BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > cic to nbt upgrade
      05-18-2017, 08:37 AM   #23
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
Originally Posted by palomino05 View Post
I'll probably have to buy one from you guys , this one seems like to much work . I will have to save up since I wasted money on this one
No worries, just let me know. It will take a week to source and prep one for you
Codemybimmer | USA Toll Free +1(866)480-8049 | Canada +1(647)849-1003
www.codemybimmer.ca
Check out our online Store | Remote Coding Package| Sirius XM Retrofit Save 10% With Promo Code "Bimmerpost"
      06-12-2017, 07:45 AM   #24
Blueyzfr169
Drives: 2014 335d F30 XDrive M Sport
Wow do I just wasted my money , so your saying I cannot use this unit for navigation on my car ?
I've just got an NBT Evo and it has a blue GPS connector. I've mounted the GPS aerial on the bar behind the dashboard clocks and it works very well.
      06-12-2017, 08:28 AM   #25
AGONXF30
Drives: 2012 335i S-Line/Melbourne Red
I have a CIC system and I am happy with it. The NBT while better, is not a lot better to go through the hassle. If I wanted to retrofit the latest, what would I need. Is it even possible?
      09-06-2017, 02:56 AM   #26
mdcagil
mdcagil's Avatar
Turkey
Drives: 3.20i ED LCI
Guys.
I also want to upgrade to hu_nbt. Looking at eBay. There are many options but their backs are different. Do you know what are the differences?
      03-25-2018, 11:32 AM   #27
rezadue
Two turbos are better than one!
rezadue's Avatar
Drives: 2013 335 X-Drive M-Sport
I am in the same boat as Tim, except I have the HK sound system - 2013 335 M-Sport with CIC.
What reasonable options are there for people such as us in terms of upgrading the CIC? It seems like:
1) NBT upgrade is harder and more expensive (Stve can you comment on just how mch?)
2) Android 10.25" units are buggy and support is spotty
3) Apple carplay is useless for people like me with an Android phone
Thanks
Originally Posted by steve@codemybimmer View Post
You're going to need to take the amp trigger wire and tap it to the fuse because the NBT is not going to know how to turn on the amp. Also, you'll need a new USB and Bluetooth Antenna as those are currently connected to the Combox. Also note that your AM/FM antenna wires are different so you will lose AM radio.
Once you disable the combox, you'll also have to terminate the most loop so that DTC messages and Service Internals can show up properly on the instrument cluster. Also, your microphone will need to be disconnected and you'll need to run it to pins 17 and 22 on the quad lock as that too also goes to the combox currently.
We usually don't recommend this retrofit due to the amount of work involved. HU_ENTRY to NBT is much easier as HU_ENTRY is wired exactly like an NBT due to the combox not being present.
335 xDrive M Sport, MPPK
      03-29-2018, 08:51 AM   #28
cshawkeye
cshawkeye's Avatar
Drives: 2013 335i xDrive M Sport
Send a message via AIM to cshawkeye
I am in a similar boat, same year car with the older iDrive system. I have the older NAV system and iDRive system and I wanted to see what I would have to do to upgrade my unit to one of the newer iDrive systems. It just sucks that I should have wait a few more months for the 2014's to drop but got a killer deal on my car in 2016.
      04-23-2018, 02:58 AM   #29
Andrei_UK
Drives: BMW 116d 2013
If you get the ATM emulator as well as the Can Filtering harness, you should be ok. I don't think anyone else here has used an ATM emulator as of yet so you will be the first to find out
I have retrofit my BMW F20 2013 car came with standard HU , I retrofit with NBT EVO 2 ID6 aftermarket ATM witch activate SatNav and slot for GPS
      09-11-2018, 10:06 AM   #30
HaugF30
Drives: Bmw F30
Hi, i have recently installed a NBT HU in my Pre Lci F11, i used the Pre Lci retrofit kit from bimmerretrofit but i got no sound in my system, i know this is a 5 series car, but do you think it will be the same? have you done a installation in a 5 series car?
      09-11-2018, 10:10 AM   #31
steve@codemybimmer
Do you have Hi-Fi or Harman Kardon?
www.codemybimmer.ca
      09-11-2018, 10:35 AM   #32
HaugF30
Drives: Bmw F30
Oh i forgot to mention, i have Hifi 676 which is FA coded to the NBT_HU
It doesn't matter if i disconnect everything from the Combox or not, still no sound.
My thought is that i also need Most Loop on the Fibre optic comming from the Combox, what do you think?
      09-11-2018, 11:34 AM   #33
steve@codemybimmer
hmmm, Hifi is via most on the F10 if I'm not mistaken. Did you move the black and green optical cable from quad lock over to the Bimmerretrofit harness?
www.codemybimmer.ca
      09-11-2018, 12:37 PM   #34
HaugF30
Drives: Bmw F30
Yes i did, i also put a most loop connector to the lines which were previously connected to the Zgw.
      09-11-2018, 02:21 PM   #35
steve@codemybimmer
I would say at this point that the head unit is not coded to the proper amp. Did you VO code the NBT?
www.codemybimmer.ca
      09-11-2018, 05:02 PM   #36
HaugF30
Drives: Bmw F30
It is Vo Coded with the 676 Code for the 676 Hifi system yes, i took the FA list from the car and Vo coded it into the NBT_HU.
      09-11-2018, 06:49 PM   #37
steve@codemybimmer
Only thing I can suggest is to bridge pins 13 and 15 on the quad lock together and that should power on your diversity antenna and presumably the external amp.
www.codemybimmer.ca
      09-12-2018, 01:48 AM   #38
HaugF30
Drives: Bmw F30
Talking
Hehe, i just found this thread, before i saw your answer
https://f30.bimmerpost.com/forums/sh...5#post23711925
Yes this must be the reason i guess, just find it strange that Bimmerretrofit didn't know about this
      09-12-2018, 06:02 PM   #39
HaugF30
Drives: Bmw F30
Yep, connected a wire from Pin 13 to Pin 15 at the Bimmerretrofit ENbt adapter's Quadlock and voila, i got sound from the system again
But i got a coupple of other problems, anyone know what to do?
I have coded the Oelstand in Fdl, but the meter is grey and is showing only a few percent at the bottom.
The other problem is that then i try to set the setting of the tailgate in the idrive, the setting goes down again, kinda like those 80's Equalizer meter's, is there something i have forgotten to Fdl code here?
      11-10-2018, 10:16 AM   #40
Franklinc
Drives: F10 528 LCI
Per my know USB and BT are connected to Combox, what did you do to make them work in NBT? what would happen once combox is disconnected?
      11-10-2018, 11:52 AM   #41
jayd1000
Drives: f30
Thanks
I got the same dilemma, i got 2012 f30 with CIC hu with basic setup, no nav, no Bluetooth just aux and usb in centre armrest. I`m debating going down NBT retrofit or do I just get 10" android screen with it all built in. Anybody got pros /cons for both ideas??
cheers,
Jason
      01-16-2019, 01:39 PM   #42
NVETHIS
Drives: '12 335i
cheers,
Jason
I'll probably have an AVIN 1025 Android unit (1.5 years old) for sale soon. I think I'm going to order a NBT EVO retrofit from bimmertech. If you're interested.
-NVE
      01-16-2019, 08:01 PM   #43
1998fordexp
Drives: 2014 320ix
Originally Posted by mdcagil View Post
Guys.
I am doing the retrofit Steve was talking about. I got an NBt unit that did not have XM. That was important to me so I am getting rid of my NBT for one that has XM. If you are looking for a nav unit, this one is great. In good shape. From 2016 x5. Can easily be coded to your vehicle.
