BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Valve Cover Gasket Replacement on a F30 335i N55 DIY
European Auto Source (EAS)
      11-09-2018, 09:29 AM   #1
endlesss
Enthusiast
endlesss's Avatar
29
Drives: 2008 M3 Sedan
Hey all,
I have seen a lot of valve cover gasket DIY from older E90 N54 cars, but I couldn't find anything complete for our F30 generation N55 motors. Mine was leaking recently so I decided to replace it and document the process along the way. When I had my N52 a video like this helped a lot, so hopefully this helps some of you as our cars get to that BMW age where gaskets start leaking..
Appreciate 15
Logicoeur386.50
jh_f30979.50
bkdore93.50
Seba77W291.50
BashShah188.00
nickf3057.00
Polo088161155.00
atlguy24.00
spencers168.00
kern4172362.50
ali820222.50
      11-09-2018, 10:15 AM   #2
pdegene
Respect My Authoritah
pdegene's Avatar
Drives: 2014 335i M-Sport
Thanks for this!!
2014 335xi M-Sport 6MT: Estoril Blue II, BM3 Stage 2, Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC, M-Sport Brakes.
      11-09-2018, 01:28 PM   #3
jh_f30
jh_f30's Avatar
980
Amazing! I was just looking for this DIY last week. Thanks man!
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~HR Sport Springs~CF Rear Lip Spoiler~Active Autowerke OBD Flash Tune Stage 2~
      11-10-2018, 02:23 PM   #4
endlesss
Enthusiast
endlesss's Avatar
29
Originally Posted by pdegene View Post
Thanks for this!!
Glad it helped!
      11-10-2018, 02:59 PM   #5
phat8186
phat8186's Avatar
Drives: F30 335xi EBII E92 335i AW
Your a boss for this one, mods should def sticky this here even though it can be found now in youtube.
      11-10-2018, 04:35 PM   #6
Seba77W
Seba77W's Avatar
292
Drives: BMW 435i Xdrive Coupe
Very nice
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
      11-10-2018, 04:46 PM   #7
perryo91
perryo91's Avatar
Uganda
280
Drives: 335
Thank you very much for posting this, I just got this done under warranty (thank jesus) because this looks like a decent 3 hour job for me. I was smelling oil and seeing smoke coming from my cat area just like you described too. After getting down and looking through the underpan of my car I saw fresh email way up in the engine through a little gap through the underpan.
Hi
      11-11-2018, 06:38 PM   #8
47Straight
Drives: 2013 BMW 335i Sportline
Awesome timing. I need to do this job soon. Much thanks!
      11-11-2018, 10:57 PM   #9
Sea-Tac
Sea-Tac's Avatar
Drives: 2108 X3 xDrive30i
Good clip. Thanks.
      11-12-2018, 10:15 AM   #10
atlguy
atlguy's Avatar
24
Drives: 2014 335I MPPK
Thank you!!
      11-19-2019, 12:43 AM   #11
percychow
BMW CCA Member
141
Drives: 2015 435i M Sport
When are you guys seeing valve cover gasket failures? Mileage-wise?
      11-19-2019, 01:29 AM   #12
jh_f30
jh_f30's Avatar
980
I did mine at 113k. Probably could've done it sooner, but at about 110k is when I started really noticing the burning oil smell after a drive.
percychow141.00
      12-04-2019, 02:54 PM   #13
dougt.ah3
dougt.ah3's Avatar
Drives: AH3 Msport; Z4 35is; F150 XLT
Noticed the smell today and appears to be the valve cover gasket. Car has 113,500 miles.
Thanks for creating the video ... very helpful and easy to follow.
Recommendation to those replacing their VCG. Highly suggest removing the coolant expansion tank hose as it is very brittle and will break if you happen to put pressure on the line. Mine did break at the expansion tank.
______________________________________________
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 1 | ER FMIC | FabSpeed Catted DP | ER CP |
percychow141.00
      12-06-2019, 03:47 PM   #14
percychow
BMW CCA Member
141
Thanks guys, super appreciate the feedback. I was warned by a local shop that this was coming and it's not as easy as the E36/S5X block - more stuff to unhook/onbolt. I'm at 60k so looks like there's some time to go.
      12-06-2019, 04:58 PM   #15
fuse27
Drives: 2013 335i xDrive
I'm at just short of 80k miles and I'm due. And there's another gasket issue (oil filter?) that made my Indy shop quote $2500 for all of it. At least that includes a new valve cover.
Current: 2013 BMW 335i xDrive | Mineral Gray Metallic | MPPK | M Performance exhaust | Dinan Stage 3 | Brixton Forged CM10
      12-07-2019, 11:51 AM   #16
jh_f30
jh_f30's Avatar
980
Oil filter housing gasket is a common weak point (along with the oil cooler gasket). Not too difficult if you want to take a crack at it yourself. Gaskets alone are only about $20-30. A handful of tools and a couple hours and you could save upwards of $1000. My local dealership quoted me around $1200, did it myself for under $100 all in.
VCG is substantially more complex. But with some research, still very DIY-able. Guess it comes down to your ability, willingness, and desire to do your own wrenching. If you do, you could trade some of your time to save about $2000.
Wgosma270.50
fuse274.50
      12-07-2019, 08:26 PM   #17
Fredo
Drives: 2012 335i
My mechanic replaced the valve cover on my 2012 F30 335i at 85k miles. FYI, this is the list of parts he replaced:
11127570292 N55 valve cover
11367609963 Valvetronic screw (2)
11127599753 Vent hose
11377502022 Valvetronic seal
      12-08-2019, 10:59 AM   #18
fuse27
Good to know. I researched VCG replacement, and with how involved and time consuming it is for an experienced tech, I think it's just outside of my comfort zone. I hadn't yet looked into what the oil gasket repair would take, but perhaps that's more my speed. I replaced the spark plugs in the B8 S4 I had prior to the F30, so I'm not completely inept. And saving myself $1k would definitely be worth it. Thanks for the suggestion.
      12-08-2019, 11:32 AM   #19
Wgosma
Drives: 2012 F25 X3 28i (N52)
Just did both gaskets on N52 (no turbo); OFH gasket easy, VC another issue...after doing it I think $750 for Mr Mechanic labor would have been more enjoyable idea 😉
Look at the OFH DIY stuff, there is one bolt under intake manifold that requires removal - think it can be removed w/o touching manifold, but double check on that point.
