02-15-2020, 03:37 PM | #1 |
Rep 9
F30 340i over M235i?
Hi all, currently deciding between a 340i (RWD) and M235i as a DD (commute ~10 miles one way). I plan on getting BM3 Stage 2 on either car.
(1) Will I need to replace the turbos on the M235i if I'm looking for 400bhp? I know upgraded FMIC/DP is required, but wasn't sure about turbos if I'm 'only' looking for 400bhp. (2) The main differences are the adaptive suspension on the M235i versus the 704 fixed MSport suspension on the 340i, plus the 340i has some additional tech goodies (BSM, side/top view cameras). I know it's an odd matchup as it's comparing the sedan against a coupe as well as B58 versus N55 tuning. Am curious which you think would be more fun as a daily driver--any thoughts would be appreciated, thanks! |
02-15-2020, 06:11 PM | #2 |
Rep 35
I know your situation is a little different but i went with a 435 over 235 because of my size, 235 was a bit tight for me to drive everyday although I would say it is probably a little more fun to throw around because of it's smaller size.
02-15-2020, 06:38 PM | #3 | |
Rep 1,597
02-15-2020, 07:00 PM | #4 | |
Rep 9
Noted, afaik the B58 only needs the DP to be changed for BM3 tune; people seem to be doing fine with the stock heat exchanger even on stage 2(?) |
02-15-2020, 07:22 PM | #5 | |
Rep 1,597
02-15-2020, 08:01 PM | #6 |
Rep 9
02-15-2020, 09:50 PM | #7 |
Rep 233
I'd lean towards the M235 if you don't need the rear seat space to haul kids or coworkers or whatever. Smaller is almost always more fun for handling and the N55 is still a great engine. The 1/2 series was always the car I really wanted (but then I had a kid).
However the 3 series interior is noticeably better, and having blind spot monitors and top/side view cameras is quite nice. I use the top view cameras daily for backing into spaces and pulling into garage. And if you care more about raw power, the B58 is definitely the way to go. |
02-15-2020, 10:15 PM | #8 | |
Rep 9
I do plan on tuning whatever car I get, so I think they'll end up at relatively similar levels still. |
02-16-2020, 01:09 AM | #9 |
2JZ-GTE
3146
Rep 4,112
B58 for the win
02-16-2020, 02:29 AM | #10 |
Cheapskate
4522
Rep 5,003
340i. More power, quicker spool, cheaper to mod, more reliable, plus the creature comforts you mentioned in optioned upgrades.
340i, adaptive suspension, comparison, f22, f30, m235 |
