08-30-2018, 09:19 AM | #1827 |
Rep 2,382
Means that they are pushing the power of a 55W bulb to a 35W bulb which causes it to overheat and burn the projector. These bulbs are true 55W setups and won't burn. Not saying there aren't others out there but I've been happy with these so far:
http://retro-solutions.net/product-i...IT-pid664.html
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
09-01-2018, 12:48 AM | #1828 |
Rep 129
Has anyone been able to get a clean beam cutoff? I adjusted the bulb position to center the hot spot but this is the best I can get it l. The first picture is the left headlight. The second on is the right. Third picture is both headlights.
09-09-2018, 07:16 AM | #1830 |
Rep 38
Will these fit north america models? Seems to be the only option I found...
https://www.schmiedmann.com/en/produ...oduct=FLXF3031 |
09-10-2018, 09:27 AM | #1831 |
Rep 38
I contacted them and they said: Yes these should fit no problem, however they are intended for euro versions.
Should I be worried about "not intended for but should fit" ? Anyone ever installed those on US models? Thanks! |
09-13-2018, 09:23 AM | #1832 |
Rep 129
They will fit but the beam pattern will be different.
09-17-2018, 02:40 PM | #1833 |
Rep 21
Hello,
I current own a 2017 bmw 320i with stock halogen light and I want to replace it with retrofit Lci headlight. The retrofit headlight are for 2015 models, but aren’t all bmw headlight unit the same size? So, it should be able to fit fine. |
09-21-2018, 12:43 AM | #1834 |
Rep 69
09-21-2018, 09:18 AM | #1835 | |
Rep 2,382
09-21-2018, 09:23 AM | #1836 |
Rep 4,456
Same so you should have no fitment issues.
09-25-2018, 05:14 PM | #1838 |
Rep 38
USR finally got the lights in stock, just ordered them. I went through a lot of pages in this thread, there's a lot of info lol... I don't know if someone with the info could just quick reply my question.
What the most common lightbulb used with these lights? Just bright halogens? Thanks |
09-26-2018, 08:58 AM | #1839 | |
Rep 129
09-26-2018, 09:37 AM | #1840 |
Rep 38
09-26-2018, 10:55 AM | #1841 |
Rep 129
I think it's worth it to upgrade to a HID kit. I installed DDM Tuning Ultra Canbus HID kit with 5500K bulbs. The output is definitely brighter halogens. Others have used The Retrofit Source H7: MORIMOTO ELITE kit. With either kits you'll have to use H7 bulb adapter. I had trouble with the bulb positioning. If you plan on going this route, install the HID bulb before your install the headlights.
09-26-2018, 10:57 AM | #1842 |
Rep 129
09-27-2018, 12:02 PM | #1843 |
Rep 38
I will receive my DEPO angel eyes tomorrow and I think I will go with the HID option for the bulbs. I did a lot of research and ended up with that:
HID Parts H7 HID Adapter : https://www.theretrofitsource.com/h7...ros-49083.html 10$ H7 Morimoto HID Bulb: https://www.theretrofitsource.com/hi...to-xb-hid.html 40$ H7 35W Canbus: https://www.theretrofitsource.com/ba...anbus-35w.html 90$ Total: 150$ |
09-27-2018, 12:51 PM | #1844 | |
Rep 241
09-27-2018, 12:58 PM | #1845 | |
Rep 38
09-27-2018, 07:28 PM | #1846 |
Rep 5
Noob here. First timer to BMW. - looking for cliff note version.
The DEPO headlamps is just the housing along with the "angel eyes". No bulbs correct? What bulbs? Can LED fit? Why on earth will this throw a code? I dont think i have been this confused upgrading headlights before. |
09-27-2018, 07:38 PM | #1847 | |
Rep 241
Some people place LED or hids of their own replacing the halogens that come with the depo units. This could throw an error code due to our cars having the can-bus bullshit in our cars. (Google can-bus for further explanation on that.) Hope that helps. -before upgrading to depo units, I had LED bulbs in my oem headlamps replacing the halogens and never got an error code. I bought specific leds that claimed it would not throw an error code, and they never did. Last edited by jlorenzo125; 09-27-2018 at 07:52 PM.. |
09-27-2018, 07:55 PM | #1848 |
Rep 5
So.....if I want the halo ring/angel eye look I go with depo units (or equivalent) and then get good bulbs. If I just want to be able to drive at night I can just get good bulbs.
Can I ask what LED did you have? |
