest ambient temp runs were chosen). My commute is about 18 miles with about half city streets and half freeway. The freeway has a hill in it that rises about 486ft in 2.2mi one way and 531ft in 2.5mi on the other. On the initial part of the freeway in both morning and afternoon commutes traffic is moving slowly, including going up the hill. I only hit actual freeway speeds about the last 3-4mi on the freeway. Morning Commute Temp Plots In the morning temps you can see that the ATM has a consistent temperature advantage over the Wagner. That said, in city streets the advantage isn't much. Of note, large spikes in the CACT temps during city street driving is due to no airflow while sitting at a stop light. I wouldn't read too much into the magnitude of it, or the difference in it between the ATM and Wagner since it falls so quickly once the vehicle gets moving again. Evening Commute Temp Plots Ambient temperatures in the evening were higher, especially where I live. City street commute speeds leaving my office are usually pretty slow, and the temps show both intercoolers performing roughly the same. My guess is the speeds aren't high enough to push enough airflow through the ATM to show an improvement over the Wagner that's seen everywhere else, such as the second city street section. One interesting thing to note, is that where the CACT over ambient delta is rising is when I'm in traffic going up the hill, but the peak is when I'm going down the hill coasting (well, coasting and braking as there's still lots of traffic). Temps don't start falling till I reach constant higher/normal freeway speeds, instead of the 15-40mph fluctuations before that. The Wagner doesn't show any advantage in dissipating heat over the ATM in lower speeds or higher ones. Once again, any sharp, short spikes are the temps while sitting at a stop light, which dissipate quickly once moving again. A Note on Lag Measurements elsewhere have shown that the Wagner EVO 2 Comp should flow a bit better than the ATM. Paying attention to lag while accelerating from a stop, and also watching my fuel economy meter seem to confirm that. Accelerating form a stop my fuel economy meter drops to about mid to high 8mpgs with the Wagner. With the ATM it's in the low 8s. The lag is slightly more with the ATM, but it's not large and annoying, and if you're not paying attention to it, probably won't notice a difference from the Wagner. How much of this is due to actual internal restriction, and how much is due to pure volume (the ATM is larger) is a guess to me. I did notice that the ATM uses rounded header bars in the end tanks on the core to help flow (the Wagner has nothing special on the core). It looks to me like the ATM is the superior intercooler. Last edited by FaRKle!; 08-05-2018 at 12:33 PM.. |
08-17-2018, 08:02 PM | #16 |
Rep 2,577
OP, thanks for the great info.
One thing you misunderstood about the pressure loss - you can never measure it by post intercooler boost reading. They always read the same boost, because that's what DME is targeting. Where it makes the difference is pre intercooler boost that you don't get to measure. Turbo would work harder for more boost to make up for what's lost going thru a bar and plate core, so the post intercooler boost target would be met. In fact, the mpg reading you came up with is a very interesting and effective way of showing lag which ultimately means pressure loss. High mpg means more fuel gets burned, means more air goes thru IC and gets into cylinder. Another point is that you compared them with a high boost car. Intercooler performs very differently to different boost level. There is actually such a thing as a too big IC for the boost you're looking to make. I'm not familiar with diesel engine and how diesel motor boost translates to flow rate lb/m and how hot they come out of turbo. Someone really needs to conduct similar tests with a N20 on 22-20psi or N55 on 18-17psi for a proper comparison. These boost level are what pump gas can support at top end at maximum. Above that, ethanol and meth are logical choice over enlarging your intercooler. Thanks again for the great info. Sean
Lemania 2320
08-17-2018, 08:25 PM | #17 | |
Rep 3,540
Absolutely! Unfortunately the N47 we get is a single-scroll turbo, and thus lag is more noticeable. When I ran the CSF IC, which is the same size as the ATM, but more restrictive due to non rounded internal header bars and a more restrictive fin pack, I noticed LOTS of lag in daily driving. That IC was too large and restrictive for my single turbo. |
AmuroRay2282.50 |
08-17-2018, 10:16 PM | #18 |
Rep 1,805
Variable geometry turbos as in our N47s are superior even to twin scroll turbos. We have infinite scroll regulation.
The VNT/VGT turbos just get very expensive to build for them to withstand gasoline EGTs. Porsche started using them on their gas cars, and greatly reduced their lag. Lag that is introduced by changing the volume of the tract to the intake can be improved by tuning. Factory flash turbo control was designed for the factory setup. I doubt anyone is tuning that.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 08-17-2018 at 10:22 PM.. |
08-19-2018, 09:58 AM | #19 |
Rep 2,577
There is another Wagner vs ATM comparison with a different result. Interesting.
https://f30.bimmerpost.com/forums/sh....php?t=1141360
Lemania 2320
08-20-2018, 11:25 AM | #20 | |
Rep 3,540
And I have to say, after my own personal experience with all of those (excluding the EVO 2 Perf), I'm a skeptic of his reviews and level of independence from the manufacturers. That said, there are also testing methodology differences. For the test you linked in particular, the data runs are pretty short. A couple of single gear pulls, followed by a three gear pull. How much cool down time was between each of the pulls? With my on-track data you know I was out there the full 20min session and going WOT often. My dataset is also a lot more comprehensive. My summary for each IC is that from a whole day of track testing, looking at all the laps, finding the trends, and presenting differences with clear signal. For the every-day commute driving I looked at a whole week's worth of commuting both in the morning and afternoon/evening. Additionally, for the direct comparison plots, the ambient temps in my tests are much closer than the other test's (and you can see the ambient temp's values throughout the entire plot). So that's two full weeks of data for my tests vs one day for the other's. I don't feel the other test's test cases are representative of actual every-day driving or track driving. Another reason I'm skeptical is that the test was done at Wagner Tuning, in their presence, and using their equipment. That opens the door for manufacturer influence. My test was completely independent. I've spent $3671.84 (intercoolers, track days, metrology) of my own money doing intercooler tests this year. There's also the amount of time I've spent looking at the data, bringing my lift with me to the track to be able to swap ICs, and other soft costs. Lastly, I have no financial stake in the results. The tester in the other test is a vendor that happens to sell both Wagner and CSF intercoolers. |
08-29-2018, 03:48 PM | #21 |
Rep 504
There are other companies out there who have made objective videos proving the performance of the CSF radiator.
Would also venture to say that more pro-am M2/235 guys are using CSF than any other system on the market. Watch the video to the end, and you can see with the intercooler + stage 1 remap gained 33.1 whp.. Don't see other companies with data like this to support their products. https://www.youtube.com/watch?v=oKNE1oGqmbw |
08-29-2018, 05:42 PM | #22 | ||
Rep 3,540
