07-29-2016, 11:24 AM | #1168 |
Rep 40,727
0x2D 0x29
07-29-2016, 12:36 PM | #1170 |
Rep 40,727
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 08-01-2016 at 06:44 AM.. |
07-31-2016, 08:49 PM | #1173 |
Rep 69
trying to generate the FSC code for F25 X3, NBT North America Next 2016-2, but keep getting the follow error when I go to run NBT.exe
Error reading DE FSC file de.fsc I created an entry in the lookup.xml for NA Next 2016-2 using 0xA80x27 as the fscshort code. de.fsc was obtained through esys. What am I missing? Is there a step before running NBT.exe to make the file readable? |
FlorinQCK-2.50 |
08-01-2016, 06:31 AM | #1175 | |
Rep 69
Thanks for the help! |
FlorinQCK-2.50 |
08-01-2016, 06:46 AM | #1176 |
Rep 40,727
It was Typo. A8 should be given as it is always A8 for North America NEXT. The question is the Upgrade Index, and 28 is correct.
FlorinQCK-2.50 |
08-03-2016, 10:08 AM | #1178 |
Rep 157
I am trying to generate the 1DE file for MY2014 F30 NBT with NEXT maps via esys and I am getting the "Base variant not determinable G175 error". Steps I took after connecting Esys (using F20 as F30 is not listed)
1. Enter 0xA8 (also tried 0x63) - received the error when i click on identify. None of the other fields populate as in the instructions they should. A couple questions: which FSC.bat file do I edit? the one in the 2017 folder ( i assume 2017 folder because of the version of maps, not car right?) Do i put the fsc.bat and fsc.exe, fsc_generator and swid_reader files all in the root of EC-Apps? Do i need to edit both the fsc.bat in EC-Apps and 2017 folder? Perhaps i need to try 0x28 instead as posted above? Thank you in advance! |
FlorinQCK-2.50 |
08-04-2016, 07:49 PM | #1180 |
Rep 40,727
0x2D 0x29
FlorinQCK-2.50 |
08-06-2016, 09:59 PM | #1181 |
Rep 188
I finally got it to work. I figured out that the program I was using to convert my fsc to base64 wasn't saving my file correctly. The way it was saving by default was by doing a multi-line out put instead of a single line...
Lifetime maps, some of my friends will be really happy tomorrow thanks to everyone here for their efforts! |
FlorinQCK-2.50 |
08-07-2016, 12:37 PM | #1183 |
Rep 40,727
No.
08-07-2016, 04:02 PM | #1184 |
Rep 157
I was able to generate the 1DE file and get it into the generator, after completing the DOS commands per the previous instructions earlier in the thread. But for some reason, i can only see map versions up to NEXT 2014-2. Is there something i need to change to get to 2017-1 or even 2016-2?
Maybe i am using the wrong generator? Any help is greatly appreciated! Last edited by Jetsurly; 08-07-2016 at 04:09 PM.. |
FlorinQCK-2.50 |
08-07-2016, 04:09 PM | #1185 | |
Rep 40,727
08-08-2016, 07:32 AM | #1188 |
Rep 40,727
I don't agree that it is better. Considering the FSC Code is displayed in ISTA/P, I would prefer to have a Single FSC Code that matches what you would get from BMW AG. It is no trouble to generate a proper code twice per year.
FlorinQCK-2.50 |
