10-18-2017, 06:11 PM | #23 |
Rep 57
Good news, from the Ebay search I did, it looks like all of them are screwed to the housing.
http://www.ebay.co.uk/itm/12-13-14-1...YAAOSwON9Zi09L |
11-03-2017, 08:28 PM | #26 |
Rep 57
I totally agree, when I finally completed installing the subs, there was little to no difference. This was due to the default Audio Var (2). I don't have a clue why, but, Var 1 has waaay more base, straight off the bat. As soon as I coded it, with the NBT rebooted, I instantly noticed there was a tonne more base, and that was with the EQ on default. I actually had to turn the bass EQ down, and the treble up a bit. But, atleast I can add and remove bass frequencies at will, unlike Var 2 (which was my default). Var 1 setting for me is not perfect, but, it's a hell of a lot better than Var 2, according to my ears. I'm not sure why you only have 3 Vars, and not 4, but, I hope your Var 1 setting has more bass like mine does. After you've changed it to Var 1, play with the EQ a bit. Good Luck S11nny
12-25-2017, 10:25 AM | #27 |
Gas Man Extraordinaire
64
Rep 80
Quick Q, I've just ordered two Focal IFBMW-SUB.V2 from France.
I have the HK system in my F30. Based on the Bavsound videos, why do they remove the whole unit? Why not just lift the seat, remove the cover, then directly unscrew the OEM speaker cone alone and unclip the electrical plug to remove? This would leave a hole to directly drop in the replacement. Why do you have to go to the extra hassle of unclipping extra things and removing the whole sub unit, plastic enclosure included? I think I'm missing something here but I can't for the life of me see why you can't simply replace the cone in situ?
F30 330d xDrive MSport+ BlackSapphire . HKaudio + 2xFocal IFBMW-SUB.V2 + RckFsg P300-12 . Gafferlicious.com
12-29-2017, 04:27 PM | #28 |
64
Rep 80
Just found their newest video which actually answered that very question :
Turns out you can simply swap out the cones directly without removing the enclosure. Mine arrived today so i'll be installing them tomorrow:
12-30-2017, 02:58 AM | #29 | |
Rep 565
Can you let us now how these sound and if install is as easy and suggested? I have the HK system in my F31 and would be interested in an easy base upgrade without subs and lots wiring or coding...... |
12-30-2017, 09:52 AM | #30 | |
64
Rep 80
In total takes about 45min start to finish (most of which was taken up trying to carefully loosen those bloody front bolts on the seats) and well worth the small outlay imho . BTW, here is the eBay seller (autoradio-center) I got them from, the £275 included delivery (the listing gives a price of £265, but when you pay via paypal it inexplicably goes up to £275 on completion so remember eBay is inaccurate re:exchange rates in the listings - probably to entice you to buy and then hits you with the real price AFTER you have completed the paypal payment ). https://www.ebay.co.uk/itm/Focal-IFB...72.m2749.l2649 Took 7 days to arrive from France with a tracking number and, to be fair, that price is still fantastic for both (every UK shop sells these for £380 per pair ).
flashollie178.50 |
12-30-2017, 10:58 AM | #31 |
Rep 565
Sounds like just what I'm after. I don't want a proper sub in the boot. I've definitely got the HK system didn't know I had 16 speakers though. Thought I had 13. Anyway I'll check and order in a day or so.
Great write up as well, thanks. |
09-15-2020, 06:39 AM | #32 |
Rep 2
Can anyone please explain to me what this means ??
But, by luck, whilst I was experimenting with coding in my car. I came across a code parameter called "AUDIO_SYSTEM_VAR", which is located in the HU_NBT/HU_CIC CAFD scetion. When you select the AUDIO_SYSTEM_VAR options, you'll see 4 options in total. "var 1" "var 2" "var 3" "var 4" (depending on what head unit version you have). Mine was set on "Var 2", so I tried var 3, and var 4, but, var 1 added more bass my audio after I coded it in. And with a little Eq'ing, the subs now sound GREAT!! Where do you find this/do this? Presumably not through the i-drive button?? Sorry, I'm used to old cars (E46s) and the technology in my F31 is way-beyond my knowledge. Thanks |
09-15-2020, 07:45 AM | #33 |
Rep 498
Having had speakers [Rainbow] & an amp [Alpine] installed in my car it sounds like I need to find someone who can interrogate my audio settings to make sure I am getting the most out of the system.
12-06-2022, 12:04 PM | #34 | |
Rep 57
Initially I found the audio "var" settings using E-sys years ago under HU_NBT I think, but, I'm happy to say that now, you can use Bimmercode to switch your audio Var settings. 1) Fire up Bimmercode. 2) Select "Headunit". 3) Go into "Expert" mode. 4) In the search bar at the top, search for "var" and select "AUDIO_SYSTEM_VAR". After selecting AUDIO_SYSTEM_VAR you should see 4 options, Variant1, 2, 3 and 4. By defualt, my car was on Variant2 (which sounds terrible and flat!). After cycling though all of the other variants, I found Variant1 made my system sound amazing. I suggest trying out the variants and select what you think sounds best. To try out each variant, you'll have to select it, code the headunit, have a listen, then switch to another varient, have a listen, and so forth. In my opinion Variant1 gives the base system solid bass and mids. You can really hear the sub woofers. If you find Variant1 too bassy, then have a play with the pathetic 2 band eq in sound settings of your iDrive when you're done. To all that have switched variants with the base system, please submit your feedback, and llet us know what variant worked for you. |
Leeg1633138.00 |
12-08-2022, 02:20 AM | #36 | |
Rep 170
12-08-2022, 11:37 AM | #37 |
Rep 57
12-08-2022, 11:44 AM | #38 |
Rep 57
You won't need an external amplifier, but, I can't stress how much of a difference changing the Audio Variant makes (atleast for me). If you install any subs in your base audio system, there'll be no difference in sound quality. The mids and low ends will sound identical to your base sound system. Experiment with the other 3 variants using bimmercode, and select the one that suits you best (for me, it was "variant1").
