12-08-2018, 09:18 AM | #1 |
Rep 279
brake upgrade
hey guys so I upgraded my rotors, pads and brake lines
rotors are from pagid the dimple and slotted I get this weird noise and it's annoying I had the embarrassing squeaking and now no more squeaks but have this embarrassing chatter sound I guess not sure what to do/check at this point video-https://vimeo.com/305221617 video rolling-https://vimeo.com/305411034 this is my setup Last edited by pongkin; 12-09-2018 at 10:40 PM.. |
12-12-2018, 03:48 AM | #6 |
Rep 8,466
You may find that its the dimples in the discs. The BMW MPPK brake upgrade that I had on my F31 330D for a while had dimpled discs; no slots. With the windows down I noticed a continuous ppfpfpf noise especially if it reflected off hard surfaces i.e. parked cars or (very) nearby buildings.
If it's more of a thrumming noise it's likely to be the grooves in the discs gently cleaning the faces of the pads.
12-15-2018, 01:30 PM | #8 |
Rep 10,229
For daily driving, slotted / drilled / dimpled rotors are not needed. For track duty, more so - since rotors and calipers get hotter and need to be cooled more aggressively.
Once the pad are bedded the noise will subside but unlikely to go away completely. |
Billfitz8169.50 |
01-08-2019, 03:50 PM | #11 |
Rep 279
nope still there, I'm going to look into it again when i have time. if still persist ill be on the fringe and just go back stock blanks.
what id like to know is is it the front or back brake pad have the free play? |
01-22-2019, 10:58 AM | #12 |
Rep 110
Apologies to bombard you with questions! |
01-22-2019, 01:31 PM | #13 |
Rep 1,934
For a slotted and dimpled 340mm rotor you'll have to look at Stoptech, R1, and Adams Rotors, that I know of. BMW doesn't make one, and so many oem replacement suppliers don't make one either. The dimensions you need are 340x30mm for the front, or 370x30mm depending on what you have now, but all sets will bolt on regardless of what you have now.
BMWiltshire63.00 |
01-22-2019, 04:07 PM | #14 | |||
Rep 110
