04-25-2019, 05:58 AM | #2663 |
Rep 1,048
can anyone tell if the devices do have Gryro/Accelerations Sensors ?
would be interesting if it would be possible to connect these devices to the BMW Performance Analyser. at the play store i found "Sensor Test for Android" and "Senors Multitool", maybe someone can check which sensors are build in and active ? Kri Last edited by Kri; 04-25-2019 at 08:16 AM.. |
04-25-2019, 01:09 PM | #2665 |
Rep 77
05-01-2019, 04:08 AM | #2666 |
Rep 595
Can anyone give me any tips with getting the reverse cam working. I bought it from avin at the same time as my HU. I've ran the signal wire from cam to HU. used the red on the signal wire to take power from the 12v wire in the HU to the cam and grounded the other end. Now all I get is the no signal screen. I've tried tapping the rear light for 12v instead but still nothing.
05-01-2019, 11:49 PM | #2667 |
Rep 77
I am now using the soundkey. It also requires setting Android media volume to max, and then sound is amazing. Even better than Schiit Modi, maybe because of better output impedance. I installed the unit inside dash and I plan to forget it there. It works flawlessly.
05-02-2019, 12:47 AM | #2668 | |
Rep 433
05-02-2019, 12:34 PM | #2670 | |
Rep 63
Measurements for soundkey. Measurements for dragonfly. Neither one is a "great" performer on the larger scale though output impedance should be a an important factor when deciding when choosing a DAC for this application as I have mentioned previously. |
05-02-2019, 12:35 PM | #2671 |
Rep 433
I'm using the 4x4 shop 8.1 unit in my e70.
Which DAC would you recommend?
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
05-02-2019, 05:40 PM | #2672 |
Rep 91
Not sure if this was already answered, but does the iDrive touch controller work as a mouse for the Avin android side?
I have the screen already installed, but a non-touch controller. If the touchpad on the idrive controller works as a mouse to control the android screen I'm gonna buy a touch controller. It's annoying and dangerouse to reach over and touch the screen while driving. |
05-03-2019, 03:17 AM | #2673 |
Rep 77
Yeah, 8.1 AVIN unit. The SoundKey easily sounds good enough for car use. Actually, it sounds amazing. Better than Galaxy S8 output directly to aux port. Considering cost, sound quality and ease of use, SoundKey or similar DAC is a great option for improving Android HU sound quality.
05-05-2019, 03:07 PM | #2674 | |
Rep 21
05-07-2019, 03:09 PM | #2675 |
Rep 2
Hi guys I’m just wondering if anyone can help me with my 4.4.4 system my unit is flickering when it’s full brightness when I put it to 50% the flickering stop but still flickers just a little I have emailed the seller but no luck.
If anyone experienced would you mind giving me advise to get around it please. Also any updates or files item mcu updates files maybe I can update the system to the latest version to hipefully make the flickering stop. Last edited by Nb080; 05-07-2019 at 03:18 PM.. |
05-08-2019, 01:42 AM | #2676 |
Rep 63
Audio science review has a wide selection of DAC reviews. You can start there. I don't have anything specific I can recommend. You can go by measurements and then listen in your car. Honestly either of the DACs you guys are using lips and bounds better than built-in unmodified audio output of this Chineese product. It appears that they haven't done anything to improve audio quality in all of this different HW releases even though components selected there are capable of much better quality. The audio was definitely an afterthought...
05-08-2019, 10:04 AM | #2677 | |
Rep 3
05-08-2019, 08:25 PM | #2678 | |
Rep 63
As far as your question is going: 1. Phone -> lossy SBC codec (BT stream) -> BMW DAC 2. Android screen -> USB DAC -> BMW ADC -> BMW DAC Technically option number 2 should be better if USB DAC-BMW ADC combo is of good quality. In practice it can be worth. Also the Android screen is buggy piece of hardware, you will be forced to share data on your phone or opt for external modem. It can all be automated but requires knowledge of how to/time. So it is your choice. If you avoid the DAC with Android screen and care about audio quality you better stick to your existing setup. Android screens have horrible audio quality that can be improved with some soldering skills, but won't be as good as even mediocre external DAC. |
05-08-2019, 09:18 PM | #2679 |
SQUEAKY
104
Rep 322
Unfortunately, I think I'm going to be hanging my hat on the avin unit after 2 years.
Just ordered this US $373.15 15% Off | Joyeauto WIFI Wireless Apple Carplay Retrofit 1 2 3 4 5 7 series X1 X3 X4 X5 X6 MINI NBT F10 F15 F16 F20 F30 F48 13-17 for BMW https://s.click.aliexpress.com/e/b3nJFzKC Hopefully it's more stable then the avin unit. |
05-09-2019, 10:35 PM | #2680 |
Rep 2
Had my avin 10.25 show up today. Struggling to understand which aux goes where including the splitter as well as what plugs where in the gps splitter. Also dont know where my video feed wire for the back up camera is as I had one already. Anyone have any experience or help for a 2015 f80 m3?
05-10-2019, 09:30 AM | #2682 |
Rep 835
Hi
Anyone got Idrive controller working with CarPlay or any other apps on the 8.1 unit? I'm guessing there needs to be an MCU update to make this work? What is the latest 8.1 MCU out there? |
05-10-2019, 01:10 PM | #2683 |
Rep 21
05-10-2019, 01:11 PM | #2684 |
Rep 21
