BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
      09-11-2018, 10:39 PM   #199
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by jballer64 View Post
Maybe I have missed this, but can someone put up an updated instruction for coding Sport +, LC, and all that goodness through the BimmerCode app? I see some things have changed from the original instructions and it isn't working for me so I know I'm missing something.
Thanks!
It should be 2014+ & varies by chassis and production date. I believe it is as follows:
• F32 = Production after 07/13
• F33 = Production after 11/13
• F34 = Production after 03/13
• F36 = Production after 03/14
      09-28-2018, 04:54 PM   #200
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Thanks!
I'm in the same boat. Can someone provide a clear list of exactly what needs to be coded in BimmerCode to activate Sport+ and LC ?
      09-28-2018, 11:47 PM   #201
Almaretto
Almaretto's Avatar
2374
Do you have access to NBT, Kombi, ICM, & EGS?
      09-29-2018, 07:00 AM   #202
sspade
sspade's Avatar
I believe so. I have BimmerCode which is what others from here have used to code these features. Just tryna follow suit.
      10-01-2018, 09:16 PM   #203
Almaretto
Almaretto's Avatar
2374
If you do, then you can code it. If not, you would need E-sys. I have never used Bimmercode, so I could not tell you whether present or not.
      12-14-2018, 05:52 PM   #204
MENCHO
MENCHO's Avatar
Drives: 2012 BMW 328I modern line
sport+ coding with vgate
Originally Posted by kapkanimd View Post
I enabled sport + on my 328i. It has been talked about before. Just coding. Not sure if any different for 320
Hi my friend just trying to code sport+ with no luck I bought vgate dongle to code in bimmer app I confuse can you help me out thay told me I have to change some values in order to see sport+ on screen and working do you think that mabe is not available for my car
      12-27-2018, 06:11 PM   #205
egrimisu
Drives: BMW 420xd 190HP
Will trese Settings alter the transmision Even in Comfort mode?
      12-28-2018, 10:45 AM   #206
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
This question may have been answered but why did my car not come with sport+ originally? It’s been great to use esp given my other mods. The steering is more responsive, gear shifts quicker and exhaust sounds better. Just wondering why it didn’t come with it originally - and is there any harm in using it?
      04-24-2019, 11:05 AM   #207
rychu9191
Drives: bmw f10
Exclamation
Hi,
I have F10 manual transmission. I change:
ICM/IcmKod_B_S2TBA -> verbaut
and now I have sport+ but only DTC off, i need DSC off with sport+ how coding?
      04-28-2019, 01:27 PM   #208
IraHayes
Drives: 328i
I tried coding it through Bimmercode originally, but could not. I just got my car back from the dealer to replace a faulty thermostat, and while there, they appear to have updated the software because all my settings were set back to factory default. When I went in to re-code, I selected Sport+ just for the hell of it and it worked. My HVAC also doesn't default to "on" on startup like before either.
I think if you are not able to code these options, it's because the current version of software in you car doesn't support those functions. You may need to take it in for service and request a software update.
      05-12-2019, 07:20 AM   #209
l.e.s.t.e.r
l.e.s.t.e.r's Avatar
Poland
Drives: F31 320D
Is it possible to cooding the 8th gear in sport, sport +?
      05-13-2019, 06:46 PM   #210
doctor80
Drives: F30, 328 Xdrive
Can someone finally explain other than turning DSC off in Sport+ , do you actually FEEL the difference?
My F30 , 2016 328xdrive does not have it, and no paddle shifters.
Is there any benefit in sport+ comparing it to Sport?
I just wanted to know if it worth the hassle
      08-08-2019, 04:30 AM   #211
Kozenko
Man
Kozenko's Avatar
Poland
Drives: F31 320d EfficientDynamics 13'
Hello!
Does anybody coded fully sport+ (with DTC OFF) with the manual gearbox successfully??
I have 320d with manual transmision.
I am really green with the coding.
I would be very grateful if You could help me step by step.
Thanks!!
      08-11-2019, 04:43 PM   #212
T2avi
Drives: BMW 318D
Bimmercode for Android
First go to Integrated Chassis Management
Set SPORT + driving mode to Active and then CODE
After that go to Instrument Cluster and set there aolso SPORT + to active
      09-02-2019, 04:39 AM   #213
Kozenko
Man
Kozenko's Avatar
Poland
Thanks for reply.
I will try to code this week.
I have the bimmercode for iPhone, but I guess it's the same.
Those two options to code and that's all?
I'm just asking because the thread looks quite complex so I don't want to miss something.
      12-11-2019, 03:17 PM   #214
it3_Magic
it3_Magic's Avatar
113
Drives: 2014 520D M-sport
2017 BMW G30  [0.00]
On my 2014 f10 coding ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut throws a driving stability error that doesn't go away. Once I code that option back it's perfectly fine.
      01-18-2020, 02:08 PM   #215
Ceejays88
Drives: BMW F30 328i
Really confused with all this.
Is sport+ only available for Autos?
If not can someone tell me what I need to code in esys for my manual.
All instructions I am finding are for SAT included
      10-10-2020, 11:31 AM   #216
deusexe
Drives: BMW F30 320d
Originally Posted by trdiablo View Post
I did the coding of
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1 2 3 4 => menue_3
FDS_MENUE_SIGNAL_1 2 3 4 => menue_3
ICM/3000 Daten/IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
Sport+ shows up if you are on sport and press again the sport button on the idrive screen and on the dashboard.
It only doesnt show up in the overview you have, that one only shows:
Sport
Comfort
Eco Pro
Does anyone know which line should be coded to have them all 4 appear below each other in the instrument cluster?
And what has already been able to code it without changing to 2TB? (SAT)
      11-23-2020, 06:57 PM   #217
Icona
Majesty
Icona's Avatar
Drives: 2017 BMW 320i X-Drive
I hate to resurrect this really old thread, but I’m having one small issue with the Sport+ coding on my 2017 3 Series. I managed to code the menu and modules correctly, but I’m missing the “Sport+” indicator in the instrument panel. When I switch modes via the console, I get confirmation of Sport+ mode on the display and instrument panel under the gauge, but not in the small dialog box that’s in the center of the instrument panel. I’m assuming that I need to edit another FDS menu file. Anyone have an idea which one I’m missing?
      11-24-2020, 07:47 AM   #218
Icona
Majesty
Icona's Avatar
I did the coding of
Sport
Comfort
Eco Pro
Hello Diablo, did u ever manage to sort that out? I’m having the same issue and can’t seem to find what menu I’m missing to get Sport* to show up there.
      01-08-2022, 08:09 AM   #219
SharkGrogu
SharkGrogu's Avatar
Romania
Drives: BMW 320i F30 LCI
Originally Posted by Timur View Post
It is possible . I have done on on my 320i.
Do the following:
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
Hello guys, stupid question: are these steps performed in E-sys?
If yes, can you please point where these changes should be applied?
      01-08-2022, 10:54 AM   #220
shawnsheridan
shawnsheridan's Avatar
Yes. FDL Codes are in KOMBI, ICM, and EGS as written.
