01-05-2019, 09:43 AM | #1 |
Rep 9
Bmw335d Brakes Discs/Pads
Hi Guys,
I have a 2015 335D Estoril blue 55k on the clock p, actually a old forum members car. Just needed some help regarding front and rear discs/pads that need changing. Originally before Xmas I spoke to someone at Euro car parts and they told me what part numbers to order online which I did without checking properly then realised I ordered the wrong brake discs (340mm not the 370) I have the m performance braking kit so need the bigger discs front and rear. Euro car parts are doing 50% off at the moment and was ready to re order but when returning the wrong discs today the guy told me the grooved and drilled will not fit properly and to go with the vented? Doesn’t anyone know if this is correct? The part numbers I was going to order were: Front discs- 10411186A Front pads- 101111238 Front Sensor-10411194A Rear discs- 1041829A Rear pads- 101111188 Rear sensor - 106111058 Discs are Brembo and pads are Pagid parts are looking at around £400 for the front set and £275 for the rear set this is after the 50% discount. if anyone can help me out or even if it’s worthwhile just getting the parts and fitting idone from a reliable specialist I would be grateful (one local specialist quoted £750 for the front), I’m based near Heathrow. Thanks guys. |
Tags |
brakes |
