BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Standard Radio to NBT Upgrade Parts Check
European Auto Source (EAS)
      09-11-2018, 03:34 AM   #1
SuhaibD98
Drives: BMW F30 M Sport 2014
Hello
I'm sourcing parts for an NBT upgrade I'd like to know what parts I exactly require i already have a list and was wondering if i need anymore
- NBT Headunit
- NBT Screen
- Touch Controller
- Cable for Unit to Screen
- Usb Cable
- Navigation Antenna
- Emulator for touch controller
However, will i need an emulator if I don't upgrade my touch controller?
      09-11-2018, 07:28 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's probably less expensive to sell/trade the car in and get one equipped the way you want it.
      09-11-2018, 01:30 PM   #3
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by SuhaibD98 View Post
Hello
- NBT Headunit
- NBT Screen
- Touch Controller
- Usb Cable
Def not cheaper to trade car in don't listen to him but u do not need an emulator for touch controller, u need the ecu for touch controller I u want the touch function. If u don't then u only need the controller. U do however need the emulator for fsc codes unless u wanna buy them which then it gets expensive. U also would need a Bluetooth antenna
      09-11-2018, 04:06 PM   #4
SuhaibD98
Hello
- NBT Headunit
- NBT Screen
- Touch Controller
- Usb Cable
Thanksfor your reply!
Ok so I've seen a harness kit
https://rover.ebay.com/rover/0/0/0?m...2F262689576519
Will this enable the use of the controller
      09-14-2018, 03:20 PM   #5
Jhnblckwood
Hello
- NBT Headunit
- NBT Screen
- Touch Controller
- Usb Cable
No u still will need the ecu for the touch function. In this ad it's the little box that says ece-us. Again u don't "need" it unless u want the touch function. It can b used with out it so up to u.
https://rover.ebay.com/rover/0/0/0?m...2F253220309699
The little black box in the link u posted is still needed for ur navigation however.
