11-17-2020, 01:48 PM | #1651 | |
Rep 57
11-17-2020, 03:13 PM | #1652 |
Rep 82
As a note, I was getting dips in rail pressure down to 2000 with the stock pump and throttle closures. I went to the Supra pump and the dips went away as did the throttle closures, same fuel in the tank. i do think the DME seeing lower rail pressure at some point, compensates with throttle closures.
11-22-2020, 01:35 AM | #1653 |
Rep 91
'18 340ix GT, AA Catted DP, BMS Intake
MHD Stage 2 E30 & xHP Stage 3 5th gear pull https://datazap.me/u/cxmplex/b58-f34...-45&solo=12-13 4th gear pull (afr is everywhere on this one prior to flooring it?) https://datazap.me/u/cxmplex/b58-f34...-45&solo=12-13
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
11-25-2020, 03:15 AM | #1654 |
2JZ-GTE
3038
Rep 3,992
What's up with cylinder number one? Mine does the same thing.
11-26-2020, 04:32 AM | #1655 |
Rep 192
A "feature" of these engines...cyl1 tends to be the one pulling the most timing. I've read some say that the PCV vents right over cyl1 which causes it to pull timing more than the others, but I haven't read a definitive anwer.
11-26-2020, 06:43 PM | #1656 |
DisplacementReplacement
409
Rep 1,101
I see the same thing, cylinder one first to pull timing most of the time, even in some not wide open throttle situations. Pcv, is that the consensus?
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
11-27-2020, 06:05 PM | #1657 |
Rep 125
Can you guys take a look please
https://www.bootmod3.net/log?id=5fc1...729b348f4a37ae
I went back to the 91 stage 2 map because of winter blend e85 but just swapped back to stage 2 e30. Been having some real issues with the OBD2 to enet with the lightning cable adapter. It works when it wants to, it's really weird so I hope I captured the log, I'm not sure. Car is feeling a lot less powerful and the other night sitting with the heater on during idle it started making a weird noise and I was getting some smoke and it turned itself off, just dropped RPM's and died. I limped it home and it's been fine since but the power hasn't felt the same. Let me know if you guys need another log. Thanks
2012 335is-stage 2 plus VTT turbos, catless, DCI, stage 2 LPFP, 2 inch inlets and outlets, VRSF CP with Tial BOV, VRSF 7.5 inch race intercooler, 3.5 bar map sensor, RB PCV valve
11-28-2020, 08:15 PM | #1658 | |
Rep 57
11-28-2020, 08:28 PM | #1659 | ||
Rep 125
11-29-2020, 02:16 PM | #1660 |
Rep 198
I just purchased bootmod3 and will be going stage 1 soon, but wanted to datalog my car before I even cracked the DME.
This is a completely stock car, aside from the MPPSK. https://www.bootmod3.net/log?id=5fc3...729b17859a820e also I forgot to log the timing corrections, ill get out and do another run in the afternoon.
2016 340i / M-Sport / Track Handling Package / MPPSK / AA DP / CTS Intake / Bootmod3 e30
11-29-2020, 06:18 PM | #1661 |
Rep 180
Greetings,
I am still learning how to read and understand logs, I know some basic stuff but would like to know someone else's opinion on how my engine is performing. Got a Bootmod3 OTS Stage 2 91 oct map with a small meth nozzle. In my country my gas sucks, they claim it's 91 octane but in reality they say it's like 90 or 89 oct so instead of running the 91acn map I run the 91oct map with a 50/50 meth injection. https://www.bootmod3.net/log?id=5fb0...729b6940614f8e Here is one log with no meth. Same OTS 91oct map. https://www.bootmod3.net/log?id=5fb0...90c668ff8168e0 Thanks!
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
11-29-2020, 08:04 PM | #1662 | |
Rep 1,239
The no meth log does have a knock count which in turn looks to pull timing from cyl 6. Its your car at the end of the day but knock isnt good, if your always running meth not an issue i guess. |
11-29-2020, 09:05 PM | #1663 |
Rep 180
Oh wow I did not see that. And yes, I do run meth all the time, I just did that one no meth run to see the difference with and without it. Thank you for pointing that out!
11-30-2020, 11:17 AM | #1664 |
Rep 198
Another run with just MPPSK:
https://www.bootmod3.net/log?id=5fc4...90c66f39291361 this is one is after I went stage 1 ACN. The log looks fairly clean at least to me...I wonder if I can push it a bit and go for the "regular" stage 1. https://www.bootmod3.net/log?id=5fc5...729b7b06af3c74
12-23-2020, 08:17 PM | #1665 |
Rep 7
Could someone please take a look at the below logs? This is on BM3's stage 2+ E30 OTS map in 3rd gear. Other mods are TU pump, catless downpipe, and XHP stage 3.
Timing seems to be all over the place. Could this mean it's time to replace spark plugs? The current plugs have about 21k miles on them. The car has not thrown any codes. https://www.bootmod3.net/log?id=5fe3...0b431a1b66a599 https://www.bootmod3.net/log?id=5fe3...90c67d0648b37f Last edited by citrinblack340i; 12-23-2020 at 08:36 PM.. |
12-24-2020, 04:46 AM | #1666 | |
Rep 183
12-26-2020, 10:44 PM | #1667 |
Rep 60
I have a m240i car doesn’t feel right bm3 ots stage 2+ 93oct with a stage 1 hpfp and catless downpipe 3rd gear log https://www.bootmod3.net/log?id=5fe8...90c67c6b3669a1
12-27-2020, 12:27 AM | #1668 | |
Rep 57
12-30-2020, 07:22 AM | #1669 |
Rep 504
01-01-2021, 07:37 AM | #1670 |
Rep 20
340i rwd
MHD stage2+ Hpfp TU pump catless dp XHP stage 3 ~E50 HIGH altitude (+- 6000ft) Very hot (32 degC) if turbo is not maxed out here, then i don't know what is Please can you take a look. is the turbo being choked? would i benefit from an intake since its high altitude? https://datazap.me/u/slowmo/340istg2...data=3-6-17-34 |
01-02-2021, 10:30 AM | #1671 |
409
Rep 1,101
Is there a consensus with which is the stronger MHD map, stg2 95 or stg2 e30 (not the hpfp maps)? Looking at logs and feedback in this thread i'm not seeing it other then the 1 lb difference in boost + with the 95... thoughts???
01-02-2021, 08:38 PM | #1672 | |
Rep 82
