01-25-2024, 03:27 PM | #1 |
Rep 1
H&R Springs uneven lowering in rear
Hey all, I had H&R Sport Springs installed on my 2018 440xi about two weeks ago and I noticed that the rear driver side sits a bit higher than the rear passenger side.
The bottom line on the cardboard is the top of the tire, the middle line is where the quarter panel starts on the passenger side, and the top line is the same but for the driver side. Does anyone know what might be wrong? |
01-25-2024, 05:32 PM | #2 |
Rep 224
Just a thought: it's compensating for the additional weight of the driver. Try having someone measure it out when you're sitting inside.
Gabe
'13 335i M-Sport Past - '06 330xi, '07 X3 3.0si, '09 328i, '12 X3 XDrive 35i |
02-10-2024, 01:27 PM | #4 |
Rep 583
There's a strong possibility the one of the springs has broken. I've had a front h&r spring break on me before
2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
02-20-2024, 02:33 PM | #5 |
Rep 1
I had it on my own with Eibach Pro Kit springs. The problem was the springs i turn them for 180° rubber pad underneath has one small teeth and that teeth you need to put inside the spring holder to look outside of car (both sides as well)
