04-16-2023, 04:37 PM | #705 |
Rep 661
Both evo and TU will need the same modifications to get the base plate to fit onto our N55 vacuum pump holes. You'll need to dremel out the correct hole locations. I'm still a little vague about the harness, but it will ultimately be pretty easy considering the worst we'll do is to cut the harness' plug and rewire it somehow because there are a bunch of B58 hpfp harness extenders you can buy for cheap; no big deal.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
04-16-2023, 07:08 PM | #706 | |
Rep 7,606
04-17-2023, 09:04 AM | #707 | |
Rep 661
I don't want to speculate without being sure, so don't take my word for it. If I may, I do remember seeing a thread where someone made measurements to both pumps and posted their findings. Don't remember the details, but the seal ring landing on the TU is slightly different than the evo; but not so to have mattered swapping between the different B58 engines; however, does raise cautionary concern onto our N55's. Then for TU pump to have that much more flow volume than evo, something has to be within the assembly to set that difference. This is where my knowledge ends, I'm willing to listen for more discovery and science.
04-17-2023, 09:56 AM | #709 |
Rep 661
N55 is mechanically driven, but does work off a cam-like setup. So technically they are both cam driven. The N55's vacuum pump's hind section has a cam lobe that turns, and it's driven by the vacuum pump pulley which is in the same chain loop with crankshaft and oil sump pump. So if you ever take the HPFP out on a N55 and look into the hole, you'll see a cam lobe, this is independent from the intake and exhaust cams which are driven by the timing chain loop. But on the pump itself, the N55 and B58 HPFP are both sprung pumps, lots of semblances to be found, although I've not seen the internal mechanism; so I couldn't comment on those.
04-19-2023, 12:33 AM | #710 | |
Rep 93
yupetc389.50 |
04-19-2023, 11:29 AM | #711 | |
Rep 7,606
04-19-2023, 02:52 PM | #712 |
Rep 93
I only see stage 2+ e20 tune, do you mean stage 2 hpfp e40 tune?
04-19-2023, 05:09 PM | #713 | |
@_sunbish
282
Rep 611
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
04-19-2023, 05:15 PM | #714 |
Rep 7,606
04-20-2023, 09:17 AM | #716 |
Rep 5,392
Note: When discussing HPFP fuel pump flow rates, it’s important to understand that besides being higher capacity pumps, the two B58 fuel pumps also flow over 6% more on the B58 engine because the N55 & B58 engines have different size cam lobes that the pumps ride on inside the engine. Make sure that flow rates are all being measured on the same engine. See photos for data.
yupetc389.50 |
04-20-2023, 10:49 AM | #717 |
Rep 93
I wonder what boost target is on that, I’m not sure if b58 hpfp on my setup can handle e40, pure500 turbo is more demanding. My current tune is e30 mix, I’m seeing b58 evo hpfp crash above 21psi, oem n55 hpfp crashed at 17-18psi.
04-20-2023, 10:52 AM | #718 | |
Rep 4,146
Mods: Yes.
F87source7251.50 |
04-20-2023, 07:53 PM | #719 |
Rep 7,606
I only saw one log on it in the MHD log IIRC. It was only like 1-2 psi more than the stage 2 map from what i remember. I think it would be lower boost than your custom tune but higher ethanol, so it would be an interesting comparison if you can test it, both from a datalog perspective and a "how it feels" perspective.
04-21-2023, 09:28 AM | #720 | |
Rep 661
That's an insightful note to make. Really appreciate the breakdown.
johnung4528.00 |
01-27-2024, 03:03 PM | #722 |
Rep 7,606
There is a risk that the TU could cause damage in the long term, mostly due to the way it has to be installed without precise alignment. Tons of people run it without issue (at least from what we hear about on here) but going with a stage 1 that is specifically designed for N55 is safter.
01-27-2024, 05:31 PM | #723 | |
Rep 14
