07-01-2019, 02:03 PM | #1 |
Rep 49
Drives: BMW G20 330e M Sport
Interior rear view mirror compatibility - from G30 to F30
I guys,
I don't know if someone did this kind of switch or if you know but I want to change the interior rear view mirror from my F30 so I was wondering if someone know if the interior rear view mirror from G30 is compatible with F30? Thank you Last edited by Scrupix; 07-01-2019 at 02:21 PM.. |
07-01-2019, 02:14 PM | #2 |
Rep 10,473
07-01-2019, 02:23 PM | #3 |
Rep 49
07-04-2019, 12:28 AM | #4 |
Rep 6
G20 maby? And most of the mirrors that come from 2018< cars with kafas2 kamera made inside the mirror is quite rare yet. Maby nobody did it actualy depends on the windshield also
08-06-2019, 09:07 AM | #5 |
Rep 49
Hi guys,
I managed to change that ugly and old interior mirror, now it looks much cleaner and better. Is more or less complicated as in some cases is necessary to remove that support from the mirror and replace it with the one that you have, on my case that was the solution but for sure is much more nicer than the previews one. |
08-12-2019, 06:38 AM | #6 | |
Rep 1,067
08-12-2019, 10:01 AM | #7 | |
Rep 49
What do you mean by compass? As related to plug and play is more or less The idea is that if you will use the support from G30, the black cap will not fit anymore to cover the support therefore I replaced the support between them, basically I kept the support from my F30 and replaced only the mirror with that frame that you see (I pullout the mirror back where is that round and replaced like this) If you need much details on this, I can send you some pics to show you better what I mean. |
08-25-2020, 11:48 PM | #8 |
Rep 67
There is an original F30 mirror made in G20 style. They created it close to end of F30 generation production and it is an option - however you can buy and install it
Here is part number 51 16 2 471 107 Picture |
08-26-2020, 03:17 AM | #9 |
Great Teacher
1085
Rep 1,305
Drives: 06 e91 325ix
Y’all make me feel old. I remember upgrading to the ultra svelte (by comparison) e83 mirror many years ago on my e34. And thinking how nice and compact the f30 mirror was compared to the old 3 pin manual e34 one!
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
08-26-2020, 04:03 AM | #10 | |
Rep 3,869
I see it is with a garage door opener. Wonder if it is compatible if the original one did not have a garage door opener? Very little information available....
08-26-2020, 04:08 AM | #11 |
Great Teacher
1085
Rep 1,305
Garage door opener is always a stand-alone item in the body of the mirror, it jsut borrows power and ground. So yes.
08-26-2020, 04:46 AM | #12 |
Rep 3,869
That's what I thought. Great, although I would have to modify my Hörmann garage door to be less secure in order to enable use of homelink.
Anyone know if the replacement is easy?
08-26-2020, 11:48 PM | #13 | |
Rep 67
1) Remove mirror cover 2) Disconnect mirror connector 3) Pull down (in parallel to the windshield) interior mirror in order to remove it 4) Snap-in new interior mirror (pull up in parallel to the windshield) 5) Connect mirror connector 6) Return back mirror cover 5 minutes of work... |
08-27-2020, 01:17 AM | #14 |
Rep 3,869
Good to hear! Thanks!
Just to clarify: - Are the mirror cover parts easily opened (separated), without damage? - when you say "parallel", you probably mean perpendicular to the windshield....? Just pull the mirror or does it need to be in specific position / turned or twisted in specific way?
09-07-2020, 03:41 AM | #15 | |
Rep 67
- If you look at the car from side it is in parallel towards down. No twists Here is pictures of this mirror on my car |
10-26-2020, 08:45 AM | #16 | |
Rep 3,869
I received mine, but I notice a vertical line just left of the centreline... On some photos I found online, the same line is recognisable..... Could you please confirm whether this is a standard "feature"!? Looks odd!! t is more visible under particular angle and in bright conditions. Here a photo of another unit from the internet:
10-29-2020, 11:35 PM | #17 |
Rep 24
10-30-2020, 04:31 AM | #18 | |
Rep 240
To make a long story short, I refused accepting either mirror and they refunded my purchase price. Something to note, if you car has the original KAFAS camera installed for high-beam assistant, it'll disable the system. Unfortunately there's no way to make it work because the first generation KAFAS camera has a printed circuit board soldered inside the your current mirror to make the system function. If you're ok with disabling the high-beam assistant, or if your car wasn't equipped with the camera, then it'll work. If your car is equipped with the KAFAS2 camera system, the mirror should be plug and play with no coding required. Last edited by zibbit; 10-30-2020 at 04:37 AM.. |
10-30-2020, 04:37 AM | #19 |
Rep 3,869
zibbit
Thanks for the feedback, zibbit! This is really odd!! I just ordered a second unit, hoping it will be better. I haven't mounted the first one still. I have browsed the net and just yesterday found also a video showing the mirror from different angles. My feeling is that this line exists on all (for whatever reason), but is by far not as visible and noticeable on all as it is on mine. I can post the link to the video a bit later but if you look very carefully, you may see it vary vaguely once or twice, but on mine you simply can't not see it... it is quite extreme. I will report once I get the second unit... I guess in a week or so. This is frustrating. Regarding KAFAS - I have an LCI model, so I assume I have the KAFAS 2.... The mirror P/N is given as compatible for my vehicle.
10-30-2020, 04:44 AM | #20 | |
Rep 240
KAFAS 2 has "connected drive" stencilled on the outside of the glass and is mounted above the rearview mirror mount. |
10-30-2020, 04:49 AM | #21 |
Rep 3,869
That is one explanation. But since not everyone having the retrofit mirror is complaining (no other complaints found) and it does not look as bad on the photos and videos I found online, the likely explanation (hopefully) is that the line is not as bad on all units....
Look at this and tell me what you think...:
11-03-2020, 07:08 AM | #22 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
I wonder if this would work on a M2. I have a 2017. I love the car. The mirror, not so much!!
Rick
