BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMS Stealth Methanol Tank question
proTUNING Freaks
      07-16-2018, 09:36 AM   #1
HKD126
Drives: 2014 335i, 2009 335xi
Does anyone know if the Aquatec 6800 pump fits on the BMS Stealth tank?
I’ve contacted BMS and the official answer from them was “We can not confirm or deny fitment of that pump. It is just best to run our complete WMI system.”
I just want to run the tank. Thanks.
      07-16-2018, 12:58 PM   #2
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
I would say as long as the flange mounts up it should work. I would also consider the in and output of the pump head in relationship to mounting it up.
I can't find my measurements and the tank is bolted into the car right now :-D
      07-16-2018, 01:13 PM   #3
HKD126
I’ll be using a TorqByte controller as well. Did you buy a kit or piece it together yourself? Port or charge pipe injection?
Thanks.
      07-16-2018, 03:36 PM   #4
zinner
zinner's Avatar
559
Charge pipe, just boost juice so I don't need a lot of flow.
      07-16-2018, 03:39 PM   #5
HKD126
I’m actually looking at doing the same thing, but upgrading to port injection later.
      07-16-2018, 08:01 PM   #6
zinner
zinner's Avatar
559
Make sure you get a one way check valve. I had issues with the tank draining into the charge pipe on an incline.
https://www.snowperformance.net/High...sno-8cv-qc.htm
