12-04-2020, 03:08 AM | #1 |
Rep 1,240
Online Entertainment / SOS Call System Failure
A couple of days ago my Online Entertainment just randomly logged out. When I try to log back in it keeps telling me that I need an online connection to check for the rights already downloaded and it fails. In the past Deezer has had some wobbles so I just thought I'd give it a day or two to sort itself out.
This morning I got in the car and got the below error. Not good. Anyone else had difficulties? I'm hoping there is some sort of BMW comms issue. If not looks like a trip to the dealers might be on the cards. Thank goodness I took out the extended warranty.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive Last edited by Rhino at Work; 12-04-2020 at 04:37 AM.. |
12-04-2020, 03:17 AM | #2 |
Rep 941
Sounds like an issue with the onboard SIM card. Can you do an Online search in the NAV screen?
2019 640i GT MSport & 2016 X3 3.5D X-Drive MSport
Previous - 2016 530D MSport - 2016 335D Touring M Sport X-drive - 2014 335D GT X-Drive MSport |
12-04-2020, 03:37 AM | #3 |
Rep 1,240
Yes and other comms things do work e.g. after my trip this morning it has updated the map location for when I log onto connected drive. Strange.
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
12-04-2020, 04:21 AM | #4 |
Rep 941
not the SIM then, very peculiar.
12-04-2020, 06:39 AM | #5 |
Rep 475
I’ve had issues with online entertainment not registering my new voucher, called them today, they said they’ve had a country wide issue and was told to reboot my headunit and update the connected drive and it should fix it.
12-24-2020, 03:18 AM | #6 |
Rep 1,240
An update as it might help anyone else with the OE problem.
The SOS system failure error went away after a few days and hasn't returned. Strange. The OE problem is still there. Connected drive have referred it to technical - they said it could take up to 6 weeks to resolve! It's been nearly 3 so far. I know of at least 1 other person, via the Deezer online community, who has the same problem. I have found a workaround though. If when listening to a song on the radio you use the connected music command (or whatever it's called) to look up the song then once it's done that you can select one of the options (eg play album for track) and it will take you into OE and it can be used as normal from there but only for the rest of your journey. Once the car goes to sleep it forgets.
12-24-2020, 03:37 AM | #7 |
Rep 14
Hi Rhino.
I am having a very similar issue. I cannot use the OE, I get a message "An Online connection is required.****.check the rights for ** etc" I have reset the idrive, reset the OE, Updated the BMW services but still cannot use the OE. BMW online are next to useless with their help, takes four days for a response, mine has been like this for around three weeks now. If I get an answer that works I will post it here, but please keep us updated in case yours is resolved first. |
12-24-2020, 03:43 AM | #8 | |
Rep 1,240
12-24-2020, 04:51 AM | #9 |
Rep 475
Mine started working a couple of days after Bmw Uk referred it to Germany, my main Deezer account wasn’t having it so had to set up a new one which got me up and running.
Deezer were useless they kept saying that Bmw doesn’t support Deezer anymore and the only way I could use Deezer was via carplay, I tried to explain the online entertainment but they were not having it! |
12-24-2020, 05:43 AM | #10 | |
Rep 379
12-25-2020, 12:16 AM | #12 | |
Rep 663
Current:
BMW X4M Comp, BMW 335d LCI |
01-22-2021, 02:52 AM | #13 |
Rep 1,240
Just as an update the Online Entertainment "check the rights" issue finally seems to have been resolved and it's back to normal today.
01-22-2021, 11:51 AM | #14 |
Rep 276
Any further thoughts on the SOS Call System Failure issue? My theory is that there's a back up battery for this system and as I only move the car for the weekly shop now, in this cold weather the battery is depleted and therefore the warning?
The first time I saw this warning was from a recent cold start. I ignored it and drove on, then decided to park up and pressed the button in the headlining to test. I got connected. So the warning was false, and the driving had charged the system battery sufficient to enable the call. |
01-23-2021, 05:25 AM | #15 | |
Rep 1,240
I actually need to do some miles this coming week for work so will see if putting some juice back into the battery has any impact on whether or not the error keeps appearing.
01-25-2021, 08:56 AM | #16 | |
Rep 56
I had the same issue with my 520D G31, once I started using the car on a regular basis the fault initially became less frequent until eventually it stopped altogether. Like you I assumed it was a charging issue. The work involved in the G31 battery replacement involves stripping out all the headliner. I was pleased I cancelled the car going into the dealer as I may have ended up with rattles after the fix. |
01-29-2021, 01:55 AM | #17 | ||
Rep 1,240
01-31-2021, 06:44 AM | #18 | |
Rep 276
This thread talks about a ACCUMULATOR (battery) issue: https://www.bimmerfest.com/threads/e...#post-13500845 |
01-31-2021, 08:18 AM | #19 | |
Rep 1,240
I found a video of the fix but there's no way I'm going to be doing that! Hope to goodness it's covered by the extended warranty.
