07-13-2019, 08:00 PM | #45 |
Rep 2,957
Anyone have thoughts on 1 piece vs 2 piece rotors for 100% street use? Is it worth the money for 2 piece?
08-09-2019, 12:09 AM | #46 |
beamymike
Rep 36
Thanks for the write up @[Daggers]
I am looking to replace my pads in the next couple of months. I have a 2013 328i. I am abit confused about the rear brake pads. I have been told different stories. Can i leave the car in P with the hand brake up to change the rear pads. I have been told i need a computer to override to release the brake pads or is this not true? Can someone please confirm. |
08-09-2019, 07:52 AM | #47 | |
Car Hypochondriac
335
Rep 901
08-09-2019, 10:39 AM | #49 |
Rep 86
BMW Dealership quoted me almost $2k to replace all 4 rotors and brakepads...
I decided it was time to learn to do it myself and save $1.3k Did it myself last weekend thanks to this DIY guide. My first time changing brake rotors/pads/sensors on any car....took me 6 hours from jacking up the car at 2pm to finish bedding the pads at 8pm..... and this was for just the two front rotors.... (I did spend an hour at home depot because I had to buy a pick tool to get the pins out) But then again it was my first time and I was doing it by myself with limited tools, so I kind of took my time to make sure everything was done right. Now I think the 2 rear rotors/pads will probably take me 3-4 hours this weekend. Also for the others reading this thread, do not forget to pump the brakes a few times after putting the brake fluid cap back on. I nearly panicked and thought I did something wrong when there was no bite when I first started the car.... |
wdeerfield2745.00 rambalu8078.00 |
08-09-2019, 05:16 PM | #50 |
beamymike
Rep 36
thanks heaps for the advice beamer fambam
Now i just have to wait 3 weeks for the pads to arrive because its on back order. Gives me enough time to get all the tools ready haha Excited to start working on my first eur car |
08-21-2019, 12:35 PM | #51 |
Rep 23
Scratching noise
Thanks for the write up very helpful!
Got the fronts done no problem, the rears all went fairly easily (minus a stuck lug nut) But it appears both of my rears are now making a scratching noise as the wheel rotates. I cannot pinpoint what this is has anyone encountered that? The noise goes away when the brakes are pressed, but when driving at ~30MPH it becomes apparent. |
08-21-2019, 05:18 PM | #52 | |
Rep 293
08-22-2019, 06:03 AM | #53 |
Rep 23
09-24-2019, 03:54 PM | #54 |
Rep 2
Which discs do I buy?
Tried entering my Vin at https://www.mdecoder.com/decode/ and it didn't point me in the right direction.
Also entered in the Vin in Realoem.com and get the following back: https://www.realoem.com/bmw/enUS/sho...diagId=34_1949 From what I can see on the car it's a BMW F30 Sport, 184bhp and it has blue calipers. Can anyone help me identify which brake discs and pads I need? Thanks, PS is it okay to post my VIN? |
04-04-2020, 10:20 PM | #56 |
Rep 5
Thank Daggers. Nice post.
I have 1 concern. I am going to change my brake pad. Waiting for the tools to be arrived. For the from caliper seems we can get some space as we can adjust the steering wheel. I am thinking how much space we have to the rear ? Do we have enough space for using a torque wrench which is approx. 18.3". Thank you Last edited by Ryan_Tran; 04-04-2020 at 10:35 PM.. |
04-05-2020, 10:31 AM | #57 |
Rep 133
Drives: F32 435dx
If you already get the maintenance warning message, that means the sensor is already worn, so you have to install a new one. You can save the sensor only if you change the pads before you get the warning message.
04-05-2020, 10:46 AM | #58 | |
Rep 133
Drives: F32 435dx
After you finish the installation of the new parts and pumping your brake pedal, you forgot to mention that we also have to reset the on board computer through the secret menu using the trip distance reset button on the dashboard. Other than that, thanks for the time to write all this up! |
04-13-2020, 03:27 PM | #60 |
Rep 3,752
04-13-2020, 05:41 PM | #61 | |
Rep 128
I’ve only changed the sensor twice in my life as I’m generally well in advance of lad wear with my routine maintenance. |
05-21-2020, 12:58 PM | #62 |
Rep 425
A couple things that might help others as I now have time on my hands to get them dirty! Changed my front pads last wknd for the first time ever. Youtube vids make it look easy.
Took the better part of a day trying to figure out how to get the calipers off the rotor. Once the 2 18mm bolts came off, the caliper did not slide off the caliper like all the vis show leading me to believe that there was something hidden that I was missing. Even some encouragement from a hammer didnt help! If the rotor is even a little worn, there's a lip on the outer edge that the old pads wont clear. Had to pry the pads away from the rotor with a screwdriver. Boom! That was the biggest hurdle. My C clamps werent big enough to push the piston back in. Autozone up the street has loner tools, Caliper tool, to use for free. Great resource. Last thing, not a lot of clearance for a breaker bar in the wheel well. Use your smaller ratchet and a few taps to the handle with a rubber mallet should get it started. After all this, next time should be take me 90 minutes tops. Easy. |
05-23-2020, 07:45 PM | #63 |
Rep 3,752
So far i heard that the first time changing brands pad or rotor... those bolts are hard to remove. BMW factory tightened it so much... so the advice is to plan with a little extra time.
08-04-2020, 01:07 PM | #64 |
Rep 525
i thought i'd add to this just for anyone else...
the job is super simple.........UNLESS you have a fu*kin corroded/seized rotor screw. Which as it turns out is a really common problem after looking at youtube. It has been a ballache to get it out, after watching a ton of youtube vids i tried a hex head remover kit (useless), then a M8 spline bit to hammer in, ended up rounding it off even more. I then tried a bolt extractor set - and turning it with an adjustable wrench. Didn't work, mainly because the thread is so seized that you just ended up rotating the hub round even if you try holding it with your other hand. in the end the only solution was to drill it out. That involved first removing the head. drill a pilot hole, using cutting oil, then keep going up in 0.5-1mm increments. I started with the head and stripped that off - that allows the disc to come out. Then have to keep going with the thread stuck inside, 2, 3, 4, up to about 7.5mm. Luckily the thread in the hub was still intact and i could put in a new rotor screw. Chances are if your car is 3 years old or more and subject to british weather, these stupid screws have corroded in, and the moment you try untightening them with a 6mm hex, you'll round off the top just like i did. Anyway, the lesson is - addendum to the OP: - before you remove the brake pads - use a pipe to hold some brake pressure wedged against the seat (or get someone to push the brake pedal) - and try and get the rotor screws out first before doing anything else. once they're out (about 3 days of running around chasing parts and solutions)...the rest takes about 20 minutes tops. i used autodoc for the brake pads and discs (brembo + zimmerman zcoat) - usually always discounts on, and with the Zcoat you don't have to mess around cleaning the rotor. to save future hassle, ECS tuning and turner motorsport do stainless steel screws which don't corrode, but its in america and to order a set of 4 in the UK is £30. In addition - if you don't have an EZjack like the OP and you're working with axle stands like us poor folk - it is worth getting the front of the car high up, just so you can get the torque wrench into the right position to correctly torque up the new caliper bolts. I also replaced the bolts/rotor screws with new ones as per ISTA instructions. Which was also annoying because i guess after 2016 BMW started using Torx head, not normal 6 point, so i had to buy an appropriate socket set. Last edited by gippy; 08-04-2020 at 01:13 PM.. |
08-04-2020, 02:45 PM | #65 |
Rep 128
Easiest thing to do in that situation (if you’re replacing rotors anyway) is to simply grind the head off the screw. If you leave the screw “shaft” in place, or not, it doesn’t matter. The new disc is held in place by the wheel bolts anyway. That screws job is just to stop the disc rotating as you put the wheels on (to make it easy to align the wheel bolts / disc / hub). So if you leave the stub of bolt there for the replacement disc, you’ll be lined up still. The screw is basically useless anyway!
08-09-2020, 09:35 PM | #66 | |
Great Teacher
1082
Rep 1,304
Drives: 06 e91 325ix
I drilled one out with a big bit, and such was the case once it was done.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
