08-17-2016, 07:36 PM | #1 |
Rep 488
Finally got to dyno my ActiveHybrid 3 (with mods)
Got some interesting results, the highest one being 361.69HP and 376.83TQ (at the wheels) with some interesting curves. This is with a JB4 on Map 5, Meisterschaft GT cat-back, Dinan CF intake, & ER chargepipe. Haven't found many other AH3 dyno runs to compare, does this sound approximately correct?
08-17-2016, 09:46 PM | #3 |
IG @bmwF9xG80
3813
Rep 7,593
So no runs on map4 ? which is your baseline (stock) to see your delta
Dynos are pointless without before/after since thats all they will display (gains). Also try to get your Dynos together in 1 graph Power/Torque Dont mean to come off wrong but thanks for posting your dyno Example..
60-130mph 6.5s X4M #HCP
08-18-2016, 04:42 AM | #4 |
Rep 1,291
We've got a thread here on the topic: http://f30.bimmerpost.com/forums/sho....php?t=1279227
We think we can get 400hp, frackje is getting a stage 1 reprog sometime soon, I might be next
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
08-18-2016, 10:52 AM | #5 | |
Rep 488
08-18-2016, 11:00 AM | #6 | |
IG @bmwF9xG80
3813
Rep 7,593
Some ppl that are anal, get 1hr or 2hr of Dyno session for a negotiated rate. - 3 pulls on stock map0 or map4 let car cool off for 10-15mins - 2 pulls on map1 ; cool down 5-10mins - 2-3 pulls on map2 ; cool down 5-10mins - 2-3 pulls on whatever other map u want 5/6/7
08-18-2016, 12:21 PM | #7 |
Rep 115,980
Numbers seem reasonable although next time also record a JB4 log so you can check the vitals. I'd be curious to know the boost levels.
Mike |
08-18-2016, 02:51 PM | #8 |
Rep 190,730
Numbers are good but i recommend you always do a stock run first to get a better idea of the gains and always datalog your dyno run
08-22-2016, 01:47 AM | #9 |
Rep 931
afranke you remember your psdzdata - software intalled on your car ?
mine is 3.59.3 August 2016 (The last)
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
08-22-2016, 02:27 AM | #10 | |
Rep 931
12-28-2016, 09:24 AM | #11 |
Rep 931
12-31-2016, 08:23 PM | #12 |
Rep 488
Just got it back from the install of a Pure Stage 2 with all the goodies. Gotta tune in the methanol injection a bit, and then another dyno. Should be fun, since I have everything on it except a built motor and ECU flash since nobody is willing to touch the hybrid (so far....working on some things). How does the Dinan thing compare to a JB4?
01-01-2017, 05:48 AM | #13 |
Rep 931
Dinan stage 1 - 2 - 3 it'a a real piggy
bypass a lot of sensor from MEVD17.2 ECU to all Engine. It's great ecu tuning solution Jb4 it' a classic map-tmap bypass with a simple processor like a commodore 64. But i don't know real performance of dinan in 335i or hybrid 335i On the paper seem the best
01-01-2017, 07:56 AM | #14 | |
Rep 4,515
I'd be inclined to dyno the car in the map you want measured having driven the car for awhile in this map. Once done then switch to map 4 to get baseline dyno. |
01-01-2017, 10:00 AM | #15 |
Rep 6,990
Those extra 300 lbs. need the extra HP, but I suspect equal hp figures could be attained on a non-hybrid 335 with similar modifications.
01-01-2017, 12:19 PM | #16 | |
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
01-01-2017, 07:54 PM | #17 | |
Rep 488
I need to install my N20 TMAP sensor, mix in some E85, and some tuning to the meth injection, and then I'll dyno again. Good point made previously about DME adaptives, I didn't even think about that. |
01-02-2017, 04:46 AM | #18 |
IG @bmwF9xG80
3813
Rep 7,593
I like PURE RAW figures without adaptation lol so I dyno'ed map4 with datalogging first then map1 and then 2 on 93.. When i did the E30 dyno I was driving in map2, then went to map7 (1 pull) then back to map1, map4 so it was adapted for 50 miles prior to dyno.
Now time to dyno Bootmod3 afranke map3 meth map?
01-02-2017, 05:21 AM | #19 |
Moon Parasite
654
Rep 1,336
Pflugerville ? I'll have to keep an eye out when I'm back running around down there again. Can't be too many AH3s driving around, especially modded.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
01-03-2017, 11:00 AM | #20 | ||
Rep 488
FSociety3812.50 |
01-03-2017, 01:39 PM | #21 |
Rep 488
Just ran another dyno on Map3 (methanol map, using Boost Juice 50/50 meth/water) with 50/50 of 93 octane and E85, and managed a very consistent 455HP to the wheels. Based on the data, it looks like I'm lacking in the fueling department, so I may up the meth mixture/flow and/or look at a Fuel-It rail. Only at 16psi currently, so there is tons of room to play.
01-03-2017, 01:51 PM | #22 | |
IG @bmwF9xG80
3813
Rep 7,593
same dynojet ? how much torque ? for only 16psi if its 455whp with 50/50 meth mixture and 93 + e85 thats very good can you post the graph?
