09-05-2021, 12:30 PM | #1 |
Rep 327
MPPK intake vs. Dinan cold air intake
I have a 2015 435i with the MPPK. I have tuned the car but am still running the MPPK intake with a drop-in filter. I am interested in running the Dinan cold air intake instead but wanted to see if anyone has made this change. Or, has anyone upgraded to the Dinan cold air intake from the stock intake? If so, what are your thoughts?
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
09-05-2021, 12:40 PM | #2 |
Rep 965
Drives: 2016 F36 435x MSport
Skip the dinan, stick with the mppk.
09-05-2021, 12:50 PM | #3 |
Rep 884
If you switch to the Dinan be sure to install the supplied MPPK airbox blocking plate. (Eliminates the red portal opening in the MPPK airbox bottom). The Dinan is designed to be a resonant closed-airbox cold air intake, and won’t provide any advantage otherwise.
09-05-2021, 12:56 PM | #4 |
Rep 327
Is that because the Dinan cold air intake isn't an improvement over the MPPK intake or do you say that for some other reason?
09-05-2021, 12:58 PM | #5 | |
Rep 327
09-05-2021, 01:52 PM | #6 | |
1296
Rep 3,533
the mppk is a better choice and makes more power than the dinan.
johnung4528.00 |
09-05-2021, 02:27 PM | #7 | ||
Rep 327
n55david1295.50 |
09-05-2021, 07:12 PM | #8 | |
Rep 5,394
There's a thread all about intakes that a couple guys did that documents this. |
09-05-2021, 08:11 PM | #9 | ||
Rep 327
johnung4528.00 |
09-06-2021, 12:40 AM | #10 |
Rep 884
My own experience is only with the Dinan vs. the stock (non-MPPK) intake/filter. Where my stock airbox bottom has with the built-in simple thermo-regulated ‘cold pkg’ heated-air intake port in the airbox. I don’t have MPPK. I was attracted to the Dinan because it’s a sealed, larger volume box mated with a smoother, more consistent larger diameter cross-section intake tube. With the low O2 up here at altitude, optimizing what little I got has always proved fruitful.
I only did some early-on intake testing using PerfExpert, and my timed-section backroad drives back before I had MHD. (and I haven’t had any motivation since to switch back to repeat my testing). I tested 4 configs (I’m an aero engineer geek): stock with port open and port closed, and the Dinan with port open and port sealed. I was trying to see what the effect was of the stock port, but also to try to see if I really needed to seal up the airbox ports as Dinan instructed (potentially affecting my cold starts). I also knew MPPK had the big added port, so I was looking to see if opening the ‘cold’ port might have a similar (though smaller) effect. My takeaways were: Performance (peak power and responsiveness) Dinan sealed port Stock closed port Stock open port Dinan open port Intake roar (from drivers seat, windows down) Dinan open port Stock open port Dinan sealed port Stock closed port Thus it’s my advice that if you’re going to run the Dinan, run it sealed. I felt it aided responsiveness and enhanced the top end (a bit more breath at higher revs). They didn’t design and include 2 different port-seal kits with the intake to save money. And if you already spent for the MPPK box, it makes it no advantage over the stock airbox bottom, as you’d seal both. Note, I’m aware of the intake and Dinan MAF issue threads here, which I think are good info but incomplete, never running the Dinan as a fully closed airbox as the intake was engineered - and only using it unsealed with an MPPK open-port airbox bottom… And I agree that an improvement on stock is a better flowing drop-in filter. I just don’t think opening the airbox adds anything but sound. |
Dinan_Engineering3912.00 123Britt289.00 |
09-08-2021, 04:22 PM | #11 |
Rep 7,607
Was away a few days and didnt see this until now, surprised no one linked my thread...
I studied this in depth, OP read my thread: https://f30.bimmerpost.com/forums/sh....php?t=1765289 I would not waste money on the dinan or any other intake for that matter, unless you are seeking only a sound change and no performance. If you want to improve the "intake system" get a turbo inlet like MST v2 and retain stock intake. BMWApp |
n55david1295.50 alohasurftoad3081.50 |
09-08-2021, 09:57 PM | #12 | |
Rep 327
09-09-2021, 10:38 PM | #14 |
Rep 286
Drives: 2014 335i 6MT MSport
I have MPPK. Replaced intake pipe and upper box with BMS intake. No perceptible performance difference other than a now-drifty idle on a cold start, and I found the turbo noise intrusive to my surprise — thought I'd like that! — so I'm probably gonna yank the BMS and go back to the MPPK box.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
09-10-2021, 12:15 AM | #15 | |
Rep 7,607
09-12-2021, 09:25 AM | #16 | |
Rep 286
An objective FAQ/wiki "sticky" about performance upgrades especially re cost/benefit would be useful to those of us without access to test equipment, or just getting started. Might reduce the number of "which intercooler should I get?" types of posts. Anyone want to buy a slightly-used red-filter F30 N55 BMS intake? 😉
09-12-2021, 02:15 PM | #17 | |
Rep 7,607
09-12-2021, 05:28 PM | #18 | ||
1296
Rep 3,533
2. just put a jb4 on it 3. add 6 gallons of e85 4. Dinan is the best value per dollar per hp you can buy 5. always gap your plugs .020-.022 6. straight pipe and resonator removal is the best exhaust setup with no rasp 7. if you want customer service VRSF is your best bet 8. Vargas is the best turbo for everyone and you get awesome customer service 9. just unplug the maf 10. ghassan automotive is the best for engines and finally 11. lpfp is a must if you mod your car. hope that helps buddy
ctt30047.00 |
09-12-2021, 11:32 PM | #19 | |
Rep 7,607
09-18-2021, 10:27 AM | #21 | |
Rep 931
09-27-2021, 02:42 PM | #22 |
Rep 4,146
I've said elsewhere - there was a noticeable difference going from the stock box (with drop in filter) to the MPPK box. Less lag, and better sounds.
Mods: Yes.
