01-27-2014, 01:38 AM | #331 |
Rep 458
My NBT came with a replacement screen cable which I used to go from HU_Entry to NBT. It is the same colour but supposed to be a different cable.
Emulator came from eBay the second time and cost £199. Came from a guy in Poland. |
01-27-2014, 01:58 AM | #332 | |
Rep 458
Just remembered the brother in law runs a garage. He will probably have one in his workshop already I can borrow |
01-27-2014, 03:27 AM | #333 |
Rep 30
On the first attempt I had the car also hooked up to a truck battery
Then the second attempt on a charger with less than recommended current, however AC/Climate off, lights off, amplifiers disconnected etc. The car will go to transport mode (engine off) and come out of it after 5 minutes while firmware is getting updated, then you might be able to start the car and let the firmware update run However I didn't try it myself. Just in case if you'd think you'd run into trouble. |
01-27-2014, 07:57 AM | #335 |
Rep 458
Surely this can't be right. What in the car could possibly draw 50 amps per hour with everything switched off. That is a huge current draw and is three times that of an electric oven. That power has to go somewhere and generate a lot of heat and I can't see where that is in this situation.
01-27-2014, 08:26 AM | #336 |
Rep 30
I had mine on a 25 amp charger while updating. After a couple of hours, I measured the battery to be almost the same voltage as before. But again, I disconencted and switched off everything possible. It also depends quite a lot on the equipment you got in the car I guess.
01-27-2014, 01:41 PM | #339 |
Rep 458
Thanks. Not cheap either but at least it's available. I've found the Schumacher model also in the uk but the retail price is £700!!
Is the one on Amazon.com above usable on 240v systems and what type of plug does it come with. I can get that one via BundleBox for about £300. Last edited by steddyman; 01-27-2014 at 01:48 PM.. |
01-28-2014, 12:54 AM | #341 |
Rep 40,763
I don't know why some much current could be drawn during flashing, but this is what BMW is saying is needed. When E6x first came out, BMW was saying a minimum 40A charger was needed. Then when Fxx came out, they upped it to 70A, and now I am hearing for the latest Fxx, they upped it to 100A.
As for the voltage, it is critical it not drop below 12.6 Volts. As for the Schumacher INC-700A, according to the specs here: http://www.batterychargers.com/Produ...tName=94080035 "120/220 VAC 50/60 Hz Input • Microprocessor controlled operation • Extra long 9’ line cord with 20A plug" And from the manual here on page 6: http://www.batterychargers.com/Docum...00906-0709.pdf "This battery charger, with auto line voltage select function, is for use on nominal 120 volt and 240 volt circuits."
01-28-2014, 05:58 AM | #343 |
Rep 40,763
Sorry, I don't remember if the power cable detaches or not, and I won't return home from Canada until Friday to look at it.
01-28-2014, 12:20 PM | #345 |
Rep 40,763
Thanks. Leaving Toronto for Montreal tonight. Always nice to visit Canada, but damn cold here right now.
01-28-2014, 04:58 PM | #346 |
Rep 458
01-28-2014, 08:35 PM | #347 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-30-2014, 08:37 AM | #348 |
Rep 458
Some very good news to report.
The new iDrive Touch controller arrived today from Germany and I swapped my No Nav controller over and it worked first time!! So it is confirmed the UK MY2014 spec cars are K-CAN2 as standard. All the buttons are working and the NBT is showing the Touch options in the Settings menu, but none of the Touch functionality is currently working. I haven't yet done any coding, could it need VO coding perhaps or require something else? This is the unit I purchased: http://www.ebay.com/itm/111249939959...84.m1439.l2649 I also should point out that the on-screen iDrive input wheel makes no mention of touch, only voice. Last edited by steddyman; 01-30-2014 at 09:07 AM.. |
01-30-2014, 01:23 PM | #349 |
Rep 40,763
Did you also buy the Handwriting Module, or just the iDrive Controller?
01-30-2014, 03:16 PM | #350 |
Rep 458
I didn't buy a HBX but I am not 100% sure if it isn't already affixed to the bottom. The reason I say that it is very deep and there is a different part number on the bottom than the side. It has 6582-9229305-01 on the bottom.
I tried to VO code the ZBE3, but it doesn't appear to have a CAFD file associated with it (see below). |
01-30-2014, 04:32 PM | #351 |
Rep 40,763
Do you have TBX ECU in your SVT?
