08-22-2020, 05:46 PM | #397 | |
Rep 255
Also do u know how much you're making about on your tune? It's the exact same set up I was going for and I was aiming for 580-600 wheel but seems like everyone's number vary wildly. |
08-23-2020, 06:02 AM | #398 |
Rep 46
The E50 tune was fine until the OA temp got up to 100 degrees. The rail pressure would drop further in the heat. I got a revised map after my "final" map to drop the boost a bit. So now it runs with no problems but with a bit less power. Not ideal but at this point it is my only option.
If I had to guess I would assume I'm making a bit over 500 HP on my E50 tune, based on what I see others are getting for virtual dyno's with a similar timing/boost outputs. Do not let the fuel pump limit your goals. Get the Dorch stg2 for the FX-180, if you have high HP goals. I do not think you will get 600 HP with just the pump/turbo and tuning. To get 600 you will need meth or other supplemental fueling. |
08-23-2020, 05:03 PM | #399 | |
Rep 255
Interesting you say just over 500 wheel as I got 475 wheel virtual dyno on my 92 octane and Supr3me got his dyno on E50 the other day at 570 wheel so I would think you're more near 570? Unless that Pump is hindering more timing etc As for the fueling limits I'll definitely keep what you said in mind. Just weird because Dorch stage 1 says it can support up to 600WHP while Spool FX-150 has a decent amount of CC over their stage 1 so would have thought it would have been more than enough for using E50 for 570-600 wheel but guess not lol. |
08-24-2020, 07:24 AM | #400 |
Rep 35
Have got the TU pump And all supporting mods to run MHD ST2 hpfp e30. Dynoed at 518hp at the crank. Feels fast and cars running very well. Been looking at some custom maps lately would it be much faster as to where it’s worth the money to get a custom e50 tune? And what sort of power will I be looking at. I’m in the U.K. so ethanol is quite expensive as we don’t have it on pump. I buy mine in bulk 48 l at a time. Costs around 2.70 per litre. So obviously mixing it at 50 instead of 30 would cost me a lot more money. So would it be worth it.
08-24-2020, 08:14 AM | #401 | |
Rep 585
The TU pump won't handle more than about E37 with that tune/torque/AFR profile from what I've seen of others logs. For more power you'll need a turbo upgrade, bigger HPFP and custom tune. Even then not much gain going past E40. |
IMS-340C394.50 |
08-24-2020, 08:40 AM | #402 |
Rep 216
Man was this thread a read lol. Anyways with advancements in tuning and other performance related parts the limit that we're seeing with pump gas is only going to increase. That being said there seems to be a general consensus that you run out of octane when pushing 600whp. I've seen guys in the drag racing scene run RaceGas concentrate or somewhat more recently BOOSTane. in the small amount of research I've done into these products they're not the typical parts store "octane booster". With BOOSTane bringing up 93 octane to a 101 octane level and RaceGas bringing it up similarly (more is needed though). My question is then. Why has no one looked into running a higher octane fuel?
I travel a lot so having to blend into an e50 or using e85 would be unreasonable for me. Tossing 6 cans of RaceGas or BOOSTane in the trunk is a much easier option. As of now my best option is to simply run two different tunes. One for raceday and one for commuting. Links for reference https://www.enginelabs.com/engine-te...-adds-24-rwhp/ http://motorsports.mybigcommerce.com...gas-ultra-can/ https://boostane.com/product/boostan...ctane-booster/ https://f87.bimmerpost.com/forums/sh....php?t=1506904 Last edited by TheFanatic; 08-24-2020 at 09:07 AM.. Reason: adding a bimmerpost link |
Uni-Rapide71.00 |
11-19-2020, 12:39 PM | #404 |
Cheapskate
4447
Rep 4,993
i'll share my video too once it's posted tomorrow
SC_B5X403.00 fake_bimmer6.00 |
11-20-2020, 12:44 PM | #406 |
Cheapskate
4447
Rep 4,993
Here's the thread. Appreciate the share.
https://f30.bimmerpost.com/forums/sh....php?t=1776676 |
SC_B5X403.00 |
11-21-2020, 01:18 AM | #407 | |
Built Motor F30 340i
403
Rep 257
kern4174446.50 |
02-10-2021, 12:33 PM | #408 |
Rep 187
Is this the same part as the upgraded Supra/BMW Pump # 13518631642
https://parts.daytonatoyota.com/p/To...oaAqqcEALw_wcB |
02-10-2021, 01:34 PM | #409 | |
Cheapskate
4447
Rep 4,993
02-10-2021, 01:52 PM | #410 | |
Rep 1,453
2022 CT4-V Blackwing 6-speed
03-29-2021, 03:39 PM | #411 |
Rep 275
Do you think you can max out a Vargas GC with the spool Fx-150?
Instagram- f30_luca
Modifications: Custom E50 Tune by David Shoup, B58TU Fuel Pump, Armytrix Exhaust, VRSF downpipe, Big Boost Charge pipe/bov kit, CTS intake, H&R Springs/B8 Struts, 335is Clutch Upgrade |
06-03-2021, 06:32 PM | #412 |
Rep 164
Does anyone know the B58 XDI-35 hpfp flow specs? It seems to be considerably more expensive than the other comparable hpfp offerings and I haven’t found the flow numbers against it’s competitors. Thanks
06-04-2021, 02:11 AM | #413 |
Rep 420
GC - fx180, Dorch 2 . E30/40 Ok.
M140IX. Turbo Pure 800 Cast.
06-04-2021, 02:35 AM | #414 |
Rep 1,453
It's 1.22 cc/rev for the N55 version so maybe somewhere around there? Couldn't find any specs for it either. It's listed at $2.4k. For that price, it would need to outflow the Dorch Stage 2 and FX-180 by a lot lol.
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 Last edited by G.Newt; 06-04-2021 at 03:23 AM.. |
06-04-2021, 12:42 PM | #416 |
Cheapskate
4447
Rep 4,993
Adding some data to the mix. I finally got some dynojet results with the TU pump. This is a great example that you can reference if people are curious about how much HP the TU pump can support. The key to these results is 1. a bigger turbo that can flow more air in high RPM, and 2. finding the optimal fuel mix (bigger turbos will need less E85 to reach it's limits). Hope this helps.
06-04-2021, 03:42 PM | #417 |
Rep 1,453
Thanks for finding that out. The only site I could find that sold it was from UK and was $2.4k USD including tax and duties, etc. I see no reason to get it when Dorch Stg 2 is $1,700 and the FX-180 is $1,800.
06-06-2021, 05:18 AM | #418 |
Cheapskate
4447
Rep 4,993
The main reason I wouldn't get it is because everybody testing it had poor results. That's why you never hear about it.
