12-14-2014, 02:01 PM | #202 |
Rep 19
Hi, i’m having problems when i run the FSc Generator.exe - i get a Microsoft.NET Framework error saying i’m getting an unhandled exemption with the following error
“Road is an unexpected token Expecting White Space. Line 815, Position 75” if i continue rather than quit, i can brows to my FSC file but the map list is empty. Any ideas? Ive attached my FSC file if anyone can help out, just rename to fsc please. Thanks |
FlorinQCK-2.50 |
12-14-2014, 03:50 PM | #204 | |
Rep 1,892
FlorinQCK-2.50 |
12-16-2014, 04:22 AM | #207 |
Rep 20
Hi guys,
i would need a clarification. The installation of a new map require much time, only the panel lit or also the engine lit? (I hope engine off ) I don't know if after some minutes the panel turns off in automatic while the system uploading the map. What I have to do? Thanks. |
FlorinQCK-2.50 |
12-16-2014, 06:41 AM | #209 | |
Rep 20
Thanks Xeones You've used USB HDD with files necessary to install map, only those or were present also another files and folders? I ask it because I've a USB HDD but within I've a lot of files and folders that I would prefer don't delete. The navigation software of the car automatically detects the files to be installed? Thanks a lot. |
FlorinQCK-2.50 |
12-16-2014, 08:27 AM | #210 |
Rep 6
Yes.
My HDD disk was full of files and folders. The car takes care of the files and folders needed. Just be sure you have those files and folders properly placed. I do not have the files with me right know but there are two or three files which need to be in the root the same way than some other folders (named 1, 2, 3 and 4 I think). It does not matter if there are other files or folders in the root. Ciao |
FlorinQCK-2.50 |
12-16-2014, 09:20 AM | #211 | |
Rep 20
Hola |
FlorinQCK-2.50 |
12-22-2014, 02:51 PM | #213 | |
Rep 11
Thank you! |
FlorinQCK-2.50 |
12-22-2014, 04:50 PM | #214 | |
Rep 1,894
FlorinQCK-2.50 |
01-14-2015, 03:07 PM | #218 | |
Rep 1
I newly bought a BMW E90 with iDrive (CIC) but the Navi dates back to 2008 is there any person who can provide me a FSC code ? I appreciate a lot. Cheers, Milad |
FlorinQCK-2.50 |
01-17-2015, 12:26 PM | #220 |
Rep 40,731
No, E-Sys cannot generate FSC Codes. Run your Generator in an XP 32 VM.
FlorinQCK-2.50 |
