BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Help! Did I blow my fuse block?
European Auto Source (EAS)
      09-12-2018, 12:29 AM   #1
Merlins Beard
Drives: 428i M Sport
Hey guys,
2014 F36 428i GC m-sport
As I was hardwiring my external battery pack and dash cam via the fuse box, I was using a fuse tap to tap into fuse 155. That fuse seems to be associated with the radio (see diagram).
In my fuse tap, as instructed, I put the original 15 amp fuse in the bottom slot and a 10 amp fuse in the top slot going to the add-on wire. The external battery I am wiring to draws 9amps so I should be fine there. When I turned the car on, I was watching the fuse block and I saw what looked like the fuse blowing, but when I looked closer, both fuses were still in tact. Hmm, I thought. That was weird. I put them back in and now seemed to be getting no power to those fuses.
So I removed all my add-a-circuit business and put everything back to stock with original fuses. Then I got my multimeter and tested the fuses. Neither side of the 154 or 155 fuse was giving me 12v power with the car on or off... and now, when I use the radio, the sound is way off. Everything works per se, but the sound is just lackluster and weird sounding... (For reference, it's the Harman Kardon system and normally sounds awesome!)
My question is.. what do I do? How do I test what's wrong? What could have happened? And why the hell did that happen?!
      09-12-2018, 03:44 PM   #2
Merlins Beard
bump
      09-12-2018, 11:50 PM   #3
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
The radio sounds awesome? I have my doubts.
Fuses are inexpensive and can easily be replaced.
      11-26-2018, 03:29 PM   #4
lex0083
Drives: 2014 335i xDrive
I think he was saying that the fuses appear to be okay but the fuse block 155 isn't working anymore.
OP, did you figure it out the issue and was it fixed?
