BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Jb4 and leaving maf unplugged?
      01-04-2019, 07:28 AM   #1
03redtypes
Drives: 2011 535i Msport
Before anyone starts in saying “bootmod3 is way better than jb4 etc” Jb4 works the best for me for what I’ll use it for, and is still a good product. I was lurking around not long ago, but believe it was on here. I thought I had read where if you’re running Jb4 and intake to keep the maf unplugged? Is this correct? If so what’s the exact reasoning behind it, and assuming it’s not going to mess with anything? Will be on a 15 335i
Thanks!
      01-04-2019, 07:34 AM   #2
mbanks21
Drives: 2015 335i MSport
If you have an aftermarket intake that doesn't jive with the JB4 (Injen for example) then unplugging the MAF may solve it
      01-04-2019, 07:52 AM   #3
03redtypes
Okay, which produce rough idle, hesitation? Will
Be running a burger motorsports with it.
      01-04-2019, 08:28 AM   #4
mbanks21
All I know is I have JB4 with an Injen intake and with the MAF plugged in the car struggles, with it unplugged it's fine
      01-04-2019, 09:37 AM   #5
Zentan
Drives: 2019 M2C / 6MT / SO
I have a 14 335i with JB4 and an Injen intake. I have the MAF unplugged. When it's plugged, it has rough idles and RPM spikes when going through gears but all of that disappears when MAF is unplugged.
      01-04-2019, 10:50 AM   #6
Wires
Drives: 2016 340i xDrive
Considering the MAF is required by the ECU to hit proper performance and efficiency targets (it defaults to a backup of alpha-n which is more of a bandaid with no MAF), you'd be better off ditching the sh*tty intake.
You're losing all air density and air temperature compensation with no MAF. It's like running a carb'd vehicle at this point.
      01-04-2019, 11:12 AM   #7
mbanks21
the MAF is still there, just the sensor is removed. The ECU gets minimal information from the MAF sensor. Terry at Burger Tuning was the one that suggested I unplug the sensor
      01-04-2019, 11:43 AM   #8
Wires
The design of the MAF is to have a couple heated elements which get cooled by incoming air. The ECU can determine volume/density of the air flow by the rate of those wires coloring, and meters fuel accordingly. It's the primary device for determine how much fuel to meter (it measures lbs/hour of air, injectors spray lbs/hour of fuel).
It allows the car to get optimum power regardless of air density/temperature. It also compensates for changes in engine air flow characteristics as the everything starts to wear.
Perhaps from a drag strip WOT perspective you do not require it. From a daily driver perspective, I'd disagree. But to each their own...
