BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Damaged F30 M Sport Steering wheel
      09-19-2020, 10:43 PM   #1
bmwaddictt
bmwaddictt's Avatar
22
Drives: BMW 428i F33 M Sport, 320D F30
Hi all, hope everyone is keeping safe!
So, I think I was a little rough when cleaning my steering wheel last night with Meguairs Leather Cleaner then with some Conditioner... :
I've scraped the leather off pretty bad so I'm looking at options to upgrade to the F8X wheel. I've confirmed that I can indeed use my existing airbag
, but can I use my existing trim piece and paddles?
I'm literally looking at this piece here:
https://www.ebay.com.au/itm/124339514522
It's the M Performance wheel. I think it will look fine without the CF trim. I'm even thinking of just getting the F80 base wheel with the tri coloured stitching. Would love if anyone could help me out.
2016 428i F33 Estoril Blue | BM3 Stage 1 OTS 98RON | xHP Stage 3 | VRSF Ceramic Coated Catless Dp | MST Intake | GFB DV+ | M4 V2 M Perf Steering Wheel | M Perf Diffuser | M Perf Floor Mats | M Perf Side Skirt Decal | Adaptive M Suspension | Ceramic Coated | LCI Radio Trim Retrofit | M4 ASD | Speed Limit Info Retrofit | Wireless Charger Retrofit | Mods4Cars SmartTOP Module | M Blue Calipers | Michelin PS3 RFT | Andream CarPlay | All bulbs LED
      09-19-2020, 11:35 PM   #2
Cityofangeles323
Cityofangeles323's Avatar
Drives: Bmw 320i
Customizable wraps from mewant or east detailing. Looks to be a solid, cheap fix.
exE36M3346.50
      09-20-2020, 12:33 AM   #3
zibbit
Drives: 14 335ix M Performance Edition
Any of the BMW M-Perf wheels will retrofit to your car, even the ones that came on the F80/82/87 from the factory. So options are almost endless; black stitched, tri-color stitch, alcantara, electronic, etc..
All of the controls and covers will swap over, including paddles, airbag (stg1, 2 or 3), factory steering wheel shaker and wiring harness. Underneath they're all the same except for ONE thing; whether they're heated or not. That's the ONLY go, no-go option that's not easily retrofitted.
Warning the job to swap everything over is a serious PITA. Make sure you take LOTS of pictures so you know how the factory routed the wires.. cause once it's apart there's almost no documentation out there to guide you to put it back together.
      09-20-2020, 12:46 AM   #4
zibbit
Oh.. one more thing. I NEVER recommend anyone getting an Alcantara covered steering wheel if they care about how their car looks. That material isn't meant to be handled or touched all the time; especially with bare hands.
On a dashboard or a trim panels to remove glare.. OK.
As inserts on seats.. ok-ish if you don't sweat lots. But be prepared to be constantly cleaning.
Oh, and fake black Alcantara turns light purple VERY fast in car interiors.. so word to the wise.. you might be disappointed after a couple months if it's not genuine stuff.
      09-20-2020, 01:33 AM   #5
bmwaddictt
bmwaddictt's Avatar
22
All of the controls and covers will swap over, including paddles, airbag (stg1, 2 or 3), factory steering wheel shaker and wiring harness. Underneath they're all the same except for [COLOR="Red"]ONE[/COLOR] thing; whether they're [COLOR="red"]heated or not[/COLOR]. That's the ONLY go, no-go option that's not easily retrofitted.
[COLOR="Red"]Warning[/COLOR] the job to swap everything over is a serious PITA. Make sure you take LOTS of pictures so you know how the factory routed the wires.. cause once it's apart there's almost no documentation out there to guide you to put it back together.
Right, now the wheel I want to get, I'm not sure if it is heated or not. Can you confirm? My wheel isn't heated.
      09-20-2020, 03:33 AM   #6
zibbit
If your car wasn't equipped with a heated wheel, technically you could install either a heated or non-heated wheel without issues. It would just mean there would be an unused connector on the RH center strut.
As a rule, BMW doesn't install steering wheel heaters into any of their Alcantara or Electronic display wheels.
      09-24-2020, 08:13 AM   #7
bmwaddictt
bmwaddictt's Avatar
22
Hi mate! Thanks for your help. Have upgraded to the M4 V2 M Performance wheel.
      09-27-2020, 03:04 PM   #8
Ennoch
Drives: F31 335D XDrive
Could that not have been refinished with leather dye? A bit late if it's already given you an excuse to upgrade, but worthwhile if anyone else is in a similar position. I did my old Impreza one with some filler (climbing calluses wore a groove in the back of it!) and then airbrushed black dye over it - it looked like new. I've had similar success with repairing the pronounced seams on the Opal White individual leather seats in my F31.
      09-27-2020, 07:23 PM   #9
John in VA
Drives: 2015 228i M Sport
Probably.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      10-01-2020, 01:46 PM   #10
BimmerRimmer
BimmerRimmer's Avatar
Drives: 2016 F36 M Sport
I just pulled the trigger on one of those Mewant steering wheel wraps. We'll see how it goes!
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
      10-05-2020, 03:22 PM   #11
watermannc
watermannc's Avatar
Drives: BMW 330i xdrive
What is a steering wheel shaker?
