07-27-2021, 09:55 AM | #312 |
Rep 17
Hi guys,
I have a 2014 320i M-Sport package with the standard tire size: 225/45/18 Front 255/40/18 Rear I'm looking to upgrade to: 235/45/18 Front 265/40/18 Rear Is this possible? It's worth mentioning that I have 12mm spacers in the front and 15mm in the back. Thank you for your help.
2014 BMW 320i | BM3 Stage 2 E30 | eBay Downpipe | eBay Intercooler | Muffler Delete | Rev9 HyperStreet II Coilovers | Full LED Bulb Conversion
10-05-2021, 03:19 AM | #314 |
Rep 5
11-13-2021, 12:14 PM | #316 |
Rep 28
waddup peeps.
i've never done any tire/wheel upgrades myself, and all my vehicles have been fitted thru the dealers or shops and, i just didn't really pay attention to it. and now i'm attempting to learn so please bear with with me. car: 2014 f30 328i xdrive current: 225/45/r18 91v m+s (summer tires) i'm also looking for my car's tire/wheel oem spec sheet. i found the user manual so far. 1) what's the widest/narrowest tire/wheel combo i could use without making any mods or adding adaptors etc? looking for the min/max range i guess. 2) winter tires: is it better to have smaller and/or narrower rims but higher tire profiles? i'll prolly have more question, but i think, item 1 would cover most thanks peeps. |
01-21-2022, 01:18 PM | #317 |
Rep 90
@.BMW
Hey, read through ALOT of your tire recommendations but still didn’t find the answer I am looking for. I have a 16 328i xdrive with the track package, m sport etc. Still keeping the orbit 398 wheels and currently have a square set you with 225 run flats. I want the MPSS, how aggressive can I go and stay within the 1% for the xdrive. Thank you |
03-31-2022, 02:03 AM | #319 |
Rep 1
Setup front and rear R20 8.5 225/35
Hi all, just want to share my setup front and rear R20 8.5 225/35. (stretch look tires). BMW F30 328i xdrive. No problem with steering. In front abuot 5mm clearance rim from shock abrobber.
P.S. all wheels same ET45. Last edited by remyygaaa@gmail.com; 03-31-2022 at 05:20 AM.. |
04-12-2022, 08:58 AM | #320 |
Melbourne Red F32 B58
59
Rep 99
I am still slightly confused on my brake package. 2017 440i xDrive M Sport.
Front brakes are Brembo, but gray and unpainted. Rear brakes are single piston gray and unpainted. Is this the standard brake package? If you upgrade at BMW (M Package), do they only add a painted front set (same caliper type) but upgrade the rears to 2 piston as well? Currently stock wheels on M Sport 18x8s with Pirellis. This weekends brake job includes: Clean and paint all Calipers Replace all rotors (hoping I bought the right ones since I am still slightly confused) Replace pads with EDC Reds Flush brakes Replace Stock wheels with TSW Tabac 18x9.5 +40 and Michelin SAS3 Photos will come next week |
09-21-2022, 04:44 AM | #321 |
Rep 30
Hey guys,
quick question. I have F31/2017, used, got it on 18" BMW 254 wheels (225/45/18). If I understand correctly, this are 8Jx18 ET30. And according to internet I should have 8JX18 ET34. https://www.alloywheelsdirect.net/bm...254_wheel_3077 https://www.alloywheelsdirect.net/in...ting_chart/bmw Is this OK? Since this wheels are probably from 5 or 7 series? They are really nice though. |
09-21-2022, 06:47 AM | #322 | |
Rep 5,392
In simplest terms, the offset indicates how much the wheel is pushed in or out of the wheel well. So your 254 wheels having an offset of ET+30 means that compared to the 400M wheels with an offset of ET+34, your wheels stick into the wheel well by 4mm more than the 400M wheels. 4mm is tiny, just a little more than 1/8 of an inch. Very difficult to notice and no fitment issues. There are many articles if you wish to learn more about offset. Here's just one: https://www.turnermotorsport.com/t-wheel_guide Tip: when you eventually need new tires consider upgrading to a wider size on the same wheels if you would like better handling and stability. The widest, best handling on an 8" wheel is 245/40-18. 235/45-18 is also an option. The Continental DWS06 Plus is a very popular all season tire. Hope this helps! |
11-13-2022, 08:16 AM | #324 |
Rep 13
12-23-2022, 10:16 AM | #326 |
Rep 10
does anybody know if these will fit my 2013 f30 330d xdrive? i had a little accident last night and my two front wheels are completely destroyed, ive found somebody selling these i just want to be sure they will fit, any help is greatly appreciated, thank you Luke
Front: 639 19x8 5jj et35 Rear: 639 19x9 5jj et 40 |
12-23-2022, 10:39 AM | #327 |
Rep 4,333
12-24-2022, 02:32 PM | #330 |
Rep 10
so a quick update! i lost my locking wheel nut key! managed to find somebody to come out and remove them, was expensive (Christmas and all) but i got my old wheels off, now my new wheels when i try to put them on they wont go on the hub properly because the wheels hitting the springs, do i just simply get some wheel spacers or? im new to all the car scene any help would be greatly appreciated as my car is off the road until i can get my wheels sorted thanks for the help!
