10-22-2020, 07:04 PM | #67 | ||
Rep 210
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
10-22-2020, 07:09 PM | #68 |
Rep 3,696
10-22-2020, 07:13 PM | #69 |
Rep 210
The dyno logs were after this so I think it got cleaned up. I haven't messed with power mods in a while (close to two years) and no issues. Honestly not sure how much longer I'll have the car at this point. Been a little bored with it lately minus road track time. Not convinced I want to invest in PS2 plus hpfp.
10-22-2020, 07:22 PM | #70 |
@_sunbish
282
Rep 611
10-22-2020, 07:25 PM | #71 |
Rep 210
That's correct. Stock turbo, stock hpfp, stock lpfp.
10-22-2020, 07:40 PM | #72 |
Rep 7,606
What do you mean? His boost targets are only 15-16.5 psi and actual MAP is around 16psi. That within what a stock EWG FBO cat with catless DPs can hold to redline. Some other custom tunes push even higher, but they may trail down to around the same value. There appears to be even a little more turbo headroom, especially in the higher gears with more load, since WGDC isnt excessively high. The boost targets are modest because its an ethanol tune with stock HPFP. The BM3 stage 2+ E30 maps are targeting 20+ psi and although we still need some f3x stock turbo logs, the M2 logs are showing people holding 19+psi to redline with stock EWG turbo (perhaps manifold at play, need those f3x logs).
FastF30521.00 |
10-22-2020, 07:40 PM | #73 |
Rep 1,288
Never gonna get a clean 4th gear pull am I ...lol.... well when you put it on VD and smooth 6 which is averaging the Hp the best over the whole range you get 382whp.... Jeremy and I are getting 400whp for your reference... try to get me a clean 4th gear pull...
10-22-2020, 07:42 PM | #74 |
Rep 7,606
It shouldnt be torque limits. Those would close throttle and pull timing evenly across all cylinders. Also, 3rd and 6th would likely have the only torque limits that you would hit with this level of power, and theres no throttle closure in 3rd. The timing corrections in the higher gears are likely just due to octane limitations and the quite aggressive timing targets on the tune, combined with the fact that everything is getting hot by that duration into the run.
10-22-2020, 07:43 PM | #75 |
Rep 1,288
EstorilMSport83.50 |
10-22-2020, 07:44 PM | #76 | |
Rep 7,606
10-22-2020, 07:46 PM | #77 |
Rep 1,288
10-22-2020, 08:02 PM | #78 |
Rep 210
Yeah when temps drop the time slips go with it...
10-22-2020, 08:04 PM | #79 | |
Rep 1,288
10-22-2020, 08:08 PM | #80 | ||
Rep 210
10-22-2020, 08:12 PM | #81 |
Rep 1,288
10-22-2020, 08:14 PM | #82 |
Rep 1,288
10-22-2020, 08:27 PM | #83 |
Rep 210
What exactly are we trying to confirm/dispel here? Virtual dyno is accurate/inaccurate? Why not jump on a dynojet and figure out what it's making?
10-22-2020, 08:32 PM | #84 |
Rep 1,288
Basically just did... thanks... I wish the pandemic thing would end... I have a timeshare in orlando... love to go there this January.... Only time I wouldn't mind driving there so I could put this car on the strip there...
10-22-2020, 09:40 PM | #85 |
Rep 1,288
Please try to get me that 4th gear pull... make sure at least 3500-6400+ rpm... I have a feeling your numbers will rise... I'd really really would appreciate it...
10-22-2020, 09:56 PM | #86 | |
Rep 2,639
10-22-2020, 09:56 PM | #87 | |
Rep 3,696
To get us back on track, bolt an aftermarket HPFP onto an FBO stock turbo EWG N55, flash this map, and you’re at ~425whp. Add a PS2 after that, and you’re 500+ whp. |
10-22-2020, 10:45 PM | #88 | |
Rep 1,288
