BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > New to coding: looking for recommendations to create standalone laptop with SW
      06-16-2021, 03:14 PM   #1
cfm56d7b
I am very new to coding.
Overview of the project:
- Plan to get a basic Windows 10 laptop with 1 GB SSD / 16 GB of RAM, newer processor
- I will be coding two vehicles: 2017 F36 and 2015 X15
- What ENET cables do you recommend? Happy to pay extra for high quality cables
- What software is required? From what source?
Appreciate all feedback. I will learn quickly.
      06-16-2021, 03:27 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Unless you're going to flash or do VO coding make life easier and use Bimmercode.
cfm56d7b5886.00
      06-16-2021, 04:37 PM   #3
cfm56d7b
Thanks for responding, Billfitz. I do need flash capability.
      06-17-2021, 10:09 AM   #4
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
I bought a old-ish Dell E4310 from Craigslist for about $200, then spent some more $$ to dump a 500GB SSD to store the full PSDZ data and ISTA files. Something like this and this.
If you're going to flash your ECUs, you're going to need a ICOM unit as I dont think you can do it over ENET. You're also going to need a external power source to power all the ECUs while programming. This is done using a specialized programming charger or having a second running car connected via jumper cables.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
cfm56d7b5886.00
      06-17-2021, 10:46 AM   #5
atzebmw
Drives: Tesla Model 3
You can flash over ENET if you are using E-Sys.
E-sys has the advantage to flash single ecus.
With some special and newer versions of ISTA you can also flash over ENET.
      06-17-2021, 11:14 AM   #6
cfm56d7b
Thanks for the recommendation and links to suitable laptops.
Can you recommend a specialized programming charger? Where can I get one?
Is there a source where I can purchase ISTA+ with an easier installation process?
      06-17-2021, 03:07 PM   #7
ST3VO
ST3VO's Avatar
England
Drives: F30 330d M Sport LCI
I've been using a Dell 32GB Inspiron with 4GB RAM for my car programming. I have Fiat, Audi and now eSys on there and it's very adequate, although it's eMMC drive is near full.
You really only need a low end laptop. The most important thing really is battery life. The Inspiron I have lasts a good 8 hours, due to the low end specs. It also has no LAN port. I use a USB to Lan dongle and a cheapo ENET lead from china with no issues.
cfm56d7b5886.00
      06-17-2021, 09:45 PM   #8
capt_slow
capt_slow's Avatar
The Schumacher
is the one I'm aware of, but really any DC power supply capable of delivering 13V at 70A+ will do the trick.
You can find ISTA download links around the Internet or even in the coding forum. The install process is a bit intimidating, but its not that bad.
coding
