01-04-2015, 11:27 AM | #23 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
01-04-2015, 12:51 PM | #24 |
Pace Car Driver
1548
Rep 3,164
No. I did mine, swapped them into my brothers M4, then I did his and put them in our 435.
http://f80.bimmerpost.com/forums/sho...05&postcount=8 Last edited by G30 B58; 01-04-2015 at 12:56 PM.. |
01-04-2015, 12:53 PM | #25 | |
Pace Car Driver
1548
Rep 3,164
http://f80.bimmerpost.com/forums/sho...05&postcount=8 Adding a protectant / conditioner would probably reduce the difference on sheen even more. That is not $300 worth of sheen IMHO. |
corchar13.50 |
01-06-2015, 01:39 PM | #26 | |
Rep 940
It's a good thing the fit, too, because I've found that the more I work on this thing the shinier it gets. My operating theory is that we're not looking at a shiny residue left behind by the sticker; I think that we're seeing the absence of some sort of matte coating on the otherwise shiny plastic. As if that weren't bad enough, sufficiently aggressive use of acetone has caused the plastic surface to "bubble" on my passenger side visor. I suppose that it either penetrated the plastic and dissolved the adhesive or simply softened the plastic enough that it was stretched. I have the Euro visors on order from iND. Here's hoping that the anthracite fabric on the F8x visors matches my F34's anthracite headliner. Not sure why, but I haven't been able to get this image out of my head since reading this. Last edited by ipilcher; 01-06-2015 at 02:04 PM.. |
Onizukachan1086.00 |
01-09-2015, 12:24 PM | #28 |
Rep 940
I got the F8x "Euro" visors from iND installed in my F34, and I'm very pleased with the result. IMO, the fabric-like texture of the F8x visors looks better next to the headliner than does the pebbled texture of F34 visors (without even considering shiny rectangles).
01-09-2015, 12:44 PM | #29 | |
Rep 3,089
01-09-2015, 01:20 PM | #30 |
Pace Car Driver
1548
Rep 3,164
01-09-2015, 05:54 PM | #31 | |
Rep 940
And as I said, I do think that the fabric-like texture of the F8x visors actually matches the headliner better than the pebbled texture of the F34 visors. (The headliner looks rather grayish and sparkly in my pics, but that's because of the camera flash.) I noticed that BMW uses different parts numbers for most F30 and F34 visors. I'm sure the reasons make sense in German. What is the F30 visor textture like? |
01-10-2015, 08:09 AM | #33 |
Pace Car Driver
1548
Rep 3,164
06-04-2018, 04:38 PM | #34 |
Rep 4,551
Drives: 2015 328d xDrive
Just did this with my non m sport 328. The gray visors aren't cloth, they're a different material. You want to use something with acetone (nail polish remover) not alcohol. It works way better/faster.
02-18-2021, 11:33 PM | #35 |
Rep 51
Man I wish mine came off like that. haha Mine melted into a mess. The first visor I ended up scratching off slowly with my fingernail. But I got it off. The second visor, I kept the sticker wet the whole time. It went way faster, basically scraped it off from one end to the other. I noticed a minor sheen difference until I soaked the visors in Lexol. My thought was Acetone strips the moisture out of the vinyl. Lexol should re-moisturize it, right? We'll see if there's a sheen difference after some of the Lexol is absorbed and the excess is wiped off in a day or so.
Overall, It's a subtle improvement, but an improvement. After daily driving an e28 for 11 years I got used to a certain lack of things, like bright yellow safety warning stickers, or airbags, or ABS, or safety features. lol Last edited by delorean175; 02-18-2021 at 11:44 PM.. |
12-23-2021, 07:47 PM | #36 |
Rep 74
Bit of a thread revival, but I have some good advice to add to this DIY so I think it is appropriate.
I followed the DIY, as well as some of the other posts. Alcohol barely worked, acetone worked OK, but required a lot of rubbing (US cloth sun visor). This left a white outline and an obvious "sheen" difference. I got out some brake cleaner and soaked a paper towel in it, and rubbed the area of the visor where the outline from the sticker was. After this I cleaned it with Mothers VLR (Vinyl Leather Rubber) cleaner/conditioner that has some oils in it. This made the sun visor look new without any sticker outside visible at all. |
G30 B581548.00 Emerson33586.00 |
12-24-2021, 06:52 AM | #37 | |
Pace Car Driver
1548
Rep 3,164
Good to know. New G30 arrives on Jan 10th and the removal of these will be on the list. |
