01-01-2020, 08:36 AM | #23 | |
Rep 15,858
01-01-2020, 10:28 AM | #24 | |
Rep 1,502
For sure every car is affected the exact same way. Other manufacturers don’t have access to special magic batteries, but non-premium cars do likely skimp on battery monitoring technology. BMW with the IBS (intelligent battery sensor) and SOC (state of charge) tracking is probably more proactive about giving warnings. Ignorance is not bliss when it comes to getting stuck in -30F weather! I keep a portable jump starter like this in the trunk for emergencies: https://www.amazon.com/NOCO-GB40-Ult...s%2C190&sr=1-4 Also check out this article: https://batteryuniversity.com/learn/...w_temperatures Now where I would fault BMW is that it never seems to charge the battery about 75% or so and that’s understandable under normal circumstances. But during sub-zero weather it really should charge to 100% (if it doesn’t, I don’t know). |
01-01-2020, 12:33 PM | #25 | |
Rep 59
Drives: F30 320d xDrive M-Sport
My wife, who owns a non-premium german car half of the price of my BMW, never ever has to do external charging, SoC is typically 90%+ (12.6V-12.7V, non AGM battery) and she is driving less miles and less often than myself. IMO, it is a BMW engineering design fault. Period. Even worse, they don't want to admit it, nor want to give advanced users option to tweak the SoC target value withing some safe limits! |
01-01-2020, 02:04 PM | #26 | |
Rep 4,877
01-02-2020, 05:03 AM | #27 | |
Rep 15,858
Just a few users will ever see those limits, let alone look deeper into their function. The APM (Advanced Power Management) is continuously checking the SOC and battery condition, has values BMW are using to protect the user for startability. For example BMW indicate for AGM batteries under APM. Startability limit is approx. 30% state of charge at 15 °C. Startability limit is approx. 50% state of charge at -15 °C. APM will be protecting those values, in extreme working conditions. If we don't happen to drive enough over time, to even allow that to happen, we'll get a warning. I do wonder how many users don't actually get an engine start, due to BMW's energy management's function. Rather than a fault. |
11-24-2020, 12:35 PM | #28 |
Rep 59
Taking battery out of car to charge it
Due to more "working from home" and also a bit because of a BMW "design limitation" to decide to keep SoC relatively low, now I am getting into a bit of a trouble...
Since doing much less driving for past several months (typically driving mostly only weekends, on average maybe 100 km), last weekend car really struggled to start (I checked voltage previously, it was only 11.7V before starting), and even after 1.5hr drive, next day voltage was just 11.8V, struggling again and throwing a Low Battery message blabla again... I don't know which current alternator supply to battery in low SoC, I can guess less then 10Amps, maybe only even 5Amps or less... I worry that soon it will not be able to start, especially with lower temperatures coming. Not to mention it is very bad for battery lifetime to be in very low SoC. Since parking place is closed garage place but without plug-in electricity socket available, only way seems to be the hard way to take battery completly out of the car and charge it at home (I just purchased CTEK MXS 5.0 for purpose). Question: Would there be any problem if car stay without battery for some 24-48hrs? Is there any problem expected after I connect it back, since it has IBS and as many modern cars it is also full of electronics that don't like to be disconnected from battery? |
04-17-2022, 07:56 AM | #29 | |
Rep 666
if so, how does eco mode work? |
