08-03-2021, 11:58 AM | #4137 |
Rep 27
Waiting Kri to release notes from 3.0.8.
I'm on 3.0.5, so far so good until now. |
LittleSamurai4.50 |
08-03-2021, 12:38 PM | #4138 |
Rep 2,366
Drives: E63 645Ci
I love how people are eager to update but no one is actually willing to test it out or put some effort and decompile to source to see what's new... always has to be kri 🙄
08-03-2021, 12:41 PM | #4139 | |
Rep 2,366
Drives: E63 645Ci
08-03-2021, 12:46 PM | #4140 | |
Rep 27
Have a nice day |
08-03-2021, 02:21 PM | #4141 | |
Rep 1
I have firmware 3.0.5 and it works. Choose 720 or 480. Do you know your resolution? https://mega.nz/folder/NNxk0Z6S#876H...older/gAAiFL4Y Last edited by szczepan; 08-03-2021 at 02:44 PM.. |
08-03-2021, 02:56 PM | #4142 |
Rep 2
Hi,
I recently installed one of these units, albeit in an e90. Software shipped seems to be 3.0.5. Everything is fine for the most part but I have a couple of questions and this seems the best place to ask... 1. I've had a couple of people complain my voice (over bluetooth when connected) is garbled, not the background noise etc but more of a scrambled audio noise. Wondering if there are some other bluetooth options via developer settings that might improve it? 2. Has anyone managed to get internet tethering from an iPhone over bluetooth working? Most of the usual android bluetooth options are missing so not sure if it's possible without rooting etc? 3. Any way to change the other of some of the options from the main menu, or even remove them? For instance I have no need for the music or video apps so I'd rather them out of the way or gone completely from the home screen. Maybe something to do by editing the theme? Thanks |
08-03-2021, 03:09 PM | #4143 | |
Rep 11
I'm running app version 2.6.7, not sure if that has anything to do with this? Steve |
08-03-2021, 03:56 PM | #4144 | |
Rep 13
I tried to install version 2.3.5 but always the same. I’m waiting for my vendor and will try older version and mcu update. I think that i was in 480. |
08-03-2021, 03:57 PM | #4145 |
Rep 2,366
Drives: E63 645Ci
I appreciate what you do, I really do. But my comment was more of a general observation. Same people answer some questions over and over again, same people doing hard work so other don't have to. Just wish there was more balance in the Force.
08-03-2021, 04:41 PM | #4146 | |||
Rep 2,366
Drives: E63 645Ci
You're welcome. |
08-03-2021, 11:49 PM | #4147 | |
Rep 1,048
Maybe by the end of this week. Kri |
LittleSamurai4.50 |
08-04-2021, 02:14 AM | #4148 |
Rep 4
Very keen to get one of these but hesitant on having a non-factory unit. Do you guys think it is worthwhile to upgrade the head unit or get an MMI module, or just have a smartphone mount off on the side? Wouldn't want to spend so much time and money to have it fail
08-04-2021, 04:12 AM | #4149 | |
Rep 220
Drives: MINI Cooper, 2020 X1
08-04-2021, 10:22 AM | #4150 | |
Rep 13
So i have tried reinstall version 2.6.7 recommended by my vendor and it's still ok. Many thank for your help. Perhaps MCU up to date is better for update version. I hope that this version improve the many bug i have with 2.3.5 at start (screen blocked on splashscreen or black screen). And i have to find IGO apk... |
08-04-2021, 03:08 PM | #4151 |
Rep 105
Hi guys, I have e82 135i with Navifly Android Headunit, I see a lot of support on f30 forum.
I have no sound after I cut my factory GPS antenna and extended it to plug it to Android Headunit instead of Oem headunit. Will cutting factory GPS wires can cause no sound? I thought it wasn't related to sound. I had sound before I rewired to android unit. Any one know if it cutting oem gps wires related to that? |
08-04-2021, 03:31 PM | #4152 | |
Rep 2
Thanks for your responses. I’ll try and source another/better mic. I had seen the custom launcher by Nick, so I may give it a shot. |
08-04-2021, 07:03 PM | #4153 | |
Rep 2,366
Drives: E63 645Ci
Btw. why cutting OEM cable?! Just why?! You could have bought an extension with male and female connectors.... |
08-04-2021, 10:42 PM | #4154 | |
Rep 105
I have no use of old factory CCC system Navi super slow and old, so I thought why not just extend the oem gps wire while I was installing the Android unit. But extending didn't work for some reason IGO says looking for GPS like there's no signal. |
08-04-2021, 10:50 PM | #4155 |
Rep 105
I have couple more questions
1. is this true android auto works only works wired for Android phones, and apple works wirelessly according to my seller 2. Sound quality is not crystal clear compare to oem, I would say it's 90% clear with slight distortion, after doing some research looks like sound restorer should fix it. 3. When switching to OEM screen music stops playing, any possible fix for that? After doing some reading here seems like no solution. 4. Any possible solution when connecting to Bluetooth to automatically start playing. 5. IGO does not have North America maps. Sorry if I asked too many questions at once, I probably have read 40 pages here but haven't read all 190 yet, I will probably find my answer here, I appreciate the answer if anyone can provide. Last edited by N54andS63TU; 08-04-2021 at 11:15 PM.. |
08-05-2021, 01:58 AM | #4156 | |
Rep 13
Thought I might have solved it when I learned there’s a Carlinkit box with its own mic, but apparently mine does not. Looking at my original wiring, the mic input to the SD625 is listed as “optional”. How do I make sure this input is being used in settings? Are there any other input sources it could be using, buried behind the dash somewhere, other than the OEM NBT mic? Could it be using my phones mic somehow? If I don’t use CarPlay/Carlinkit box, the SD625 BT mic sounds fine. Played with the various options in the Autokit app, nothing helps. Last edited by schooleydoo; 08-05-2021 at 02:03 AM.. |
08-05-2021, 11:11 AM | #4157 |
Rep 23
Anyone having problem with playing Spotify?
These few days Spotify often not playing after turning on the car The play button showing that the song is playing but no sound on If I try to fiddle with the KSW sound restorer (start or stopping the services), which I almost never did because never have problem before. It just result in the sound restored but sounds like from a cheap mono speaker. Like not all the speaker working |
08-05-2021, 02:00 PM | #4158 | |
Rep 2,366
Drives: E63 645Ci
