11-17-2018, 07:39 AM | #1 |
Rep 351
Dash Cams - UK options
Black Friday has struck, and it was in good time after picking up a AUC car.
I have reserved two of the following https://www.argos.co.uk/product/8624...referrer=COJUNNextbase 212G, with what I was after “Parking mode”. I’m just as concerned about the car parked as it is during motion. My question is, apart from minor ‘nice to have’ features, would I be missing any important bits for a claim or using footage as evidence/figure out what has happened overnight etc etc. I would need one front and one rear, and will use the fuse guide on the forum to wire with a box that doesn’t drain the battery. What are the differences between the above, more premium and the likes of an Aldi equivalent dash cam? I understand field of view, camera angle and lens quality but beyond this? Also, all in one kits (front and rear) or two independent dash cameras? E.g https://www.very.co.uk/nextbase-512g...utm_content=na (Sorry, first BMW and dashcam too, so not really knowledgable on this front). Last edited by KTE; 11-17-2018 at 12:33 PM.. |
11-17-2018, 03:32 PM | #2 |
Rep 187
Drives: 330d f31 msport
I have a next base 312g fitted a few weeks ago but not checked any footage yet ,
It was which best buy !! Earlier this year . Piece of cake to fit and set up , one addition I would have is the polarizing filter to remove the bonnet glare . I previously had a front/ rear dual cam but all the footage was corrupted by the camera itself so binned it . Oh yea !! This camera is also recognised by the insurance association , so qualifies for a bit of premium discount !!! |
11-17-2018, 03:57 PM | #3 |
Rep 649
The 512GW has the polarising filter. I have the 512GW & GWR combo fitted, works brilliantly, I'd take that over the two separate cams. I like that the rear camera is very small and unobtrusive.
Cheers Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
11-18-2018, 04:35 AM | #4 |
Rep 757
Not aimed at you but...
Does anyone else find that every bad driver on the road seems to have a dashcam? All the 30mph in a 60 limit type drivers seem to have them. |
11-18-2018, 04:27 PM | #6 |
Rep 736
I subscribe to which and went for the 312GW (which scores 72%). The 212 scores 71% and the only omission seems to be GPS, which may come in handy if I have to use footage in a claim.
PM me and I'll be happy to copy and paste the entire review of each and any other if it helps. |
11-18-2018, 04:47 PM | #7 | |
Rep 351
It seems the G is for GPS, and W for Wifi.. who would've guessed haha . The 212 has 2 versions, one with GPS and one without. My only concern is how big any of the above may be in the rear. Don't want it to be an eyesore or too obvious. |
11-19-2018, 03:03 AM | #8 |
Rep 785
11-19-2018, 10:21 AM | #9 | |||
Rep 351
Yes, the above does not narrow it down to it being their fault each time, but the dash cam would definitely tilt the scales in a dispute Quote:
£0 policy amendment charge. . Last edited by KTE; 11-25-2018 at 11:01 AM.. |
11-25-2018, 10:59 AM | #10 | |
Rep 351
Following reviews, others seem to have an additional cable to piggy back an ignition further to the live.
With the Nextbase hard wire kit, there are only two cables, a black spade which is the earth, I will clip that in under a washer/nut in the fuse box area, and a red power to connect to live or ignition depending on preference it would seem.. The cable only got to behind the rear seats before the block adapter on the hard wire kit, luckily there is enough wire from this little box to get to the fuse box, just need to figure out the best way to keep this in a safe position. Question is, Fuse 161 is "Live+" as per some other posts in threads, I will be using this with the Parking mode. I also seem to be very few who use ASS (stop start), providing the G sensor isn't activated throughout the night, I shouldn't expect a flat battery after say a week of not driving? I can't seem to find anything to adjust the voltage cut off point too Edit: For anyone venturing across something similar for the first time... Parking mode it seems can be used whilst connected to a Ignition fuse, however if the camera repeatedly captures any motion for extended periods of time (cumulatively even over say a week) then you can no longer record as this would all be done on the internal battery, which would have depleted. Apparently perm live seems to allow the 312GW to record all the time, whereas I initially thought it would only do so when the G sensor is triggered.. Confirmed as a feature only for the 412GW (and maybe upwards) by Nextbase on a dashcam forum.. Quote:
Different scenarios would be the below in different variants. Vehicle is not driven for a week, this would discharge the internal car battery for every recording done by the 412GW, unlikely there should be so many instances where the G sensor is triggered unless of malfunction or over-set sensitivity. Hardwire kit protects to 11.2v (very low for most if not all F2x/F3x BMWs!), other brands seem to be adjustable. Seems this wiring is quite easy to create or purchase in parts. I wouldn't be the person at this time to provide such a guide. Once the internal car battery is at the minimum threshold, the dashcam internal battery continues to be used for any further clips. Likewise, the 312GW would run out of its own device battery if recording excessively (20 clips + say). Once out of juice, can no longer record if any situation arises. Both situations are unlikely, and the latter does not cause any concern for vehicle battery health. However if settings/hardware are tested prior to final fitment, a long 2 week holiday break may warranty a switch over to permanent live? Or a freak repeat situation of extended vandalism.. Pros and cons to it all, I'm sticking with what the hardware is capable of and what I want to happen. Ignition live with parking mode. My first hand experience for any 'newbies' like my self. Last edited by KTE; 11-25-2018 at 06:10 PM.. |
11-30-2018, 07:19 PM | #11 |
Rep 351
Saw a post about not wiring in series but parallel, whilst the concept is understood in theory I’m just no sure about how it’s been wired. I spotted both fuses in the same direction with the red cable coming away from the fuse
Also, second nextbase going in soon, I’ve used 141 already, I noticed 143 was listed next to it on the fuse box map, anyone had experience with that fuse #? |
12-30-2018, 03:49 PM | #12 |
Rep 351
Thread revival. First 5/6 weeks seemed OK with the 312GW, recorded media is what I would expect, perhaps a little below par on night videos. G sensor triggered a little more than expected, but better more than nothing and I'd clean up more often.
25th I am fitting an upgrade in the form of the 512GW. Long story short, cam didn't record a hit and run. Either because the battery depleted over 1/2 days after 2 short vids when initally fitted into car when weather was moderately mild (+6 degrees). All checks including charging for 4-5 hours were made, including testing parking mode in the flat and in the car. It is what it is. Charged again after the incident and put into vehicle. This time the battery depletes due to 8 recordings back to back at 10pm of rain. Talking about light to medium rain. Desired parking mode just does not seem to want to work. Other solutions aren't the best as one week I can literally do 10 miles, the other I could do 50. I can't rely on the vehicle battery, especially with how easily the G sensor is triggered! I switch on internal lights and it goes off! Here's a thread I started on a dash cam forum where Nextbase apparently read into. https://dashcamtalk.com/forum/thread...mviewer.37434/ The app is hopeless. Fingers crossed and I have a bad unit out of many decent ones. Quality wise at night, this unit I have seems sub par.. |
12-30-2018, 05:39 PM | #14 | |
Rep 793
Do you have the nextbase hardwire kit. Which fuse have you tapped into? |
12-30-2018, 06:31 PM | #15 |
Rep 11
I have the Viofo A119s with custom firmware and more than happy with it
Daytime footage - Download RAW footage https://www.dropbox.com/s/nk0aucaipl...4_345.MP4?dl=0 Night Footage - Download RAW footage https://www.dropbox.com/s/ue3e2a8uuv...5_320.MP4?dl=0 |
12-30-2018, 08:41 PM | #16 | |
Rep 351
Yes, Nextbase own brand kit. Believe it’s #143 from memory, a ignition live only. Permanent live with the way the g sensors go off would ruin the car’s battery. My schedule is a bit erratic, so can’t always get in miles everyday. The kit is awful, I recall reading the only preset for voltage is 10.9V. Will double check packaging. Most other brands let you adjust accordingly. |
12-31-2018, 03:10 AM | #17 | |
Rep 512
Drives: 320i M Sport Shadow Edition
From the passenger side tucked under the headliner and feed this all the way back to the back pillar, down the side of the fixed seat back and the trim, lifted the seat base and feed it through to the boot. PM me and I'll do a little video for you if you want to see where the wires went |
12-31-2018, 04:22 AM | #18 | |
Rep 584
12-31-2018, 05:39 AM | #19 | |
Rep 793
Other wire into ground? |
12-31-2018, 02:47 PM | #20 | |
Rep 351
Whichever of the 2 is more convenient access wise |
12-31-2018, 02:58 PM | #21 | |
Rep 793
Thanks bud. Will give it a try. Then I will connect the other wire into fuse 143. By the way is the other wire battery+ or acc+? Keep hearing these two terms on the blackvue install. |
12-31-2018, 03:44 PM | #22 | |
Rep 351
Batt+ is if you use a fuse like #161, permanent live fuse. Always running off the car battery. From my own experience and others, I’d recommend against this as if the weather is bad/cam g sensor goes off, it’ll almost continually record whilst the vehicle is at standstill. Acc+ is ignition live, like #143/#141 any many others. This only charges the camera when ignition is live. (Press the button once without having foot on pedal) There’s a mapping of fuse numbers with symbols just tucked into a slit nearer rear seat side of the fuse box. The above two are grouped from memory. Make sure to follow the instruction of fitting the original fuse #143 into the top slot of the piggy back cable. Before sealing up and tidying everything plug the camera in the other end to see if it is charging whilst only the ignition is on. The black wire is ground, which you’ll fix into place under the nut. The red wire is dependent on your choice, but power either through batt+ or acc+ |
Mrklaw169.00 |
dashcam, dashcams, security, security camera, united kingdom |
