10-25-2018, 12:43 AM | #155 | ||||
Rep 7
10-26-2018, 02:13 PM | #156 |
Rep 7
guys is there any guide for the coding? I think the wiring is very easy see the attached for some additional detail.
LEFT Headlight Connector FEM Connector Pin 1 Pin 48 A173*3B Pin 2 Ground Z10*1B Pin 3 Front Fuse Box Pin 4 Empty Empty Pin 5 Empty Empty Pin 6 Empty Empty Pin 7 Empty Empty Pin 8 Pin 53 A173*4B Pin 9 Pin 21 A173*2B Pin 10 Pin 20 A173*2B Pin 11 Empty Empty Pin 12 Empty Empty |
10-26-2018, 08:25 PM | #157 | |
Rep 765
10-26-2018, 09:05 PM | #158 | |
Rep 765
This is what I used, sorry idk what I uploaded last time. |
10-27-2018, 12:38 AM | #160 |
Rep 765
No problem man Goodluck. Coding isn’t that bad as long as u kno what ur doing. U may have to flash ur fle’s with esys and psdzdata full but I didn’t. Idk if that’s bc mine were used or what but if u can’t code them then u prolly have to flash first. Goodluck.
Ps I heard some ppl having to initiate led’s With ista+ if all else fails then try that too. Again I didn’t have to but heard of ppl needing too. |
10-31-2018, 12:33 AM | #161 | ||||
Rep 25
I just installed the headlights and its just right how you saying. I start the car and the headlights turn on, but in 1-2 seconds, it turn off by itself. What do i need to do? |
11-04-2018, 12:08 PM | #162 |
Rep 3,052
Hello,
Where in front fuse box PIN3 should be plugged in? I don't have socket Z7*10B in front fuse box, can I connect it to different one? How you guys did that? Thanks |
11-07-2018, 06:39 AM | #163 |
Rep 3,052
Did anyone have problem with wdbi_plain error when coding FLEL? I’m coding it with modified FA(zeitkriterium and 552 in Salapa Elements).
e-sys and ista see FLE 43(ecu with fault memory) Thanks! |
11-07-2018, 08:58 PM | #164 |
Rep 765
11-08-2018, 09:07 AM | #165 |
Rep 3,052
Ok figure it out.
They work fine in F82. Strange, that i also have STMR AND STML in ista shown in red. How to get rid of them in ista tree? Change FA in VCM?(i didnt do it) |
11-08-2018, 11:47 AM | #166 |
Rep 6
Hi, I made a wiring harness for a 552 adaptive led, all made same as official bmw retrofit.
I have brand new headlights with brand new modules. My car is 11/2011 with regular halogen lights. I added 552 code to VO, but problem is that FLE modules should come after coding VO but they don't. Do You know maybe where is problem ? Do I need to update I-step because my vehicle is from 11/2011, do I need somehow to teach-in modules because they are brand new unused ? Thanks in advance. |
11-08-2018, 12:27 PM | #168 |
Rep 6
11-09-2018, 03:25 PM | #169 |
Rep 3,052
11-14-2018, 06:08 AM | #170 | ||
Rep 25
I start up the car and both headlights works for 1-2 seconds and then they turn off by itself. And just remain the passenger side DRL on with the indicator on; and the driver side just the indicator on with the DRL lights off. Also, both indicators stay on, not blinking and are flicking like there is not enough power. What do i need to do now? I havent do the retrofit wiring yet. |
11-14-2018, 06:58 PM | #171 | |||
Rep 765
03-04-2019, 12:15 PM | #173 |
Rep 85
03-14-2019, 07:42 AM | #174 |
Rep 7
Hello,
so where did you put new wires for K-CAN2 in FEM??? for left headlight: Pin 9 from headlight to Pin 21--A173*2B Pin 10 from headlight to Pin 20--A173*2B For right headlight: Pin 9 from headlight to Pin 50--A173*8B Pin 10 from headlight to Pin 49--A173*8B When i'm putting these wires,it didn't work,nothing at all. Even worser,KOMBI,HU-ENTRY are not working. How do You solved that?? F30 2013/07 Already have newest i-Level, edited zeitkriterium to 07/2015, added 552(adaptive),coded FEM,REM.ESYS not show any FLE's. ISTA shows just one FLER block... Thanks. |
03-15-2019, 12:25 AM | #175 | |
Rep 7
Had bad contact on left headlight CAN-Low, everything working fine now,looks amazing) Thank You |
07-23-2019, 12:28 PM | #176 | |
Rep 40,650
