11-16-2021, 04:21 PM | #89 | |
Rep 72
They want insurance involved. Geico adjuster doesn't respond. |
11-16-2021, 05:36 PM | #90 |
Rep 4,876
Even if the rotors are rusted, that won't impact anything until you apply the brakes. Sounds like the BMW dealership is either doing a cop out or trying to get you spend more money there on a brake job.
11-16-2021, 06:37 PM | #91 | |
Rep 6,239
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Agreed
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
11-18-2021, 08:30 AM | #92 |
Rep 72
Well.. BMW says it's the cause and all 4 rotors must be replaced. I feel like I am dealing with scammers. I don't know how we come to this point. We have been trying to reach my adjuster for 6 days now. I called Geico again. We are trying to reach to his supervisor now. BMW says Geico might approve the replacement, won't hurt to ask...
11-18-2021, 09:19 AM | #93 | |
Rep 234
11-20-2021, 11:47 PM | #94 | |
Rep 5,089
My guess is that warped rotors can cause vibration at highway speeds, but insurance probably won't pay as those are supposed to be maintenance items. Is it possible to take car to a reputable mechani for post-repair inspection? |
11-21-2021, 10:09 AM | #96 | |
Rep 72
11-21-2021, 10:10 AM | #97 |
Rep 72
11-21-2021, 11:31 AM | #98 | |
Rep 5,089
How many miles are on the current set of pads + rotors? How long have u owned the car, and during your ownership, have u noticed any highway speed humming/shaking and cricket sounds? |
11-21-2021, 12:12 PM | #99 | |
Rep 72
I bought the car 5 years ago at 16k miles, current miles is 42k. According to the computer of the car, (I am not sure if the front or back brake sets but) one of the set had 2k miles left, other had 9k miles left on them. I didn't replace the brakes during my ownership. I don't know if/when previous owner replaced them. I didn't notice any shake or noise before accident. Mind you, the cricket noise doesn't happen under breaking, in fact sound goes away if I touch the brakes, comes back if I release the brakes. Also, oil changes are done at BMW dealerships only. They claimed to inspect the brakes each oil change I had in the past and they never mentioned anything about them. Last oil change was at the same dealership in August. Let's assume it's the rotors causing the issues as BMW says, would the problem (rust) go away after couple hundred miles of driving/braking? |
11-21-2021, 01:41 PM | #100 | |
Rep 5,089
Cricket sound going away seems to imply it is not warped rotors(which should cause more noise when brakes are used).
Were the rotors removed during repair? If so dealer should really doublecheck on the reinstallation(e.g. any missing anti-seize/brake grease?). Quote:
11-21-2021, 05:36 PM | #101 | |
Rep 72
I am planning to make them say via text messages that the issues with the car is happening because of the rusty rotors and not the suspension parts that were replaced. I just want some sort of legal protection if the wheels fall off. I just hope the noises will go away. They tried to give the car back to me in that condition twice already. I don't think I can make them fix the car anymore. I tried everything. And maybe they are right. |
11-21-2021, 08:55 PM | #102 | ||
Rep 500
11-22-2021, 10:02 AM | #103 | |
Rep 72
Anyway. Computer says front brakes have 8k miles, rear has 1800 miles left in them. I will driver the car like this and hope to see problems go away. If this makes me uncomfortable I will take it to independent to see what's wrong. Can a brake/rotor go bad and need replacement after a certain year even if it has 8k miles left on them? |
11-22-2021, 11:09 AM | #104 | |
Rep 5,089
The definite criterion to replace BMW pads is 3mm or less. The BMW brake wear sensor has 2 contact points, the first one can trip ahead o 3mm, while the 2nd one does trip(make contact) at 3mm. The definite criterion to replace BMW rotors is min. thickness stamped on the brake rotors, if above that min. thickness, u can throw on a new set of pads(and wear below min. thickness). The caveat here is that once below min. thickness the rotors can vibrate even pads are above 3mm. Also the thinner the rotor, the less mass to take up heat, so brake fluid can heat up quicker and become less effective. Enjoy your renewed ride! |
adilakif27.00 |
11-24-2021, 03:50 PM | #105 | |
Rep 72
My advisor quoted me $900 for front brakes pads and rotors. I just looked up BMW VALUE SERVICE and Wayne BMW is offering the same job for $422.95. Am I missing something here? https://www.paulmillerbmw.com/bmw-value-service.htm View post on imgur.com |
11-24-2021, 03:56 PM | #106 | |
Rep 5,089
E.g. our local dealer quotes $150-$200 everyday low price for oil change. But when they sign up for value service pricing, BMWNA's corporate price (per zip code) can be $90-$100. At times BMWNA coupons can drop that price to $50-$60(out-the-door), which is cheaper than best on-line price for parts-only! If you don't have the value service price on hand, my local dealer will charge its $150 and up. |
11-25-2021, 06:24 AM | #108 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
It’s been a long and bumpy ride here OP. Go for the brake job value service and see if they can do a complimentary inspection for you.
09-03-2022, 08:08 AM | #109 |
Rep 72
Hi again. Almost a year after this accident, I am at the dealership to change the brakes and they noticed my Thrust arm bushings are leaking (Lower control arms bushing). Video shows black color on both bushings. Can this be related to the accident I had? If so, can I get this done via insurance year after the accident?
Video: Last edited by adilakif; 09-03-2022 at 08:50 AM.. |
09-03-2022, 12:06 PM | #110 | |
Rep 1,199
Also stop taking this car to the dealer. Wtf are you doing? Find a decent independent mechanic who won't charge you absurd labor rates for easy jobs.
