10-29-2019, 03:22 AM | #45 | |
Cheapskate
4447
Rep 4,993
There are some F8x guys that have had the arms for a while, but mostly in the rear. There are some long term reviews in their forums. |
10-30-2019, 03:06 PM | #46 | ||
Rep 205
Drives: 14 F30 335i xDrive
kern4174446.50 |
11-02-2019, 02:06 PM | #47 |
Rep 194
Can someone explain why the monoball on the tension strut is beneficial as far as turning goes? What exactly does switching out the hydrobearing for the monoball do? And why the replace the bushing in the tension strut vs the lower control arm (which I thought were the same thing)? Here are some resources I found for reference:
Close Look at F30 328i Suspension by Insideline! https://f30.bimmerpost.com/forums/sh...d.php?t=648418 And https://www.realoem.com/bmw/enUS/sho...diagId=31_0993 Granted the first link is RWD and I am more interested in the switch for my xdrive. Someone shed some light on this! |
11-03-2019, 06:35 PM | #48 | |
Rep 785
Both can be replaced to make adjustments to the suspension geometry - there are bushings for the LCA which can increase front camber, and there are solid rubber bushings or monoballs (sealed bearings) available for the tension strut. Hopefully I got them all sorted out this time. It's a confusing jumble of names up front. To your second question - the hydro bushings are designed for a comfortable ride. They're soft and squishy to go along with the general design philosophy of the f30 chassis, which is to isolate the driver from the feel of the road and give it a plush, floating type of ride. Unfortunately this also results in a vague and imprecise steering experience since all of these soft parts sit between the wheels and the steering components, in a way. They allow a lot of deflection or movement (slop) which is not really ideal in a high performance driving scenario. Most of the folks on these forum threads are doing these mods to reduce the vague/numb feel. The solid bushes resist the deflections resulting in a more precise steering. Sharper turn in, easier to place the car on the desired line, increased feedback from the road. The increased negative camber improves the front tire grip during high speed cornering. All result in more predictable handling and increased driver confidence.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
pkiledj46.00 |
11-28-2019, 04:15 PM | #49 | |
Rep 194
11-28-2019, 04:39 PM | #50 |
Rep 3,539
Uncalibrated alignment rack. So the rack says you have x measurement, but you really have something else.
For example, I went to a place once that said they aligned my toe to 0.05deg in each side, but when I went to a properly calibrated rack it was more like 0.35deg each side. |
pkiledj46.00 |
11-29-2019, 12:51 AM | #51 | |
Rep 194
About the KMAC tension strut monoball - how did you determine the amount of caster to run? And how did you match the left/right caster? Did you literally just put the left and right tension struts side by side and eyeball the monoballs to get them to be symmetrical? My mechanic is talented but I can't speak to his knowledge of suspension performance. My point is, when he installs the monoballs what should I tell him as far as "put the hole at ______ o'clock" |
11-29-2019, 02:28 AM | #52 | |
Rep 3,539
MacklinUSOB518.00 |
11-29-2019, 02:36 AM | #53 | ||
Rep 194
If you are just changing the angles that the wheels turn, why/where would it rub. I am lowered on Dinan springs but the drop is very minimal, especially in the front. Can you explain the idea of adding caster from a handling perspective. Sorry for the newb questions! |
