02-13-2019, 11:08 AM | #45 | |
Rep 15,858
As to active suspensions, isn't one of the best suspension systems out there at present the McLaren ProActive Chassis Control, featuring Adaptive Damping. To quote "provides much higher stiffness in roll compared to conventional suspension systems, and greater comfort in a straight line". Possibly the way forward in much simpler implementations. Less compromise than passive systems. I'm sure we need to open up a new topic. |
02-13-2019, 11:11 AM | #46 | |
Rep 19,982
02-13-2019, 11:45 AM | #47 | ||
Rep 5,681
In saying that I'm certainly not suggesting all adaptive systems are rubbish but I suspect the ones that work best are relatively complex and, because of the associated cost, tend to be found only on quite expensive cars. However, the "cheap" adaptive system on my F31 was frankly a waste of around £500 and it wouldn't surprise me if similarly priced offerings from other manufacturers fall into the same bracket. For normal road use I'd contend that a well sorted passive system is more than capable of providing a decent blend of handling and ride comfort for most drivers most of the time. As evidence of that the sports suspension offered by the likes of ACS and Birds show what can be achieved with a good passive system on a BMW and they do so without the cost and complexity of the more sophisticated adaptive systems; I daresay the set-up on a McLaren is better but short of a lottery win the cost of one of those is way beyond most of us! |
02-13-2019, 12:13 PM | #48 | |
Rep 3,965
And the adaptive suspension in my LCI 4 series feels better implemented than it was in my pre-LCI 3 series, for what it's worth Personal taste plays a role here of course as with tyres, steering feel etc etc
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
02-13-2019, 01:45 PM | #49 | |
Rep 15,858
Yes you are understanding it correctly. The benefit would come, (my experience with the 5-series), if there was a similar 'mid mode' damper map, more usable on a lot of our UK roads. |
02-14-2019, 02:29 AM | #51 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
Umm...probably not as it's already been to Deutschtech in Milton Keynes which is the nearest dealer to London taking part in the free fitting offer. It will be back with us in Norfolk next week if you fancy a day out.
02-14-2019, 03:37 AM | #52 |
Rep 734
Soooo I just got off the phone to Hastings Direct, provider of my car insurance, to ask about how much it would change my premium to alter the suspension, and they declined it outright, saying they wouldn't insure those changes.
Does anyone recommend an insurer that will cover such changes? |
02-14-2019, 04:37 AM | #53 | |
Rep 8,495
I eventually moved to A-Plan Thatcham as Admiral ran out of boxes to list all my mods
02-14-2019, 04:38 AM | #54 |
Rep 734
02-14-2019, 05:24 AM | #56 |
Rep 734
Had a chat with Admiral, they're offering £622 which is the cheapest I've found yet.
I should be getting a refund from Hastings too so I may go with this. |
02-14-2019, 06:16 AM | #57 | |
Rep 115
They have the following options with suspension: "We have the options when suspension on the vehicle is altered Suspension lowered less then 5cm Suspension lowered between 5cm and 12.5cm Suspension other (not lowered)". The ACS comes under 5cm as it only lowers by 25mm for my model. |
02-18-2019, 05:06 AM | #58 |
Rep 734
Apologies for bumping my own thread, but does anyone have any experience of how the car feels with just the ACS springs and not the dampers?
I'm having an internal battle over the nearly £2k expense of both the springs and dampers. |
02-18-2019, 07:25 AM | #59 | |
Rep 609
Drives: F31 330D xDrive MPPK ACS
I haven't tried one with non Adaptive dampers.
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
g9icy340.50 |
02-19-2019, 06:01 AM | #60 | ||
Rep 138
I don't like the way the car wallows and rocks on undulating roads; Lorcan indicated I'd need the dampers to sort that. However, I also find the nose (especially the outside corner) tends to "dip" into corners; whereas the wife's Mini Cooper feels much flatter on corner entry. If just the springs would help that dipping problem, and didn't make the wallowing/rocking too much worse, then I'd probably go for it. Probably can't stretch to the full spring + dampers at the moment. |
02-19-2019, 06:16 AM | #61 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
I've had springs only on passive dampers on my f31 335i for the past few years. I've done about 40k miles on them. Springs only is definitely a worthwhile upgrade (over MSport which is what I had before). However, it had to be said that the damping still isn't right. This is apparent when the road surface gets tricky (undulations, ruts) and you can feel the tyres losing grip where they shouldn't be. There's also a bit too much bouncing at speed at times. I keep planning to add the dampers, but it's a big outlay. I might still do it before the current offer ends.
02-19-2019, 06:24 AM | #62 | |
Rep 138
How does the MSport suspension compare to the standard? I've heard varying opinions, from good, to just that it's overly hard (I'm wondering how standard-to-AC would compare to MSport-to-AC). |
02-19-2019, 06:39 AM | #63 | ||
Rep 3,965
02-19-2019, 06:57 AM | #64 | |
Rep 15,858
I used to follow the VW scene a few years back, when we were running more VW models in the family,. A lot of models had the same issues, 'wallow' being a common problem. Main improvement was from better damping. Springs alone can simply move the problem, to say more rock and jitter. Nothing worse than stiff springs which are underdamped, IMO. |
