06-22-2020, 01:08 PM | #1 |
Rep 199
2.5v setup to 12v
I have a small converter to step up the voltage from 2.5v to 12v by running a separate wire from an ambient lighting source.
Question is will this cause any harm to the canbus system at all? |
06-22-2020, 04:55 PM | #3 |
Rep 199
I need an illumination/dimmer wire for my boost gauge. There is no fuse to piggyback but I found the ambient led above ashtray comes on with headlights. BUT as it only gives out 2.5v the boost gauge doesn't recognise the input as it requires 12v. So I have found little electronic something that can step it up to 12v, by running a wire from the ambient lighting, then step up and then run it too boost gauge, voila.
Before i do that I am curious if will cause any issues to the can bus at all? |
06-23-2020, 01:43 AM | #5 |
Rep 199
06-23-2020, 07:34 AM | #6 |
Rep 16,079
There is a fuse box under the hood full of fuses that can be piggybacked. People do so all the time, usually to power dash cams. I did so for a set of auxiliary LED daytime running lights. I tapped fuse #69, which on my car powers the console outlet. It comes on when the car is unlocked, powers off a few minutes after the car is locked.
06-23-2020, 07:47 AM | #7 | |
Rep 199
06-23-2020, 10:39 AM | #9 | |
Rep 199
Thank you for your help. |
