BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos > QuickJack = Safe?
      06-17-2019, 01:27 PM   #23
86Zed
Recent /M Enthusiast
86Zed's Avatar
Drives: 6MT
Have used one for over four years without issue, it is a well built mechanism. I know many others who use them successfully as well
I always inspect the jack frame, mounting area and lockout bars before working near or underneath the car. As i assume one does with jack stands, ramps, etc. as well.
      06-17-2019, 03:00 PM   #24
martinm0
Drives: 2011 E90 335i RWD 6MT Sport
Originally Posted by perryo91 View Post
I think OP is just looking for a reason to "justify" the fact that he wont be buying a quickjack, because of one story that it failed on someone
I got the same feeling!
I love mine. Say what you will, but it is quick, effective, and safer for me as I have issues resting the car on the jack stands as they don't quite fit the jack pads.
      06-17-2019, 06:15 PM   #25
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
QJ specifically states that the jacks are not designed for people to work UNDER the vehicle. It states that you must supplement with jack stands at vehicle lift points (oxymoron?).
It's a big CYA statement.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
Efthreeoh5066.50
      06-17-2019, 08:54 PM   #26
Efthreeoh
Drives: E90 & Z4 Coupe
My Rotary 2-post lift DOES NOT say that.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission.
      06-18-2019, 06:09 AM   #27
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Nor should it since your 2-post lift has a different audience.
      06-18-2019, 11:14 AM   #28
blue135
Drives: 2008 135i Convertible
Have had my 135i, RX350 (4400 #) and Colorad (4300#) up in air and felt much more comfortable under Quick Jack than with 4 jackstands. And much easier to move around than working with 2 stands.
In addition, it takes me 10-15 min to screw around with jack and jack stands to get 135i up in the air. So much plastic and the jacking points all cause concern.
I think it is clear in pictures, but the hook on the end of the arm in contact with tabs in the rails are what hold things. Cams are simply to aid in getting arms released when you want to to go down.
Assuming one honors the weight limits Quick Jack specifies, each arm is only holding up 2500# or 3500# on each side. Not hard to engineer with high strength or regular steel.
