08-25-2021, 05:06 PM | #1 |
Rep 445
Meyle Tension struts popping
Did/does anyone have experience with these tension struts making a popping noise? I only have it happen at very low speed and mainly reversing at near full lock. Parking basically…
I verified the torque measurements and installed at ride height, so I'm a little surprised to still be dealing with this. Thanks for any help |
08-27-2021, 12:12 PM | #2 |
Rep 1,571
Bit strange. As long as you torqued everything to proper settings while suspension is at ride-height, that should not be occurring.
08-27-2021, 04:54 PM | #3 |
Rep 445
I feel like I had similar noises before the install, but much more frequently immediately after. Starting to think that the added stiffness is making other suspension components flex more- hence the noise.
08-27-2021, 09:14 PM | #4 |
Rep 1,934
Odd I have this behavior in my car after lowering it. No control arm changes (same arms from factory at 86K). Have you lowered your car recently ?
At first I thought it was my axles, but then landed on the springs in my full floating front rotors. Now I am not so sure anymore
08-28-2021, 09:35 AM | #5 | |
Rep 445
Your note is starting to convince me that there might be something in my theory. Maybe it's the control arms now making (more) noise? |
08-30-2021, 09:21 PM | #6 |
Rep 445
Was able to get a vid of me manually turning the passenger wheel. Only the drivers side makes noise.
View post on imgur.com |
08-30-2021, 10:10 PM | #7 |
Rep 1,934
Nope that is not what I hear. Mine sounds like a really taut guitar string being strum
08-31-2021, 09:34 AM | #8 |
Rep 445
08-31-2021, 03:27 PM | #9 | |
Rep 1,934
08-31-2021, 05:56 PM | #10 | ||
Rep 445
08-31-2021, 06:34 PM | #11 |
Rep 141
I had them installed about 2 weeks ago while I was in Alaska and probably hear the same noise as you are. I've been trying to think of where else the noise could be created from. Definitely loudest while backing up.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
08-31-2021, 10:17 PM | #12 |
Rep 445
Well it's nice for me at least to hear I'm not the only one. So strange I see no mention of issues elsewhere!
09-12-2021, 09:42 AM | #13 | |
Rep 445
From what I can tell the mount is almost identical to the brand new one I put on. If anything it spins a bit easier… |
