BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > clearing abs fault
European Auto Source (EAS)
      11-30-2013, 09:32 PM   #1
Drag0n
Drives: 328i
clearing abs fault
Hello, I followed these steps to coding paddle shift on my f30
Expert Mode->Coding, Read Vehicle Order, Read (VCM), Save the xml, Edit
FA-Editor, right click FA, calculate FP, goto SALAPA-Element, changed 205 to 2TB, apply, calculate FP, save
return to Export Mode->Coding, Load the xml, right click on FA, activate FA, Read (VCM), single click on the root SVT then click Code button
It did not work and had some faults :bawling:
is there any way to clear these faults?
Thanks
      12-03-2013, 04:37 AM   #2
Timur
Russian Federation
Drives: BMW 320
There is a way
Go to C:\EDIABAS\Bin\TOOL32.EXE
Push F3
double click on FS_LOESCHEN_FUNKTIONAL (Jobs) - it will erase your faults
but first you must find the cause of a fault - othervise the fault light pops up again
Good Luck
      12-03-2013, 05:28 AM   #3
HFW003
HFW003's Avatar
Australia
1687
Drives: MY19 LBB M2 Comp
Exactly the same way you were told on the other site my friend.
If the codes don't clear it usually means there is an underlying issue.
Good luck.
