04-10-2024, 08:09 AM | #1 |
Rep 71
Bad fuel rail pressure sensor?
Hello
Looked around the net and could not find a definitive answer. When reading fuel rail pressure live data on idle the values go up and down sporadically between 27000-30000 kPa (270-300 bar). Is this normal or should the value be at a stable number? MAF sensor seems to follow the pattern as it also jumps from 10-25 g/sec. Car feels as if low boost or lower power on low rpms. Stage 2 with DPF removed. I assume that it is not remap related as the car has been working fine after remap, but these issues started recently. MAP, MAF, IAT sensor cleaned no difference. No boost leaks, smoke test done. Thanks
10' 120d Stage 2 250 hp & 500 nm
18' 320d Stage 1 235 hp & 460 nm |
04-26-2024, 09:09 AM | #3 |
Rep 71
The n47 has a quantity control valve and a pressure sensor on the rail. Do you know how to troubleshoot this and single out the failing part. The quantity control valve is an expensive item.
edit: Sorry i was misinformed. There indeed is a pressure regulator and pressure sensor on the rail. The quantity control valve is on the pump.
18' 320d Stage 1 235 hp & 460 nm Last edited by armend195; 04-26-2024 at 09:13 AM.. Reason: i was wrong |
04-30-2024, 07:48 AM | #4 | |
Rep 71
What could cause that? Maybe when cranking it with sensor unplugged there was a raise in pressure that made the car feel more powerful the first minute? Or maybe the car ran good until the fuel rail pressure sensor values started to differentiate? Thankful for any input. |
04-30-2024, 07:50 AM | #5 |
Rep 71
Is there any sensor i can unplug to see if the pressure normalizes? For example unplugging the pressure regulator and see if the pressure is stable or if there is a difference?
05-06-2024, 07:32 AM | #7 | |
Rep 71
As i see it its related to the MAF. Changed MAF, IAT no difference. Unplugging MAF no difference. Car still rough, hesitant and jerky. Took some screenshots of the live data. The rail pressure gets longer and more erratic low spikes as temperature gets higher.
05-07-2024, 05:19 AM | #8 |
Rep 871
Given your MAF is is a primary device to control fuelling, i would probably rule out the fuel rail itself and look towards what is causing your wonky MAF readings.
I would get a graph of the following sensors, plus a graph of the "MAF Setpoint/Requested". If the setpoint is all over the place, it will likely be one of the second list. If the setpoint is stable, something is directly affecting the MAF reading itself. Directly affected: EGR: If the valve is fluttering open/closed it will cause the MAF air-flow to fluctuate MAF Itself (you've changed) MAF Wiring Air leak (i know you've smoke tested, but the PCV could be bad?) Indirectly Affected (i.e. this would affect the calculation for the MAF setpoint): Accelerator sensor O2 Sensor readings IAT Sensor (you've changed) MAP Sensor |
05-07-2024, 01:12 PM | #9 | |
Rep 71
Thank you very much for the info. When unplugging MAF, the pressure does not change. Does that not rule out that MAF is not issue? I mean, when MAF is unplugged, the car runs on like a basic map or values? But the pressure still spikes like in the photos. Car is stage 2 with removed DPF and i assumed o2 sensors were issue, went to tuner and removed o2 on new flash. Shows 0.0V when reading etc. Made No change at all, even after unplugging. MAP sensor changed, no difference. What could be faulty with PCV? I’ve changed tube that cracks, the breather pipe that goes into the intake next to the turbo. Also changed the springy type thing that sits next to the oil filler cap/injectos, thats also part of PCV. What else could it be? Seems like the car behaves like this 8/10 times. Sometimes it just runs normal plenty of power, smooth and low fuel consumption. I read a long time ago about the accelerator sensor, and maybe i’ll give it a shot. Is it a way to diagnose this with live data? Or should i just go on and purschase used one and change? And just to double check, i’ll attach a photo. Is it this complete one? Thank you very much for the input and help! |
05-07-2024, 01:13 PM | #10 |
Rep 71
05-07-2024, 01:32 PM | #11 |
Rep 871
The accelerator position is loggable so I would just look to log it on your next drive.
If you're still seeing the crazy readings on the fuel rail with the MAF unplugged, I would try graphing as many other sensors as possible to see if any correlate. |
05-09-2024, 02:21 PM | #12 |
Rep 56
MAF is used to limit fueling so the car does not smoke. It's not directly responsible for fueling.
Those sensors and regulators are not that expensive. You can use bosch or pierburg sensors, no need to buy BMW original. It's impossible to tell anything according to your logs because there are no reference points. Your remapper should be able to log it and see what's wrong. Unless he's just a guy who just flashes software... It's impossible to be 100% sure about fuel system components because they affect each other. There is a possiblity of making a better guess but that would involve logging all the necessary data points. I highly doubt it's your accelerator pedal but you can log the values at standstill. There are 2 sensors integrated in 1 assembly and there is a crosscheck to see if the values drift. If you still have EGR then you should try blanking it. |
05-13-2024, 03:35 AM | #13 | |
Rep 71
First off, thank you for your input. Logged both absolute pedal position sensors and they seem fine. They both sit at steady 14% on idle and seem to be reacting accordingly to my pedal input. My tuner looked into it and gave me same advice as you, try to change these in this order: - fuel rail pressure sensor - fuel rail pressure regulator - fuel quantity valve on hpfp I just ordered rail pressure sensor and will change it to see if it makes a difference. EGR assembly is completely removed from engine. Smoke test done, no leaks.
05-17-2024, 01:08 PM | #14 |
Rep 71
UPDATE
Changed fuel pressure sensor - no difference Was also advised to change coolant temp sensor just to rule that one out since a faulty one can cause hidden issues etc... Went back to tuner to double check the remap, he tweaked around a little, even put on a lower output map and we even went back to stock figures but still no difference in pressure. Car seems very jerky and slow-ish in low rpm's. Higher fuel consumption. But WOT is fine, full power. Only part throttle issue. Next is to change rail pressure regulaing valve on rail.
05-18-2024, 03:56 PM | #15 |
Rep 871
I am no specialist or mechanic, but I honestly have no idea why anything on the Fuel Rail would cause the MAF readings to go haywire - I'm not sure why a tuner is suggesting that. The MAF will be one of the sensors that contributes to the fuelling. If the MAF sees an air mass drop, the fuel will be commanded to be reduced; not the other way around.
The reason why the car is fine on WOT is could be because it goes into 'open-loop' mode when you gun it. The ECU goes from using real-time O2 sensor data to long/short term fuel lookup tables as the car knows it needs to run rich. It could potentially be a faulty O2 sensor causing the EGR to keep turning on/off? Have you measured these sensors? |
05-20-2024, 04:09 AM | #16 | |
Rep 71
EGR is both physically removed and mapped. O2 sensor is also mapped OFF, shows 0,0V when logging. When unplugging MAF there is no difference.
05-20-2024, 04:21 AM | #17 |
Rep 71
05-20-2024, 04:49 AM | #18 |
Rep 71
If more/other sensors need to be logged please tell me.
I'll even compensate the person who helps me find the issue
05-27-2024, 03:00 PM | #19 |
Rep 71
Better selection of sensors:
WOT 4th gear: https://datazap.me/u/armend195/fuel-...r?log=0&data=1 Driving part/light throttle: https://datazap.me/u/armend195/fuel-...e?log=0&data=1 Cruise control set speed: https://datazap.me/u/armend195/fuel-...og=0&data=1-17 I included the swirl flaps actuator (%). The swirl flaps are mapped out should there still be movement in the datalog?
05-28-2024, 08:37 AM | #20 |
Rep 871
So these logs are just a few seconds each... Was the car exhibiting the symptoms at the exact time they were taken?
Agree your swirl flaps are all over the place on every run - it almost looks as though they are cycling open/closed every few seconds. A standard or disabled car shouldn't be exhibiting those symptoms. The swirl flaps would also likely affect your MAF and Fuelling readings. If they have only been disabled by the remap, i would look to unplug the actuator (i dont even know if thats possible?) |
05-28-2024, 11:17 AM | #21 | |
Rep 71
Yes the same symptoms when logging. The swirl flaps actuator is unplugged thats why i find it weird that it goes up and down when logging |
fuel, fuel rail, pressure, rail pressure, sensor |
