10-19-2019, 02:59 PM | #1 |
Rep 194
How to make car more tossable
I have a f30 335ix 6MT. Love the car but even with Dinan springs, bump stops, Shockware, car still feels as heavy as it is. Any advice on making the car feel more nibble? How about sway bars?
10-20-2019, 02:21 PM | #5 |
Rep 194
10-21-2019, 12:38 AM | #7 |
Rep 194
10-21-2019, 02:15 AM | #8 | |
Rep 681
2016 328ix F31 - SOLD!
2006 997.1 C4S |
pkiledj46.00 |
10-21-2019, 04:39 AM | #9 |
Rep 10,256
Just wanted to confirm whether your vehicle has M Adaptive suspension (since Shockware has been mentioned in the original post).
What attributes of "tossable" are you looking for? Neutral steering response? More responsive compression / rebound cycle? M Adaptive shocks even with Shockware cannot be improved beyond the initial design which has 2 settings: less than firm and more than firm. Shockware simply makes both of these settings more firm. My vehicle also has M Adaptive suspension and while I like it it doesn't provide crisp compression / rebound cycle like Ohlins R&T coilovers - not available for xDrive vehicles unfortunately. In other words, the suspension indeed feels "heavy" as a direct consequence of poor compression / rebound cycle response. Bilstein offers B4 Damptronic shocks which are a direct replacement for OEM adaptive shocks. I haven't yet seen detailed comparison between OEM adaptive shocks and B4 Damptronic shocks. |
pkiledj46.00 |
10-21-2019, 06:48 AM | #10 | |
Rep 2,666
Because to my knowledge, you can't mess with the control arms on the xdrives. |
10-21-2019, 10:43 AM | #11 | |
Rep 681
Basically, if you want to be low and run more than about -1.2 camber you should avoid LCA camber bushing to be safe. UCA bushings are fine and will only adjust caster if they are adjustable.
2006 997.1 C4S |
10-21-2019, 02:44 PM | #12 |
Modder of everything I own
147
Rep 491
i did a rear sway bar and rear subframe bushing inserts. I still have to do the front sway bar but I like how it handles. My coil overs are set really stiff as well.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
pkiledj46.00 |
10-21-2019, 03:48 PM | #13 | |
Rep 194
https://k-mac-camber-kits.com/Catalo...%20Catalog.pdf Check out page 10. It says "Inner Arm Camber Adjustable Bushes" and "Inner Thrust Arm Caster Adjustable Bushes." Sorry for the noob question, is an "inner arm" the same thing as tension strut aka UCA? |
10-21-2019, 04:35 PM | #14 | |
Rep 3,539
Additionally, I saw on Bimmerworld that SPL makes one too, but it doesn't have as large of a caster adjustment range or look as well sealed as K-MAC's.
pkiledj46.00 |
10-21-2019, 07:30 PM | #15 | ||
Rep 194
10-21-2019, 10:26 PM | #16 |
Rep 3,539
Much quicker steering response, improved steering feedback, and a more "connected" feeling with the car. People always complain about the steering feel on the F3x, and this remedies that to a large degree. You'll easily notice this in daily driving.
pkiledj46.00 |
10-22-2019, 10:40 AM | #17 |
Rep 1,286
I’m getting K-MAC 193616-8H FRONT CAMBER INNER ARM BUSHING and K-MAC 193916-7J FRONT CASTER THRUST ARM ADJ. INNER BUSHING installed on Thursday and hoping for great results.
There are no reports of issues with these 2 parts, correct?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
10-22-2019, 11:24 AM | #18 |
Rep 681
There are some issues if you're super low and max out the camber on those LCA bushings. But if you keep your camber around -1* or thereabouts when super low, you should be fine.
2006 997.1 C4S |
10-22-2019, 11:43 AM | #19 | |
Rep 1,286
Should I not have the shop set to max negative camber? Would -1 degree be a better choice? That’s not that much better over stock. Kinda disappointing because the that case I should have ordered camber plates instead.
10-22-2019, 11:55 AM | #20 | |
Rep 3,539
I'd also take a look/picture of your LCA and see how parallel it is with the ground. If it's pointing up from the subframe to the knuckle, tread carefully.
10-22-2019, 12:16 PM | #21 | |
Rep 194
Yes, please report back! Before/after pics would be great too! |
10-22-2019, 12:18 PM | #22 |
Rep 1,286
I’ll have the shop take your suggestion into consideration. Aren’t you running this exact same setup without issues? That’s your negative camber set to?
