05-28-2015, 03:07 AM | #333 | |
Rep 95
Let me study this a little further and see what I can do. Perhaps this virus is not so bad... |
FlorinQCK-2.50 |
05-30-2015, 02:22 AM | #335 | |
Rep 1,894
FlorinQCK-2.50 |
05-30-2015, 02:43 AM | #336 | |
Rep 95
Still haven't tried it. Only today I will. I'll post my findings after. |
FlorinQCK-2.50 |
05-30-2015, 04:26 AM | #337 |
Rep 40,668
I have, and it works fine, and I would hope it is correct considering it comes straight from BMW AG's latest official 2015 04 08 Lookup.xml file.
FlorinQCK-2.50 |
05-30-2015, 04:36 AM | #338 | |
Rep 1,894
FlorinQCK-2.50 |
05-30-2015, 05:15 AM | #340 |
Rep 40,668
And for 2015-2, you are certain you are using SWID 0028000A?
FlorinQCK-2.50 |
05-30-2015, 05:31 AM | #342 |
Rep 40,668
PM me short VIN you are using and the code you are getting for both 2014-1 and 2015-2.
FlorinQCK-2.50 |
05-30-2015, 05:47 AM | #344 |
Rep 40,668
I get same codes, but you send me 2014-2 code not 2015-2. 2014-2 Code won't work for 2015-2 map.
FlorinQCK-2.50 |
05-30-2015, 07:15 AM | #345 |
Rep 11
Hi all!
I have successfully updated maps to Europe Next 2015-2 using a well known method (downloaded FSC file from car and then used map code generator). I am just curious, how map update code can be generated without access to the car, only with a VIN number? Is it possible only having access to BMW servers via BMW dealership or it can be done offline with a special software? |
FlorinQCK-2.50 |
05-30-2015, 07:17 AM | #346 | |
Rep 40,668
FlorinQCK-2.50 |
05-30-2015, 07:32 AM | #348 |
Rep 40,668
No. Few have access. Most are actually re-sellers after buying file from those with actual access.
FlorinQCK-2.50 |
05-31-2015, 09:23 AM | #350 | |
Rep 95
After all I was unable to do it because I was hoping to use my hardrive as a USB PEN to upload the map but it didn't work. And I don't have 32gb USB PENDrive. This means I need to buy or borrough one. So still need more time to try it. Btw, is there a way of using several USB Pendrives smaller than 32gb? Using for instance 3 x 8gb USB pendrives? If so, how would that be possible since the map is not structured like that? Is there a map version (EUR PREMIUM 2015-2) splitted in 3 volumes? |
FlorinQCK-2.50 |
06-01-2015, 10:35 AM | #352 |
Rep 37
F25 CIC
Hello, fighting a little problem. I have a 2013 F25. I am using the latest NAV NA-2015-2.
I extracted my 1B using SW_ID. I renamed it and attached it as a .txt doc here. At first, I was not getting a valid code because I was using the NBT command line. After a few codes I found the error in my ways. I switched to FSC. So I tried fsc L976806_001B0001.fsc 0x2d 0x07 L976806 Now I get: version after create() = 0xD1. Various threads suggest a base64 problem. I've tried both encoding and decoding the file without change. Any suggestions? |
FlorinQCK-2.50 |
