05-30-2020, 02:12 PM | #8119 |
¯\_(ツ)_/¯
945
Rep 1,762
Replaced front pass door lock actuator. Door wasn't locking/unlocking with the key. Easy job.
Palantir219.00 |
05-30-2020, 02:40 PM | #8120 |
Rep 209
Spare tire
Done with the trunk for now.
Your life is a book and you are the author. Along the way there are fans, critics, editors etc that influence, change, refine and/or mess up your story. But at the end of the day, YOU are the writer and it is YOUR story.
05-30-2020, 03:09 PM | #8122 |
Rep 209
Thank you. Brand new oem wheel and full size run flat came at a great price. About a third of what a donut would cost. Space is not important because I seldom carry anything more than a laptop bag. Also like the idea of being able to go 75mph for unlimited distance on the highway (Tennessee speed limits are generous )
haagm58809.50 |
05-30-2020, 03:18 PM | #8123 | |
Rep 1,508
Palantir219.00 disintegrator66403.50 |
05-30-2020, 03:25 PM | #8124 | |
Rep 209
Edit: Nice tip on the donut brake clearance!
05-30-2020, 04:43 PM | #8125 | |
poopycat
266
Rep 791
Edit: wrong forum, thought of another make. You had run-flats, my bad. |
05-30-2020, 05:14 PM | #8126 |
Rep 209
Thank you for the divine validation!
05-30-2020, 06:24 PM | #8127 |
Member
106
Rep 151
Attempted to install clear front reflectors, gave up. Even with a hairdryer seemed I was getting nowhere. Felt like I was gonna damage the bumper. oh well...
05-30-2020, 07:32 PM | #8130 |
Rep 919
Drives: F30 328d Sport Line
I used a heat gun and had to push very hard on the reflectors into the bumper to remove my stock reflectors. I get what you're saying and you're right, they can be a pain to remove. Once out, make sure to remove as much of the old adhesive as possible so the new reflectors sit flush.
Palantir219.00 |
05-30-2020, 08:02 PM | #8132 | |
Rep 1,236
Basically get a tiny bit of it pushed in and reach in and wedge your fingers between the reflector and bumper. It's easy after that. Remember to apply outward pressure on the bumper and it shouldn't dent
2023 M2. ZB. Manual.
2024 m235i |
05-30-2020, 08:27 PM | #8133 |
PsyD
102
Rep 156
Drives: 2016 340i M-sport
Over the past couple days have installed CF shifter pieces to match the other interior CF and added some vinyl to the outside. AP intake, new spark plugs, and Remus axleback exhaust to be installed next week
05-30-2020, 08:34 PM | #8134 |
PsyD
102
Rep 156
I ended up getting a heat gun for this purpose but I've used it for other projects too, so it's good investment. It took a solid few minutes of applying heat with a med-high heat intensity with the gun to get the adhesive to become pliable, but it also took a good bit of force to get the reflector out. As someone said earlier, definitely make sure after you get it off that you go over it again to make sure you've gotten all of the adhesive off and clean it with alcohol before sticking the new one on
Palantir219.00 |
05-31-2020, 04:30 AM | #8135 |
Rep 359
Nice score....Any more of these deals available? I eventually plan on switching to go-flats as well.
05-31-2020, 04:33 AM | #8136 |
Rep 359
Did the same thing... I think I actually aborted twice! Good advice given to leave in the sun and just be generous with the hairdryer. They need alot of force to be pryed off. My finger tips were sore after finally getting the fookers off! Good luck!
Silverlining_m21733.00 |
05-31-2020, 07:32 AM | #8137 |
Rep 1,508
05-31-2020, 08:40 AM | #8138 |
Rep 4,031
I did mine in November, that was a pain. Well worth the effort though. Like others, patience and you'll get there.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
Palantir219.00 |
05-31-2020, 10:46 AM | #8139 |
Rep 211
patiently waiting to pick my baby up from getting buff and wax job! pictures to come!!
Palantir219.00 Silverlining_m21733.00 |
05-31-2020, 03:55 PM | #8140 |
BMW CCA Member
488
Rep 808
Can you spot it?
$22 from Ebay for a set of four. About a good hour to install. Mostly to get everything lined up. All you need is a drill (for pilot holes) and a 10mm socket. Last edited by exE36M3; 06-01-2020 at 10:17 AM.. |
