BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Best Spark Plug for your B58
      07-03-2020, 01:46 PM   #1
kern417
Cheapskate
4450
I made a video to answer most if not all of your spark plug questions. TL;DR at the beginning for cliff notes, or enjoy listening to me ramble for 15 minutes 🤘🏾 hope this helps.
Appreciate 13
M140_BCS237.50
OzBMR574.50
IMS-340C394.50
Solid67187.00
Supr3me552.00
PeterWT253.50
e_b_d_i18.00
WolfGTI716.00
njdangelo436.00
      07-03-2020, 06:13 PM   #2
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Great visual comparison of the various plugs people talk about using.
I don't think the Champion plug is colder than the NGK plug. Both companies have their own heat range classifications and the comparison chart is a rule of thumb guide and I think it's a bit off in this case.
The NGK plug has a shorter, thicker insulator nose which should dissipate heat more easily and the tip itself is better insulated.
NGK 94201 on the left, stock Champion on the right
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
kern4174449.50
      07-04-2020, 09:55 AM   #3
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Great video and info Kern as usual.
My car has the Champion Spark Plug and from the video you mentioned that we can't go a step colder with the exact same thread length inside the cylinder and also the contact point with the Coils ?
If there's a 1 step colder than the OEM Champion plugs with the exact dimensions (thread length/Coil contact area) I appreciate if you could list the brand and part number.
Thanks mate.
Originally Posted by kern417 View Post
I made a video to answer most if not all of your spark plug questions. TL;DR at the beginning for cliff notes, or enjoy listening to me ramble for 15 minutes ���� hope this helps.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT --------
      07-04-2020, 05:26 PM   #4
kern417
Cheapskate
4450
Thanks mate.
To clarify, I believe what you're referring to is when I was saying that the TU plugs are longer but they are not a step colder.
Also, there are currently no plugs available that have the same geometry and are a step colder than the factory plugs.
      07-04-2020, 11:30 PM   #5
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
I did some measurements on the NGK 94201 vs stock Champion.
Insulator thickness at the end of the threaded section
NGK 4.77mm
Champion 4.33 mm
Depth of insulator nose (from electrode strap measuring to inside of the threaded section)
NGK has 2mm less depth compared to the Champion plug
NGK has a shorter, thicker insulator nose and should be colder than the Champion.
kern4174449.50
F30_E0.00
      07-05-2020, 04:50 AM   #6
IMS-340C
IMS-340C's Avatar
Egypt
395
No your video is great and very clear for everybody to understand many thanks.
Only point at that needed to be more clear at 11:20 into the video you said Gen1 and Gen2 has different pistons/compression ratios, you forgot to mention that not all Gen2 has lower compression the early production Supra with the Gen2 engine had the same compression ratio of 11:1 like Gen1 while the M340i which had a different compression ratio of 10.2:1 and for MY 2020 the Supra also shifted to 10.2:1 compression ratio.
My question was: There is no way to find a spark plug on the market which are colder and have the exact same thread depth and coil contact area shape like the ones we have in our OEM Gen1 engines ?
EDIT: So basically we can't put a colder spark plug in our Gen1 engines than the Champion spark plug ?
      07-05-2020, 06:54 AM   #7
kern417
Cheapskate
4450
Right, basically I should have said a combination of those things. Even the injectors spray pattern and pressure play a role in how the ignition happens. So a lot of variables between the 3 engines.
And no, at this point no colder plugs are available. That might change in the future, but people are running 700+hp on the stock plugs without issues. I don't think they're really needed.
IMS-340C394.50
      07-05-2020, 06:55 AM   #8
kern417
Cheapskate
4450
NGK 4.77mm
Champion 4.33 mm
This is what everyone was saying in the other thread, so there much be some other characteristic of the plug that has an effect. Perhaps the materials used affect the heat range to make it lower. But we can't find any mjore details on the heat ranges themselves other than that chart, and I'm inclined to trust it until i see more specs. But it just goes to show that the NGK will work just as well.
      07-05-2020, 09:19 PM   #9
InstigatorX
Drives: 2018 440i GC xDrive
Suggestions on reputable sources for the Champion plug for Gen1? I remember reading about counterfeit plugs somewhere.
      07-06-2020, 05:59 AM   #10
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
I used NGK 97506 on the B58, they often give misfires, a clearance of 0.5mm. Now I put 94201. The clearance is 0.5mm. I’ll go and write how they behave.
M140IX. Turbo Pure 800 Cast.
kern4174449.50
      07-06-2020, 07:40 AM   #11
kern417
Cheapskate
4450
FCP Euro. Future replacements will be free.
https://www.fcpeuro.com/products/bmw...on-12120040551
They also normally sell NGKs, but they're on backorder.
      04-17-2021, 08:13 AM   #12
Devil doc
Drives: M240ix
Bringing back this Old thread
Quick question, how did the the 97506s compared to the 94201s with the misfires? Thanks
      04-18-2021, 01:22 AM   #13
G.Newt
Drives: CT4-V Blackwing 6MT
94201 is specifically made for gen-1 B58 motors. Would go with those or OEM, not 97506, although they can work.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
kern4174449.50
      04-18-2021, 07:35 AM   #14
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Great video Kern!!! What a great service to BMW enthusiasts.
Thank you!!!
Just one question about gapping.
If my old plugs look burnt or wet, as you say is bad, how do I know whether I should try a narrower or wider gap? Is there a rule
of thumb or parameters on how narrow/wide to go for my 2016 340xi with BM3 stage 1?
Thanks!
      04-18-2021, 09:02 PM   #15
blacksapphire440i
Novice
blacksapphire440i's Avatar
303
Drives: 2018 440i Gran Coupe
What do you mean by future replacements? I bought NGK plugs from FCPEuro w/ an oil filter + 5w-30 special tec b oil. Would I send the old parts to them and they would give me a replacement?
      04-18-2021, 11:45 PM   #16
G.Newt
https://www.fcpeuro.com/page/lifetime-guarantee
kern4174449.50
      04-19-2021, 08:29 AM   #17
kern417
Cheapskate
4450
Thank you!!!
Thanks!
typically that is a tune or hardware issue. gapping plugs is to prevent misfires/blowout due to increased cylinder pressures, temperatures, etc that comes with increased hp. however our stock plugs handle more power very well without gapping.
buy new ones (same as wha tyou bought originally)
submit a warranty claim
ship back the old ones when they are removed
profit
      04-19-2021, 11:21 AM   #18
Devil doc
Drives: M240ix
From my experience I got a fair amount of timing corrections on the stock plug with stock gap, then I tried S55 plugs at 0.22 and it helped the connections at the stage 2 level, but I still had corrections; however, the corrections got really heavy at the stage 2+ Level.
Finally went back to the stock 94201s with a 0.22 gap this time, and it made a huge difference. I only saw one single small correction now.
      04-19-2021, 11:49 AM   #19
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
i told you
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
      04-19-2021, 12:25 PM   #20
Juice247
Drives: '17 BMW 440xi Gran Coupe
I replaced my stock original plugs with 23k miles on them with new NGK 94201s. Gen 1 B58. Gap at .022. BM3 stage 2+, DP, HPFP and the engine is WAAAAAAAAAAAY smoother.
'17 440xi GC THP, MPPSK, AA Catted DP, Dinan CF CAI, TU HPFP, BM3, xHP, E-Sys
      04-19-2021, 12:51 PM   #21
Devil doc
Drives: M240ix
Originally Posted by kriszty View Post
i told you
Yup! The difference is night and day
      04-19-2021, 01:21 PM   #22
blacksapphire440i
Novice
303
profit
If I wanted to do this with oil, would I just fill the old bottle with the old oil and ship it back to FCPEuro?
