BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > B48 330i OEM Exhaust Upgrades
proTUNING Freaks
      06-10-2017, 07:31 AM   #23
Cl4rk
Cl4rk's Avatar
France
Drives: 2016 F36 430i MSport 8AT
Originally Posted by GregD View Post
If you bought the muffler from someone upgrading to an aftermarket muffler, they should have cut it near the dimple. Cut your own exhaust at the same place, taking into account some extra room for the adapter piece. I had one made fairly cheap, and fitted it myself with clamps on both ends. Only tools needed is a good pipe cutting tool. Install took me less than 1 hour.
No need to transfer the vibration rubber IMO.
Thank you.
I have found a place that can make the sleeve reducer (to be used in reverse).
I need to perform the exact mesurements to be sure.
2016 F36 430i M-Sport 8AT | Ext Carbonschwarz Metallic | Int Korallrot | Trim M Perf Carbon set | Black double slat front grill | Black Exhaust tips | replica M Perf Rear Diffuser | Rear Spoiler
BMS BJ+ | Paddle shifters | replica M-Sport pedals | Variable Steering | Adaptive M Suspension | M-Sport Brakes | H&R Black Spacers 10mm-13mm | VSC-1 exhaust flap control
      04-25-2018, 07:58 PM   #24
samgraveno
Drives: 2021 G20 M340I
Hi Guys,
I've been researching on this forum and have the opportunity of buying a coworkers slightly used 340i full exhaust (not cut at dimple). I currently have a 330i M-sport and bought the dual diffuser and want the looks of a dual exhaust. Is it possible for me to remove my current 330i exhaust at the cat and install the used 340i? Basically I'm trying to get around cutting mine at the dimple in-case I decide to trade it in, in the future. Let me know what you think.
      04-25-2018, 08:29 PM   #25
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Originally Posted by samgraveno View Post
Hi Guys,
considering the 330i and 340i use different downpipes, I don't believe the 340i exhaust will bolt up to the 330i, assuming that's what you mean when you say at the cat.
      04-25-2018, 08:37 PM   #26
samgraveno
Sounds good. Probably my best bet is to cut it at the dimple but clamp it on instead of welding. That way I can change it back if I sell the car.
      04-25-2018, 09:18 PM   #27
rjd_F30
rjd_F30's Avatar
even then, you may need an adapter. I'm not sure if the 330 and 340 have the same size piping axle back. they may though, not sure. but yep, thats your best bet, thats what I did with my MPE very easy and reversible
      04-26-2018, 08:06 AM   #28
samgraveno
Originally Posted by fupsaker View Post
I myself have a 340i muffler with 340i CAT and I think it sounds awesome on my 330i. I like it much better than the MPE for 330i. It is something I really would recommend!
Hi fupsaker,
I know your post is about a year old. But I am in the market to do very similar to what you did on your 330i. My diagram below is an example of a 340i exhaust system. I assume you replaced #1 (cat) and #6 (muffler). Did you replace the center muffler #2? Did you cut the existing muffler at the dimple? Have you experienced any issues?
      04-26-2018, 08:25 AM   #29
Sweeney921
Sweeney921's Avatar
98
Drives: 2000 BMW E39 M5
Originally Posted by Elkawass View Post
Dears,
My current ride is the 2016 LCI 330i
What are the options and the best mod available (DP only or Rear Muffler only or Both, or even a Full Exhaust) ... what do you guys recommend.
I have a 2017 LCI 330i Sport Wagon. Recently installed a Supersprint cat-back dual tip exhaust, which was a much bigger PITA than expected. US cars have the B46 engine, which uses a V-band clamp to join the exhaust piping to the downpipe. Supersprint's designs are for the B48 engine, which evidently uses a slip-on connection instead. Kudos to Supersprint because they sent me a custom adapter based on some measurements, which I cut and welded onto the front-pipem
The Supersprint cat-back sounds great. I'm glad I got the resonated mid-pipe, because there's next to no drone.
View post on imgur.com
eleven11371.50
      04-26-2018, 04:31 PM   #30
tpliquid
Drives: f31 330i wagon
any sound clips sweeney?
      04-26-2018, 10:12 PM   #31
CoopersF15
CoopersF15's Avatar
Drives: F15 Xdrive 40e Performance
If anyone in the CA area going to bimmerfest this year has done this mod, please reach out - I'd like to hear it in person!
2017 F15 40i ePerformance -M Sport
      04-30-2018, 02:52 AM   #32
fupsaker
fupsaker's Avatar
Norway
Drives: F31 LCI 330i xDrive
Hi fupsaker,
Hola!
I replaced everything from #3 and backwards. Not the center muffler, as I can recall. They sound is way better imho than the original exhaust.
Proud owner of 2017 F31 LCI 330i xDrive
      04-30-2018, 07:06 AM   #33
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
I just installed a 340 MPE on my 328...things to note:
340 piping is 5mm larger (its 3") so as someone said earlier you will need a sleeve to downsize to you stock piping.
My MPE axleback pipe didn't line up 100% with my existing exhaust pipe so we did have to add a slight bend to my sleeve during install.
Beyond that the tips don't center completely to the dual outlet diffuser so at the end of the install there was some slight adjustments that needed to be made to hangers and the sleeve.
All in all with some patience it worked out flawless. My original 328 MPE was louder, but the 335 MPE does give you more pops and burbles so I'm considering it a wash in terms of sounds. You do gain the symmetrical look aesthetically.
(I used the most reputable exhaust shop in the GTA by the way:
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
rjd_F301999.50
      05-03-2018, 11:24 PM   #34
tpliquid
I have 18 330i and I got a 335i exhaust and pipes didn't line up correct.
I am going to assume that the 340i exhaust would be needed if want to be direct fit.
330i exhaust pipe diameter is 80 mm measured.
      05-06-2018, 10:55 PM   #35
thatf30
thatf30's Avatar
Drives: 2017 330i M Sport
2017 BMW 330i  [10.00]
correct 330 to 340 would guarantee best fitment. And even though a slight pipe diameter difference, mine just bolted/clamped right on. And while you're at it go for the M performance muffler
      05-07-2018, 06:15 AM   #36
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
And after you get your 340 exhaust get some M Performance cf tips.
2016 BMW F80 ZCP
darms55.50
      05-08-2018, 11:35 PM   #37
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
What shop would that be out of curiosity? And how much did they charge?
      05-09-2018, 05:17 AM   #38
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Hot Rod Scott
$250
2016 BMW F80 ZCP
      09-09-2018, 09:43 AM   #39
Clemy
South Africa
Drives: F30 320i lci
Howzit Guys,
I have a F30 320i b48 and am considering changing the exhaust and Downpipe.
Wanted to know if you guys changed to the 340i exhaust. Are you still using the stock Downpipe and getting a better tone with it?
Just to confirm you have installed the 340i exhaust from Downpipe to rear muffler excluding the center muffler and resonator? So you guys cut the mid pipe out?
1 more thing, i had a custom exhaust for my n20 320i. Any chance the exhaust will fit on the 320i b48?
Thanks Guys,
      09-11-2018, 03:36 AM   #40
MR1818
MR1818's Avatar
Malaysia
97
Drives: BMW 330i LCI
I did a full custom exhaust system which is a Valvetronic Exhaust when the valve is open its a direct flow from the downpipe all the way till the end and when its closed it goes thru a large box and the sound is just a little louder than stock. As 330i have 2 resonators, I've replaced it with a bullet type resonator which makes the sound more solid and the outcome of it is superb!
Recently and finally we are able to remap our cars and now I Have the POPS & BANGS and its crazy!
Can have a look at my ride in instagram mr_b48
      09-11-2018, 03:51 AM   #41
Ngen6
France
Drives: F36 430i M-sport Carbon Black
Thanks for sharing.
I have 430i LCI and I wanted to do the same but I saw sometimes guys telling that there pipes diameter is 65mm... I need to measure mine to be sure
I would appreciate to don't use a reducer
Current : F36 430i M-sport CarbonBlack
Previous : F30 330d M-sport SaphirBlack
      09-11-2018, 04:22 AM   #42
Ngen6
France
Here's a quick clip my spouse took, quality is not that great but it gives a good impression of how it sounds.
Next up is mid-pipe.
Thanks GregD for sharing.
Very agressive sound, exactly what I want for mine.
On the video, have you only replace the muffler by a 440i one ?
If yes, I will do for sure
      09-11-2018, 04:40 AM   #43
Clemy
South Africa
Thanks bro,
Are you using your stock Downpipe there?
      09-11-2018, 08:53 PM   #44
MR1818
MR1818's Avatar
Malaysia
97
Originally Posted by Clemy View Post
Thanks bro,
In this picture yes but I've changed my downpipe to a catless one already.
330i, b48, exhaust 330i oem
