10-19-2018, 09:46 PM | #419 | |
Rep 3,679
10-19-2018, 10:42 PM | #420 | |
Rep 482
Drives: 2014 Glacier Silver F30 328i
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
10-19-2018, 10:50 PM | #421 |
Rep 3,679
Well if the pressure test comes up clean and the logs keep looking like that, then there's nothing to tweak, she's running well.
10-20-2018, 09:42 AM | #422 | |
Rep 307
I’ve never done a pressure test on a recirculating valve though, I wonder if you can at least hear the leak with the recirc hose on. |
rjd_F301999.50 |
10-22-2018, 09:19 AM | #423 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-22-2018, 09:35 AM | #424 |
Rep 307
A flutter is normally the opposite of a leak, it’s the valve not opening. What opens the valve is vacuum, not pressure. Pressure is actually what keeps it closed.
If you’re not hitting boost and there are no leaks, it’s either an error in the tune of the wastegate duty cycle, or the turbo simply can’t physically hold boost. I’m betting it’s the tune if there are no leaks. |
10-22-2018, 10:00 AM | #425 | |
Rep 2,382
10-23-2018, 04:18 PM | #426 |
Rep 482
Update: Shop said no boost leak found. DV looks good to.
Ran a few more logs (suggested by the shop I went to) for PTF to analyze on the OTS Stage 2 93 map. 1. Cold start idle for 1 minute 2. Standing gradual Rev from 2k - 6.5K 3. 3 gear pull at 3K to WOT switching into 4th gear 4. WOT Auto 60-100pmh Sent logs off to PTF. Everything looks just about dialed in but they made a small adjustment in my tune. Unfortunately, I tried to flash the new map but I was getting a server error multiple times. I'm currently in queue waiting for support. LOL!
10-23-2018, 04:37 PM | #427 | |
Rep 3,679
10-26-2018, 03:46 PM | #430 |
Rep 2,382
On another note, seems I have a coolant leak somewhere. Nothing apparently obvious it seems. Takes about a month for it to generate a light. I'm thinking maybe either a bad hose, radiator, or maybe the heating element. No vapor from the tailpipe and nothing in the oil from what I can see.
10-26-2018, 03:57 PM | #431 | |
Rep 3,679
Curious because I've been noticing a bit of vapor from the exhaust, not at start or anything but when it's idling (maybe when driving, but I can't exactly tell when I'm driving the car) after it's all warmed up, or after arriving home from a drive. Very minor and dissipates immediately.
10-26-2018, 07:05 PM | #433 |
Rep 3,679
That's what I think too, I just would've thought condensation would go away after it's warmed up.
10-26-2018, 07:17 PM | #434 |
Rep 482
Update: Ran some new logs on Test Map 3 from PTF. Logs look great and holding boost! They are making a slight adjustment in my throttle angle and from there everything looks to be dialed in
10-27-2018, 01:44 AM | #435 |
Rep 3,679
Nice! Glad to hear you're all sorted out
10-27-2018, 11:41 AM | #437 |
Rep 3,679
lol It happens man. At least you've got your car back now.
10-27-2018, 10:17 PM | #438 |
Rep 482
Indeed my friend. Anyone in here running meth in their n20/26? I wonder what upgrades it would entail or if it could be done?
10-28-2018, 07:59 AM | #439 | |
Rep 307
Be careful with who you choose as a tuner. Many tuners don’t have a lot of experience with meth and either tune it poorly or try to stray you away from running meth. Meth is amazing though. |
10-29-2018, 09:09 AM | #440 | |
Rep 2,382
Also, for the coolant leak, we found it this weekend. It's leaking from the coolant temperature sensor on the radiator. Since the sensor comes with the radiator (N26 anyways), it'll have to be replaced. Finally... I get to use this CPO lol. EDIT: Also, yeah, the warning was the low coolant light. I missed the initial problem (somehow. The damn thing is right at the top) but my buddies at the shop helped me pressure test it to be sure that was the only leak. Considering it took a month to drain, we're confident that it is.
rjd_F301999.50 |
